Author Topic: Cherry G80 with MX Clears for $40 shipped  (Read 1952 times)
Offline WRXChris
« on: Wed, 06 June 2012, 00:50:32 »
http://www.ebay.com/itm/Cherry-Mechanical-PS2-Keyboard-MX-Clear-Touchpad-Programmable-N-Key-Rollover-G80-/221042551148?pt=PCA_Mice_Trackballs&hash=item337729a96c#ht_3715wt_1395
Decent price for 120 clear switches (well 119 clears and a light grey).  Only problem is it's plate mount so if your after the stems you're going to have to either desolder the switches or snip the top half of the switch off to get at the stems & springs.
Offline Hak Foo
  • Make America Clicky Again!
« Reply #1 on: Wed, 06 June 2012, 01:01:12 »
Quote from: WRXChris;608353
8113s are circuit-board mount; the board is just black.
Overton130, Box Pale Blues.
Offline MMB
« Reply #2 on: Thu, 07 June 2012, 20:19:35 »
I have bought 2 of these from this person. They are not plate-mounted.
Offline WRXChris
« Reply #3 on: Thu, 07 June 2012, 21:30:05 »
Apologies for the misinfo, that's good to know!  And also sorry for being a douche about your threadcrapping in the hhkb aluminum thread, MagicMeatball.
Offline shawn o
« Reply #4 on: Thu, 07 June 2012, 22:23:18 »
Doesn't matter if they are PCB mount, they are easily modified.
