Author Topic: RF 10th Anniv and LED in left Control key  (Read 1926 times)
Offline jcrouse
« on: Thu, 07 June 2012, 17:29:56 »
I have a Realforce 10th anniversary. It has lighted keycaps for the Caps Lock, Num Lock and Left Contol key. The caps light up when I press and release either the Cpas Lock of Num Lock, just as one would expect. However, I don't know hot to get the light on for the left control key. Any ideas?
Thanks,
John
Offline laffindude
« Reply #1 on: Thu, 07 June 2012, 17:54:12 »
Swap Capslock and Ctrl.
Offline reaper
« Reply #2 on: Thu, 07 June 2012, 18:50:21 »
Go here, scroll down, look for DIP switch settings.
Din Eli
Offline jcrouse
« Reply #3 on: Thu, 07 June 2012, 19:24:26 »
Thanks Reaper. After I posted, it hit me but I still couldn't find the link you provided, so thanks. Now, why would one want to swap them?
John
Offline zirb
« Reply #4 on: Fri, 08 June 2012, 03:08:10 »
Control is in the Caps Lock-position on HHKB, some people prefer that layout after using it that way
