Author Topic: leopold otaku key question  (Read 1989 times)
Offline draterrojam
« on: Sat, 09 June 2012, 16:43:07 »
So I just got a otaku (red switches), I love it so far. However, i got some key caps from wasdkeyboads.com and the space bar seems to not fit the otaku. Is this normal?
Offline Chicken Chaser
« Reply #1 on: Sat, 09 June 2012, 17:30:32 »
http://geekhack.org/showthread.php?30141-Keycap-Compatibility-FAQ
Unfortunately, the WASDkeyboards space bar does not fit Leopolds
Leopold TKL Blues || Leopold TKL Reds || Filco TKL Ninja Browns
Offline jwaz
  • * based mod
  • #geekhack on freenode
« Reply #2 on: Sat, 09 June 2012, 17:36:24 »
The Profosist can mod it for you or EK sells high texture Leopold compatible space bars.
http://elitekeyboards.com/products.php?sub=access,cherrymxkeys&pid=sb_u2
Offline Reptile
« Reply #3 on: Sat, 09 June 2012, 18:08:17 »
Quote from: JesuswasaZombie;610494
I would suggest someone else for modding
Home:Realforce 87UB 55g
Work:Leopold FC700R Ergo Clears
Offline oddsratio
« Reply #4 on: Mon, 11 June 2012, 23:18:47 »
Quote from: Reptile;610506
Hmm, any reason why? I mean, I was happy with the work when I had no other options a couple months ago, though the cost became a bit much on the revisions. I bought two spare spacebars from EK though last month just in case they went out of stock again.
Offline Caaaarrrt
« Reply #5 on: Tue, 12 June 2012, 01:53:43 »
I believe those EK Leopold compatible space bars are only compatible with the FC200R not the FC500R fullsize keyboard, which has different stabiliser stem spacing again.
Metal Grey LZ-GH - 62g Clears | White HHKB Pro2 |KBC Poker - Lubed Reds w/ Plate and Red Imsto case | Duck Poker |  CM QuickFire Rapid - Blues w/ red case
