Author Topic: Can you replace caps lock with an R4 key?  (Read 2304 times)
Offline dmbr
« on: Sat, 09 June 2012, 20:05:02 »
I've seen some pics where it appears to have been done. Is it an R4 keycap that's being used?
Offline Nunez
  • BACK!
« Reply #1 on: Sat, 09 June 2012, 22:11:32 »
Well, its definitely possible.
The height profile will be an issue.
[ Attachment Invalid Or Does Not Exist ] 52606[/ATTACH] [ Attachment Invalid Or Does Not Exist ] 52607[/ATTACH]
I miss Ripster :(
HHKB Pro 2 || KBC Poker || Filco MJ2
Offline Rumudiez
« Reply #2 on: Sun, 10 June 2012, 18:13:20 »
What pics have you seen doing it that are actually appealing? As Nunez wrote, it's possible given all cherry stems are the same and stabilizers won't be an issue, but it's kind of weird..
40% layout, anyone?
Offline metafour
« Reply #3 on: Sun, 10 June 2012, 18:15:28 »
I use the short right shift from an 1822 as my capslock.
Offline dmbr
« Reply #4 on: Mon, 11 June 2012, 11:58:36 »
Quote from: Nunez;610602
(Attachment Link) 52606[/ATTACH] (Attachment Link) 52607[/ATTACH]
Ah, I see. Hadn't considered the height.
I have a clear r4 which I was thinking of using for looks with the LED; I also figured it might cut down on accidental allcaps.
Thanks for the replies!
Offline MMB
