Author Topic: Need Help 122 Key M Resto  (Read 10542 times)
Offline themadreason
« on: Sun, 10 June 2012, 16:40:54 »
You may remember that I have been modding a 122 key M to work with my PC through a USB connector.  I have the bolt mod done.  I replaced the left shift key with a larger one from a 101 key M.  I fabricated my own press fit connector from some wood with a hand saw.  I used some foam insulation to get the connections to press together.
After trying several different configurations for the press fit connector, I still cannot get the keys for Q, A, and Z to register.  The rest of the keyboard works.
Can anyone help me troubleshoot this?  I worked with the barrel plate to ensure that it is flat with the back plate.  I have tried hitting the key hammers through the barrels with a tooth pick.
Still nothing for the Q key cluster.  I am so close to getting this mod done!  The bolt mod makes the keys feel FANTASTIC!
Advice?  Questions?  Comments?  Caustic remarks?
« Reply #1 on: Mon, 11 June 2012, 14:49:18 »
Don't know the solution to your problem, but I may have some internal parts (membrane, etc) for sale or trade that could replace your problem parts, if that is what it is.
PM me if that is a direction you want to go, I will have to dig around in some boxes.
- D Trump 2026-10-24
Thanks
« Reply #2 on: Thu, 14 June 2012, 14:01:01 »
for the offer.  I will keep that in mind.  I think that my problem may be at the software end.  Are there any special drivers that I need to make this keyboard work?
I allowed the Ruffian controller to auto install drivers.  Do I need some special software with the operating system?
« Reply #3 on: Thu, 14 June 2012, 15:38:52 »
I have only done Model F 122s, and used Soarer's converter. It worked like a charm, and the only additional software was when I used Key Tweak to move some things around.
I don't know anything about Model Ms except the standard ANSI ones.
