Author Topic: broken SSK  (Read 3880 times)
Offline mkawa
  •  No Marketplace Access
  • (ツ)@@@. crankypants
broken SSK
« on: Mon, 11 June 2012, 02:42:23 »
Offline ricercar
  • mostly abides
broken SSK
« Reply #1 on: Mon, 11 June 2012, 11:33:09 »
I have a broken SSK, too, but I'm not that auction holder. A number of keys are stiff, z and x don't work at all. Anyone want to take it off my hands for $50 shipped CONUS please PM.
Offline metafour
broken SSK
« Reply #2 on: Mon, 11 June 2012, 12:49:36 »
Are they fixable?
Offline REVENGE
broken SSK
« Reply #3 on: Mon, 11 June 2012, 14:16:35 »
Quote from: metafour;611294
Are they fixable?
Probably. It depends on the type of damage, but the internal frame and spring & hammer assemblies can be ordered from Unicomp. I don't know about the membrane or PCB.
Offline mkawa
broken SSK
« Reply #4 on: Mon, 11 June 2012, 17:12:09 »
unicomp does _not_ sell the membrane or PCB (the former i've confirmed with them, the latter i'm guessing, as they have a new controller board they use now that wouldn't work with the SSK matrix). they also don't sell the rubber layer or cover sets. so basically, it may not be, easily anyway.
Offline Heisenberg
broken SSK
« Reply #5 on: Mon, 11 June 2012, 18:00:59 »
Just get a working full size and swap the guts. The keys not working could be something as simple as the spring or hammer being out of place.
Offline Internetlad
broken SSK
« Reply #6 on: Mon, 11 June 2012, 18:04:25 »
it would be a cool learning experience, but I just spent some cash on a board and my accountant (Read: Wife) wouldn't be to happy about that.
"Beep . . . Beep . . . Beep" -Sputnik I
broken SSK
« Reply #7 on: Mon, 11 June 2012, 18:39:38 »
Quote from: Heisenberg;611550
You won't get the embedded numpad anymore, though :o
Offline bazemk1979
broken SSK
« Reply #8 on: Mon, 11 June 2012, 18:53:51 »
how about the fullsize boards, you can always get membrane or PCB replacement in case something goes wrong with the bolt mod right? I'm talking of the 101 boards.
Offline Heisenberg
broken SSK
« Reply #9 on: Mon, 11 June 2012, 19:40:11 »
Quote from: dorkvader;611563
Isn't that dependent on the controller? If you swapped the membrane and hammers only, wouldn't it be fine? Who uses the embedded pad anyway...
Offline mkawa
broken SSK
« Reply #10 on: Mon, 11 June 2012, 20:32:12 »
the bigger issue is that the pinout of the ssk matrix is different than the pinout of the 101 matrix. further, the controller for the 101 won't necessarily cleanly mount on in the ssk case, and takes a full-size membrane pinout
basically, mixing and matching is difficult, and going wholesale 101 is also tricky. basically, membrane and controller issues can be tricky. hammer issues are easy, sure, until you realize that you have to bolt-mod just to get at those.
Offline REVENGE
broken SSK
« Reply #11 on: Tue, 12 June 2012, 01:22:42 »
You can probably buy the controller for the SSK from Unicomp. Repair the PCB yourself or swap one from a full-size.
Offline MMB
broken SSK
« Reply #12 on: Tue, 12 June 2012, 06:25:16 »
I pulled a controller from a full-sized Model M, placed it into an SSK. Worked fine.
broken SSK
« Reply #13 on: Tue, 12 June 2012, 09:22:40 »
Can't you just wire a Teensy directly to the matrix? Those connectors between the membrane and PCB don't look that unique.
Offline mkawa
broken SSK
« Reply #14 on: Tue, 12 June 2012, 09:46:15 »
Quote from: MagicMeatball;611906
i stand corrected
Offline mkawa
broken SSK
« Reply #15 on: Tue, 12 June 2012, 09:47:08 »
Quote from: dorkvader;611966
some guy did do this recently, but imo it looks like a pain, not to mention the cover now has a weird looking holes in it
Offline Wildcard
  • When caffeine isn't enough
broken SSK
« Reply #16 on: Tue, 12 June 2012, 12:57:18 »
Just sent a PM if it's still available, might be a good board for parts.
Offline MissileMike
broken SSK
« Reply #17 on: Tue, 12 June 2012, 14:48:16 »
Quote from: mkawa;611975
i stand corrected
I am typing this on a terminal M-spacesaving with a full 1391401 controller.  Yes, it works- the only thing you lose is the virtual numpad, which I don't think anyone ever uses anyway.
BS: 5 Space Savers  ||  9 42H  ||  10 1391401 or similar  ||  1x 1390131  || AT&T 305b  ||  Dell Model M
Cherry: Leopold FC200RC/AB  ||  3 Ducky 1087  ||  PLU ML87 ||  Cherry G80-8113LUVEU-2  browns
Alps: Filco Zero Tenkeyless (fukka)  ||  ABS M1  ||  3x Dell AT101w  ||  Ancer KF-191  ||  6 Vivanco Compact
Misc: NMB RT6855T+  ||  NMB RT101 Space Invader  ||  Dell Quietkey  ||  Ge Fanuc Industrial Metal
