Author Topic: Keyboard suggestion?  (Read 1489 times)
Offline palading
« on: Tue, 12 June 2012, 00:23:12 »
I want to buy a mechanical keyboard. Is there a 87-key keyboard that uses PBT caps and red switches?
Offline Caaaarrrt
« Reply #1 on: Tue, 12 June 2012, 01:49:15 »
Leopold FC700R comes with PBT caps and has the red switch option. I'm not sure if it is available yet where you are located though.
Or else you could buy any other red switch 87-key keyboard and buy some PBT caps separately.
Metal Grey LZ-GH - 62g Clears | White HHKB Pro2 |KBC Poker - Lubed Reds w/ Plate and Red Imsto case | Duck Poker |  CM QuickFire Rapid - Blues w/ red case
