Author Topic: NIB Chicony KB-5181 w/monterey blues on fleabay  (Read 4914 times)
Offline Internetlad
« on: Thu, 14 June 2012, 14:12:11 »
http://www.ebay.com/itm/Chicony-KB-5181-/251084247809?pt=PCA_Mice_Trackballs&hash=item3a75c99301#ht_500wt_1413
Don't know about "Great" find depending on the bids, but any NIB vintage mech is something to get excited about.
"Beep . . . Beep . . . Beep" -Sputnik I
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #1 on: Fri, 15 June 2012, 20:32:41 »
Great board.......part of my daily driver- cherry blues? Yea probably..........little noisier though from bottom-out.
I'm with you---new and vintage, first to use depending on price is a no brainer. Did take a little while to get use to the back space key.
Luga G80-1865/MX Reds + Dolch G80-1813/MX Blues + G80-3700HQAUS + DK9008G2 Pro/MX Browns Thick PBT + DK9008G2 Pro/MX Clears Thick PBT +  QFR TKL/Ghetto Greens + Cherry G80-1800/MX Blues + IBM Model M SSK Bolt Modded + IBM Model M + IBM Model F + IBM AT F + Cherry G80-1000 (HAD)/MX Vintage Blacks + Razer BWU/MX Blues + Leading Edge DC2214/Blue Alps + Compaq MX11800/Browns + Chicony 5181/Monterey Blues + Chicony 5161/MX Black Cherry Clone + Focus 2001/White Alps + Chicony 5191/White Futabas + Olivetti ANK27-101 + Dell (Old Logo) AT101/Black Alps + NMB RT8255C+/Black Space Invaders + Unitek K260/Green Alps + Apple M0116/Orange Alps + AEK II M3501/Cream Alps + AEK M0115/Orange Alps + NEC  APC412/Blue Sliders + NEC APC410/Blue Sliders + Omnikey /White Alps + Wang/Yellow Alps (Omrons) + Laser/White SMK + Fame/Blue Aruz + AEK II M3501/Salmon Alps + Zenith ZKB-2R/Green Alps + Wang 724/Orange Alps + DK1087/Green Alps + Zenith ZKB-2/Yellow Alps + Dell Old Logo AT101/Salmon-Pink Alps + Leading Edge AK1012/White SMK's + Magitronic SK-1030/White (Linear) Futaba's + Packard Bell/White (Clicky) Futaba's + Datacomp DFK101/White  Alps + SGI AT101/Dampened White Alps + NMB AQ6RT-72511/Grey Space Invaders (Hi-Tek) + Datacomp/Blue Alps + Phillips 2812/White Space Invaders (Linear) + Dah Yang K251/Vintage MX Blues + Chicony 5161/DS Caps/Vintage MX Blue + Archie-NMB AQ659ZRT-725/Black Space Invader (Tactile) + IBM Model M 71G4644 (RD) Bolt Modded with Soarers Converter + IBM Model M Silver Label 1390131 + Cherry G80-1501/Vintage MX Clears + Focus FK8000/Linear Futabas + Gateway 2000 Anykey Programmable/Maxi-Switch + Dell GY13PVAT101/Dye Sub Caps/Salmon Alps + Chicony 5161/White Alps + AST K0B101/Slider over RD + Qtronix QX-32H + Everex/NMB RT8255CW+ Black Space Invaders-Split Erase + Tandon/NMB AQ659ZRT-101A/Beige Space Invaders + Cherry G80-11903 MNRUS/MX Blacks + Apple IIGS A9M0330/SMK Whites + WYSE PCE/MX Blacks + Chicony 5160AXT/Clicky Futaba + Cherry G80-0528/Vintage MX Blacks + Dell AT101/Linear (Modded) Black Alps+Topre 55g
Offline False_Dmitry_II
« Reply #2 on: Tue, 19 June 2012, 20:21:33 »
Woot, it's mine. I haven't used one of those yet and man, did I get a good price on it.
Offline TexasFlood
« Reply #3 on: Tue, 19 June 2012, 20:26:13 »
Quote from: False_Dmitry_II;617393
You got a great deal! I love mine, can't imagine you won't enjoy it.
« Reply #4 on: Tue, 19 June 2012, 20:50:28 »
I bet I will. I like these space invaders and it's the other main 'like blues'.
I was expecting it to go higher than that for sure.
Offline Internetlad
« Reply #5 on: Fri, 22 June 2012, 15:33:24 »
nice catch! I checked the price before reading the thread and was like "Damn!"
Offline AKIMbO
  • HHKBro
« Reply #6 on: Fri, 22 June 2012, 16:35:51 »
Lolwut someone scored a deal of the century on that keyboard!
| KBD75 (box reds)
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
Offline TexasFlood
« Reply #8 on: Fri, 22 June 2012, 17:28:09 »
Doesn't say what switch so might not be monterey blue which most of use want this keyboard for, or at least that's what I wanted.
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #9 on: Fri, 22 June 2012, 17:54:24 »
Very true............
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #10 on: Fri, 22 June 2012, 17:57:17 »
Not sure if it helps or if there would be a difference, but the FCC ID number is the same as mine and I have blues............? Would  it be different if they were white?
Offline TexasFlood
« Reply #11 on: Fri, 22 June 2012, 17:59:34 »
And recently one showed up with blue cherries! So one never knows for sure without checking/asking.
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #12 on: Fri, 22 June 2012, 18:46:17 »
Get the heck out of here!
Wow...........
« Reply #13 on: Sat, 23 June 2012, 22:52:09 »
Quote from: Internetlad;619736
.. You started the thread.
« Reply #14 on: Sun, 24 June 2012, 18:57:26 »
Anyways I like them alot so far. Unfortunately it is missing one of the white pieces of plastic that holds a key to the metal wire. Originally it was one of the ones on the spacebar, but I took one from the right shift.
It otherwise does seem at least pretty close to new.
« Reply #15 on: Sun, 24 June 2012, 20:13:53 »
You mean a stabilizer insert? I have some that were in a NeXT keyboard. If they are the same, you can have some.
« Reply #16 on: Mon, 25 June 2012, 00:54:31 »
Yeah, if that's what they are called.
They look a bit different to any of the other ones I've seen so far.
« Reply #17 on: Mon, 25 June 2012, 09:11:26 »
Here's a picture of the ones I have. They look a bit different than the ones for costar on cherry MX.
http://i.imm.io/tWWB.jpeg
« Reply #18 on: Mon, 25 June 2012, 11:10:57 »
Those look closer to standard alps than these do. These have the the cherry plus, and the two things that go off like that but they are connected on the open end.
Offline Internetlad
« Reply #19 on: Mon, 25 June 2012, 11:22:22 »
Quote from: False_Dmitry_II;620604
yeah but it was still an auction, I meant when I saw what it went for.
