Author Topic: Is this supposed to happen?  (Read 3093 times)
Offline Spetnazz
« on: Fri, 15 June 2012, 18:37:59 »
Hey guys.
I've had my QPAD MK-85 mechanical keyboard with Cherry MX Red switches for a few days (my very first Mech keyboard) - I had no 'problems' the first 2 days, and everything went fine, until my spacebar started saying some pretty annoying squeaking sounds, so I lifted up the spacebar with my key-remover, popped it back on, and the annoying sound disappeared. BUT!
Now when I push a little bit from the "front" on the right side of the spacebar, it kinda moves upwards, but when I do it on the left side of the spacebar it doesn't move. I have no idea if this also happened before I lifted up the spacebar, since I really can't remember it, sooo.. Do you guys know if it's normal that the spacebar(s) does things like that, if no, is there anyway I can fix it? Not that it's a pain in the A for me, but I want my keyboard to be 100 % fine :P
Sorry for my bad english, I'm from Denmark. :D
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #1 on: Fri, 15 June 2012, 18:50:27 »
I'm not as well rehearsed as others still recognizing myself as a noob............., but sounds like your stabilizers popped off. I know there is a link on here somewhere to remedy that.
Luga G80-1865/MX Reds + Dolch G80-1813/MX Blues + G80-3700HQAUS + DK9008G2 Pro/MX Browns Thick PBT + DK9008G2 Pro/MX Clears Thick PBT +  QFR TKL/Ghetto Greens + Cherry G80-1800/MX Blues + IBM Model M SSK Bolt Modded + IBM Model M + IBM Model F + IBM AT F + Cherry G80-1000 (HAD)/MX Vintage Blacks + Razer BWU/MX Blues + Leading Edge DC2214/Blue Alps + Compaq MX11800/Browns + Chicony 5181/Monterey Blues + Chicony 5161/MX Black Cherry Clone + Focus 2001/White Alps + Chicony 5191/White Futabas + Olivetti ANK27-101 + Dell (Old Logo) AT101/Black Alps + NMB RT8255C+/Black Space Invaders + Unitek K260/Green Alps + Apple M0116/Orange Alps + AEK II M3501/Cream Alps + AEK M0115/Orange Alps + NEC  APC412/Blue Sliders + NEC APC410/Blue Sliders + Omnikey /White Alps + Wang/Yellow Alps (Omrons) + Laser/White SMK + Fame/Blue Aruz + AEK II M3501/Salmon Alps + Zenith ZKB-2R/Green Alps + Wang 724/Orange Alps + DK1087/Green Alps + Zenith ZKB-2/Yellow Alps + Dell Old Logo AT101/Salmon-Pink Alps + Leading Edge AK1012/White SMK's + Magitronic SK-1030/White (Linear) Futaba's + Packard Bell/White (Clicky) Futaba's + Datacomp DFK101/White  Alps + SGI AT101/Dampened White Alps + NMB AQ6RT-72511/Grey Space Invaders (Hi-Tek) + Datacomp/Blue Alps + Phillips 2812/White Space Invaders (Linear) + Dah Yang K251/Vintage MX Blues + Chicony 5161/DS Caps/Vintage MX Blue + Archie-NMB AQ659ZRT-725/Black Space Invader (Tactile) + IBM Model M 71G4644 (RD) Bolt Modded with Soarers Converter + IBM Model M Silver Label 1390131 + Cherry G80-1501/Vintage MX Clears + Focus FK8000/Linear Futabas + Gateway 2000 Anykey Programmable/Maxi-Switch + Dell GY13PVAT101/Dye Sub Caps/Salmon Alps + Chicony 5161/White Alps + AST K0B101/Slider over RD + Qtronix QX-32H + Everex/NMB RT8255CW+ Black Space Invaders-Split Erase + Tandon/NMB AQ659ZRT-101A/Beige Space Invaders + Cherry G80-11903 MNRUS/MX Blacks + Apple IIGS A9M0330/SMK Whites + WYSE PCE/MX Blacks + Chicony 5160AXT/Clicky Futaba + Cherry G80-0528/Vintage MX Blacks + Dell AT101/Linear (Modded) Black Alps+Topre 55g
Offline Spetnazz
« Reply #2 on: Fri, 15 June 2012, 19:14:38 »
As it seems to me, my stabilizers is just fine. And I don't think the right side is supposed to be more loose than the left side, that would be strange..
Offline Spetnazz
« Reply #3 on: Fri, 15 June 2012, 19:21:04 »
Well, I just filmed it (not the stabilizers), so you guys know exactly what I mean. You can hear that when I 'push' the spacebar to the left side it has a dark / deep sound, and that sound just gets lighter and lighter as I go to the right. I don't know if you can see it so clearly, but when I push the left side of the spacebar, it moves the whole spacebar upwards if you know what I mean, but to the right, it just moves the right, and into the middle where the Cherry MX red switch is placed. :P
[video=youtube_share;1NaKpx9Erb8]http://youtu.be/1NaKpx9Erb8[/video]
Offline rknize
    • metaruss
« Reply #4 on: Fri, 15 June 2012, 21:35:27 »
Do these use Costar or Cherry stabilizers?  You would pop the key off and check the stabs.
Russ
Offline Spetnazz
« Reply #5 on: Sat, 16 June 2012, 05:23:27 »
Quote from: rknize;614475
They use Cherry stabilizers. That's what is sais in the product information where I bought the keyboard
Offline Tony
« Reply #6 on: Sat, 16 June 2012, 06:46:19 »
I think that the stabilizer has been bent a bit.
Offline Spetnazz
« Reply #7 on: Sat, 16 June 2012, 11:52:07 »
Hmm maybe.. Do you have any idea how to fix it? Maybe a link or something? :D
Offline Quarzac
  • A very busy dude!
  • Still around, sometimes.
« Reply #8 on: Sat, 16 June 2012, 11:55:46 »
With a cherry stabilizer you could pull out the  stabilizer and replace it, but I don't know where you'd get a replacement. I'll be parting up a G80 sometime soon though, and will save them.
Risen from the dead for a model F.
Wyse buy colors were GSY for the dark grey, GBA for the light grey, and BBI for the fonts.
Offline Spetnazz
« Reply #9 on: Sat, 16 June 2012, 12:03:29 »
I've found a site that sells Cherry MX stabilizer springs, so as soon as possible, I'll order one or two of those, replace the stabilizer in the spacebar, and see if that will fix it. :D
Offline rknize
    • metaruss
« Reply #10 on: Sat, 16 June 2012, 12:24:24 »
I've twisted them before.  They are not difficult to straighten.  If you are thinking of replacing it anyway, maybe pop it out and give it a once over.
Russ
Offline Spetnazz
« Reply #11 on: Sat, 16 June 2012, 20:16:17 »
I got it sorted. My stabilizer had bent a bit, so I straightened it, and installed the spacebar again.
Thank you for all the answers, I was very close to RMA my keyboard, but that would be a shame, cause then I would have to live without my lovely new mech keyboard for about a week or so.
« Reply #12 on: Sat, 16 June 2012, 22:04:57 »
Quote from: Spetnazz;615133
I'm glad it worked out with you. You'll notice some GH'ers have multiple keyboards. I have spares for just such an eventuality. That's why I wont to get my model F working, so I can bolt-mod my unicomp without having to give up that excellent Buckling Spring keyfeel.
Offline Spetnazz
« Reply #13 on: Mon, 25 June 2012, 05:16:48 »
I got it fixed, but now it happens again.. Well that wouldn't be that hard to fix, but then I noticed that the "0" button on the numpad was totally stuck. So i'll RMA the keyboard within a few days, and when I get the money that it costed me, I'll buy the Filco MJ2 with brown switches :P
