Author Topic: Spherical Keycaps  (Read 4614 times)
Offline Chris_F
Spherical Keycaps
« on: Sat, 16 June 2012, 19:47:43 »
Is there anyplace that sells vintage looking spherical key caps for MX style switches? Something similar to the style of a Commodore 64 or other computers from that era.
« Last Edit: Sat, 16 June 2012, 20:00:57 by Chris_F »
Q: The best keyboards ever made are from the early '80s and have buckling springs.
A: True
Offline AKIMbO
  • HHKBro
Spherical Keycaps
« Reply #1 on: Sat, 16 June 2012, 19:59:18 »
If you are looking for a full set check out 7bit's round 4 group buy.  I'm pretty positive it's modeled (at least colorwise) after the space cadet keyboard.
« Last Edit: Sat, 16 June 2012, 20:03:44 by AKIMbO »
| KBD75 (box reds)
Spherical Keycaps
« Reply #2 on: Sun, 17 June 2012, 12:09:16 »
QWERkeys has some super thick sphericals from (I believe) devlin in the UK. I was very happy with the quality, but I believe they only have one profile.
