Author Topic: So, I heard you like thick keycaps :p  (Read 6024 times)
Offline nntnam
« on: Sun, 17 June 2012, 10:04:49 »
Did it myself. Still need to fix the mold. :-D
« Last Edit: Sun, 17 June 2012, 10:08:26 by nntnam »
░▒▓ KMAC | FILCO MJ2 | HHKB | PHANTOM ▓▒░
Offline GeorgeStorm
« Reply #1 on: Sun, 17 June 2012, 10:14:27 »
Must sound so deep :D
Poker with blacks
My flickr
Offline MMB
« Reply #2 on: Sun, 17 June 2012, 11:04:59 »
You brokeded the stem :(
WHat are you using for casting?
Offline nntnam
« Reply #3 on: Sun, 17 June 2012, 11:10:54 »
Quote from: MagicMeatball;615491
Yep. it is because of the mold. I need to re make the mold. The keycaps can sit on the keyboard but may loose easily. I'm using polyester at the moment, but seeking for another material, polyester doesn't give a good finish.
Offline MMB
« Reply #4 on: Sun, 17 June 2012, 11:13:15 »
Polyester resin is also highly toxic and dangerous to work with. Are you doing it outside with a filtered mask? I hope so >.<
Looks nice though. Have you tried it on a switch with an LED? Might wanna make sure it clears the LED.
Epoxy resin works well, and comes in clears.
« Last Edit: Sun, 17 June 2012, 11:16:32 by MagicMeatball »
Offline nntnam
« Reply #5 on: Sun, 17 June 2012, 11:20:39 »
Quote from: MagicMeatball;615497
Thanks for your warning. I almost don't know that >.<. Luckily, it's just my first try. Is it still toxic after cured? I don't have a led keyboard, so can't tell you about its transparency, but I think it does not let the light through much.
Offline MMB
« Reply #6 on: Sun, 17 June 2012, 11:35:42 »
Quote from: nntnam;615501
It's not still toxic when it's cured, but the fumes are dangerous when you are mixing the resin with the catalyst. Don't kill your brain cells my friend.
Try epoxy resin. It's still toxic, but not as bad. And definitely work outside, with a painters mask. :)
Offline MMB
« Reply #7 on: Sun, 17 June 2012, 11:40:09 »
http://www.****blick.com/products/artmolds-aquaclear-resin/
"Unlike polyester resins, (which are extremely toxic and require the use of a NIOSH mask), AquaClear has little or no odor. Set time: 15–20 minutes."
Offline nntnam
« Reply #8 on: Sun, 17 June 2012, 12:02:36 »
Quote from: MagicMeatball;615509
This looks good. Thanks for your help. This may be thing I'm seeking for.
« Reply #9 on: Sun, 17 June 2012, 12:12:10 »
Looks so thick, the switch housing will just barely miss the side of the keycap wall. (excellent!)
Good work: I hope you get your mould working, 'cause that'd look killer with or without an LED underneath.
Offline thegunner100
  • (╯'□')╯︵</3 ノ( '-'ノ)
    • The Emotional Skyscraper
« Reply #10 on: Sun, 17 June 2012, 12:13:47 »
Very nice, it reminds me of strawberry jelly :D
Input Devices:CM QF Rapidx2 ~ REALFORCE 87uw 45/55g ~ Logitech G5v2 ~ Wacom Bamboo CTH-460
Audio Setup: look me up on head-fi
Check out my blog on touhou/doujin music, audiophile gear, and doujin games!
Offline nntnam
« Reply #11 on: Sun, 17 June 2012, 12:49:52 »
Thanks for all your kind words, guys. I'm working on the new mold now. Hope it will work well this time :D
Offline MMB
« Reply #12 on: Sun, 17 June 2012, 14:30:16 »
