Author Topic: Cherry G84-4100?  (Read 4455 times)
Offline Upcboy
    • Perfect Aim
Cherry G84-4100?
« on: Tue, 19 June 2012, 02:38:05 »
Is there anyone that sells replacement Keycaps for this Keyboard? I'd love to have a blank set of keys for a replacement. What am I looking for?
Offline MMB
Cherry G84-4100?
« Reply #1 on: Tue, 19 June 2012, 02:40:56 »
This is pretty much your only option, as far as I know
http://www.ebay.com/itm/221010685841?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649#ht_500wt_1183
I have looked, but not many choices out there.
Offline MMB
Offline Upcboy
    • Perfect Aim
Cherry G84-4100?
« Reply #3 on: Tue, 19 June 2012, 02:43:12 »
I see i have a replacement board already... (as you can tell I'm never happy with what i have) did you notice they layout of the keys are slightly different between that one and the Black KB i got from you? That board has F11 and F12 on it and the black on has num Lock and PrtSc in its place.
Offline MMB
Cherry G84-4100?
« Reply #4 on: Tue, 19 June 2012, 02:46:19 »
I never noticed it, honestly. Since it's the entire PCB you would be replacing, it doesn't matter anyways :)
But yeah, Cherry ML keycaps ... hard to find.
Offline IvanIvanovich
  • Mr. Silk Underwear
Cherry G84-4100?
« Reply #5 on: Tue, 19 June 2012, 07:25:40 »
Apparently SP does them. No idea how expensive they will be, but probably a lot.
