Author Topic: Recommend a 107 key keyboard?  (Read 3617 times)
Offline Godbless
« on: Tue, 19 June 2012, 13:50:45 »
Hi guys, this is a weird request, but basically I like using these 107 key keyboards where there is no gap between the "Up arrow" and "End" key. However, its hard to find a decent one as my cheap Ativa just broke.
This is a picture of what i mean:
http://www.newegg.com/Product/Product.aspx?Item=N82E16823201028
If there isn't anything out there I guess Ill just get this Rosewill or Gearhead one. I'm using it for gaming so I'm wondering if they'll be alright.
Offline JaccoW
  • Fire Typer!!
  • Keyboard is Lava!
« Reply #1 on: Tue, 19 June 2012, 15:12:00 »
Try again, the link was shortened
|||My other keyboards :
x
Offline Godbless
« Reply #2 on: Tue, 19 June 2012, 15:34:12 »
Ok, fixed link, thank you.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #3 on: Tue, 19 June 2012, 17:30:11 »
There really aren't many mechanical like that. Only I can think of off hand is HCL Diamond, but you would have to get it from India somehow. If you don't mind more keys and ISO maybe a Cherry G80-2551 or 8200, etc.
Offline Godbless
« Reply #4 on: Tue, 19 June 2012, 23:59:38 »
Thanks for your reply.  I'm kind of newb when it comes to keyboards.  Whats mechanical keyboard?  It doesn't have to be anything fancy, my budget is under $50.
Offline stingrae
« Reply #5 on: Wed, 20 June 2012, 07:54:38 »
Quote from: Godbless;617576
Lol good luck getting someone on here to recommend a keyboard under $70! :D that's where the magic happens!
Filco Ninja Tenkeyless  -Noppoo Choc MiniCm Storm Quickfire Rapid
Offline exousia7
« Reply #6 on: Wed, 20 June 2012, 09:06:25 »
Wow a mech keyboard for under $50?? I can only think of a membrane keyboard that "feels" like a mechanical keyboard but not a true mech keyboard @@ That's going to be really hard to find.
Offline Godbless
« Reply #7 on: Wed, 20 June 2012, 17:20:10 »
well it doesn't have to be mechanical... just something decent.
« Reply #8 on: Wed, 20 June 2012, 18:04:46 »
Well... there is ebay. G80-8200, make lower offer they will probably take it as it is close to your budget already.
