Author Topic: Looking for an image showing correct mounting of Apple M0116 RETURN key stabilizer  (Read 1159 times)
Offline signet
I pulled the L shaped return key to determine why it was sometimes binding unless struck on the RH edge of the key.  The centre of the stabilizer has a small plastic fitting which clips onto the wire.  The fitting is not damaged, and is securely locked onto the wire of the bar, I just need to see how it clips to its support as it currently just flops around.
