Author Topic: Northgate OmniKey Ultra keyboard  (Read 3553 times)
Offline wally6800
« on: Wed, 20 June 2012, 08:52:11 »
Hi,
I just found a Northgate Omnikey Ultra Keyboard packed away in a lot of old computer stuff I boxed up when I moved several years ago.
I would like to try using it again, but I need a cord to connect it to my computer.  I am a user and not a techie so I need help in locating a cable that will work.
Any help offered will be greatly appreciated.
Thanks in advance.
Wally6800
Offline Dwhangkhui
« Reply #1 on: Thu, 21 June 2012, 08:25:50 »
Hi Wally
First if your keyboard comes with a large connector cable you can just buy a Din 5 female to PS/2 male adapter
If you don't have a cable you can probably buy one at the northgate repair site.
You can find here a manual for using the keyboard
Good luck fitting it back into use.
Solidtek - 6600ABU
Offline r4pture
« Reply #2 on: Thu, 21 June 2012, 11:31:58 »
The plug to my Omnikey looks like a standard female PS/2 port.  Would a male/male PS/2 cable work for him?
[sigpic]http://geekhack.org/signaturepics/sigpic12085_2.gif[/sigpic]
~ Dell AT101W~ ~ ~ ~IBM Model M2~ ~ ~Northgate Omnikey 101 ~
