Author Topic: vim clutch  (Read 3448 times)
Offline hashbaz
  • Grand Ancient One
  • * Moderator Emeritus
vim clutch
« on: Thu, 21 June 2012, 17:06:10 »
Do want :D
VIM Clutch is a hardware pedal for improved text editing speed for users of the magnificent VIM text editor. When the pedal is pressed down, the pedal types "i" causing VIM to go into Insert Mode. When released, it types and you are back in Normal Mode.
https://github.com/alevchuk/vim-clutch
Offline sth
  • 2 girls 1 cuprubber
vim clutch
« Reply #1 on: Thu, 21 June 2012, 17:07:24 »
That would make vim+poker so much easier!
Offline Djuzuh
vim clutch
« Reply #2 on: Thu, 21 June 2012, 17:08:56 »
meh, it's great for esc, but I don't use i that often.
r, R, o, O, a, A, I are usually way more usefull.
Offline hashbaz
  • Grand Ancient One
vim clutch
« Reply #3 on: Thu, 21 June 2012, 17:11:35 »
Agree.  'a' is probably my most-used entry into insert mode.
Offline Djuzuh
vim clutch
« Reply #4 on: Thu, 21 June 2012, 17:16:38 »
Quote from: hashbaz;618942
Somebody edited his message :P
But I'll buy one to hook up to esc I thinkk
Offline digitalleftovers
vim clutch
« Reply #5 on: Thu, 21 June 2012, 18:00:45 »
Whether it would be useful to me or not, its a totally clever and awesome solution.
I want one too! Maybe just to launch new consoles.
Keyboards:
Filco 104 MX Brown (Otaku) - FKBN104M/NPEK 黒い空
Ducky TKL MX Brown/Blue 80% (White) - 1087-F 白の空
KBC Poker MX Red with PBT Key Caps - PFCN6000
"Consumers use touch screens.  Producers use keyboards."
Offline hashbaz
  • Grand Ancient One
vim clutch
« Reply #6 on: Thu, 21 June 2012, 18:45:37 »
Quote from: Djuzuh;618946
I edited it within seconds of posting it.  Misread the comment I was responding to.
Offline mkawa
  •  No Marketplace Access
  • (ツ)@@@. crankypants
vim clutch
« Reply #7 on: Thu, 21 June 2012, 23:33:35 »
personally, meh. vim is generally pretty conducive to foot pedals though, since it's modal, so cool regardless.
Offline kbafewx
vim clutch
« Reply #8 on: Sat, 23 June 2012, 03:56:15 »
wow that's a cool gadget... can you macro the pedal to do whatever you choose?
Offline mSSM
vim clutch
« Reply #9 on: Sat, 23 June 2012, 14:22:59 »
Quote from: sth;618936
It's pretty easy, if you use CTRL_[ ... That's actually faster to reach than Esc, if you ask me. :)
Or you remap Esc to be on left CTRL, and CTRL to be where CapsLock is. That one is useless anyhow, and it makes CTRL a lot easier to reach. And it's cool that you can karate-chop your Esc! That's what I do when I did something stupid in ViM, or when I successfully finished an annoying part. :D
Offline Trent
Re: vim clutch
« Reply #10 on: Sat, 04 August 2012, 12:42:44 »
I may buy one of these so I can program the foot pedal to a key like scroll lock or insert so I can use it for voice chat programs push to talk.
I tried to do the same thing with my griffin powermate but it will only emulate a single key press instead of an actual key press and depress.
Quote from: Trent
I hate fun
IBM Model M | IBM Model M SSK | FK-2000 | FK-8000 | FK-9000 | Fujitsu Peerless | Zenith Data Systems (Yellow ALPS!) | AEK
