Author Topic: dk1008 keycaps  (Read 2906 times)
Offline grave00
dk1008 keycaps
« on: Fri, 22 June 2012, 02:42:19 »
Is it easy to get something to replace keys on that model of Ducky?  I"ve never replaced keycaps before but the keycaps on my DAS and WASD are way better.  I thought maybe new keycaps might improve the typing experience on this one as I use it for work.  They're very loose and light.  Kinda like typing on hotels from Monopoly.
Offline IvanIvanovich
  • Mr. Silk Underwear
dk1008 keycaps
« Reply #1 on: Fri, 22 June 2012, 07:28:46 »
If you have the version that is normal ansi enter no problem, you have lots of choices. If you have the older version with the huge J return... well those are not as easy to find, will have limited option.
Offline grave00
dk1008 keycaps
« Reply #2 on: Fri, 22 June 2012, 15:08:51 »
No, it's a typical US layout.  Where would I look for replacements or how do I tell what is compatible?
I'm thinking of getting a cherry blue keyboard at some point but this isn't a bad keyboard at all.  It's grown on me much like the red cherry's have grown on me whereas at first I felt like I was going to drive my fingers right through the board.
dk1008 keycaps
« Reply #3 on: Fri, 22 June 2012, 18:11:11 »
Any aftermarket sets that say 'Filco compatible' you will be good to go. There are lots of sources here, elite e-sports, wasd, etc, etc... I would start in classifieds or the groupbuys sections. There are always a bunch of nice sets up at any time here. If you can't find what you are looking for you can branch out to taobao.
« Last Edit: Fri, 22 June 2012, 18:13:44 by lysol »
