Author Topic: Cherry MX switches led mounting  (Read 1912 times)
Offline Chris_F
« on: Fri, 22 June 2012, 19:01:25 »
Is it possible normally or through modification to mount a 4 pin rgb LED to Cherry MX switches? Keep in mind I'm asking about the switches themselves and not about a particular keyboard.
Q: The best keyboards ever made are from the early '80s and have buckling springs.
A: True
« Reply #1 on: Fri, 22 June 2012, 20:07:54 »
I'm no expert at modding but I can tell you that Cherry MX switches have a spot to mount LEDs and under the switch there are 4 little holds so I would assume yes is the answer to your question.
[ Attachment Invalid Or Does Not Exist ] 53720[/ATTACH]
[ Attachment Invalid Or Does Not Exist ] 53721[/ATTACH]
