Author Topic: Filco shifted pcb/case, keys too close to edge  (Read 1790 times)
Offline bavman
« on: Sat, 23 June 2012, 12:39:20 »
I have included pictures below as a reference to what I'm talking about as well as a video. The case and the key placement on my filco don't seem to line up perfectly causing the left side to be extremely close to the case and in some cases stops them from working correctly. However on the right side, I have plenty of room between the keys and the case. I don't run into any problems when using the stock caps or my cherry set, but When I use some SP keys, the shift always run into the problem as pushing against the case too hard and causing it to not be able to fully recover from a keystroke. This is easily demonstrated on mine particularly because its a filco with blues. The key will actuate the first time, but if you press it again you will notice there is no click because it has not come up fully from the previous press. I have even included a video to explain this problem better. Any one else have this issue or know how to fix it? I thought about sanding down the side of the key but I don't really want to ruin it, and I don't want it to show either that I sanded the key down
[ Attachment Invalid Or Does Not Exist ] 53767[/ATTACH] [ Attachment Invalid Or Does Not Exist ] 53768[/ATTACH] [ Attachment Invalid Or Does Not Exist ] 53769[/ATTACH] [ Attachment Invalid Or Does Not Exist ] 53770[/ATTACH] [ Attachment Invalid Or Does Not Exist ] 53771[/ATTACH]
[video=youtube;5fLV66DUnDM]http://www.youtube.com/watch?v=5fLV66DUnDM&feature=youtu.be[/video]
« Last Edit: Sat, 23 June 2012, 12:45:48 by bavman »
Offline thegunner100
  • (╯'□')╯︵</3 ノ( '-'ノ)
    • The Emotional Skyscraper
« Reply #1 on: Sat, 23 June 2012, 12:42:44 »
I had the same problem with my MJ1 using any SP keys. It's actually a pretty common problem, and I just used a nail filer to file off just enough for the left sided keys to work properly. You wont ever see that the key has been modified if the key is on the keyboard.
Input Devices:CM QF Rapidx2 ~ REALFORCE 87uw 45/55g ~ Logitech G5v2 ~ Wacom Bamboo CTH-460
Audio Setup: look me up on head-fi
Check out my blog on touhou/doujin music, audiophile gear, and doujin games!
Offline bavman
« Reply #2 on: Sat, 23 June 2012, 12:45:22 »
Hmm. Its weird because the caps and control are both SP made yet they both have no problem at all.
« Reply #3 on: Sat, 23 June 2012, 12:47:45 »
Quote from: bavman;620312
For me, it was the ctrl and shift keys from hashbaz's rgby and the rag set that were having problems.
Offline bavman
« Reply #4 on: Sat, 23 June 2012, 12:52:22 »
Darn, we'll I'll try a nail file when I'm able and see what will happen.
Offline mkawa
  •  No Marketplace Access
  • (ツ)@@@. crankypants
« Reply #5 on: Sun, 24 June 2012, 01:24:06 »
tolerances on SP's molded keys and filco case clearance often seem to line up in bad ways. a little bit of filing on the key edge usually fixes it right up
