Author Topic: buying keycaps  (Read 3036 times)
Offline mellohello
buying keycaps
« on: Mon, 25 June 2012, 17:33:48 »
so i bought a cm storm quickfire a week ago and the wasd keys are already wearing out (the paint is nearly all gone). does anyone in the have any suggestions for where to get pbt keycaps for the uk quickfire, i'm thinking blank ones, or ones where the paint doesn't come off at all?
thanks
Offline i3oilermaker
  • techkeys.us
    • TechKeys
buying keycaps
« Reply #1 on: Mon, 25 June 2012, 17:35:57 »
Offline mellohello
buying keycaps
« Reply #2 on: Mon, 25 June 2012, 19:54:01 »
thanks for the suggestion, but i should have mentioned my preference is white or black keys ^^.
by the way, my keys are laser etched with paint filling, is it normal for the paint to come off after less than a week of use? i've honestly never had the paint come off a key so quickly
