Author Topic: Salvaging switches from a plate mount  (Read 1646 times)
Offline braaaiiins
« on: Thu, 19 July 2012, 21:41:27 »
I'm trying to salvage some  switches from an old cherry mx black board that is plate mounted. Do I have to desolder EVERYTHING even if only want a few switches?? This is a really noobie question, I know, but I couldn't find much info on how to salvage these things! Please help =)
Offline WRXChris
Re: Salvaging switches from a plate mount
« Reply #1 on: Thu, 19 July 2012, 22:20:22 »
you only have to desolder the switches you want (and any LEDs and/or diodes if they are installed in the switches).  Once desoldered, on the top side of the switch where it mounts to the plate, there are 2 tabs centered on the top and bottom edge of the switch that you press to dislodge it from the plate.
EDIT: and if there are diodes or LEDs, it may be easier to just clip them off rather than desoldering, unless you want to save them.
« Last Edit: Thu, 19 July 2012, 22:22:01 by WRXChris »
Offline braaaiiins
« Reply #2 on: Thu, 19 July 2012, 23:06:19 »
Thanks a lot! I got them off =)
