Author Topic: Remapping Fn key on Camo Filco  (Read 3977 times)
Offline Mugen
  • O-Rings are the murderers of keyboard souls
« on: Fri, 20 July 2012, 09:19:00 »
Hey,
Does anybody know how to remap the Fn key on a Camo Filco? i've tried most softwares but they dont even recognize the key :\
Thanks.
Offline Igthorn
Re: Remapping Fn key on Camo Filco
« Reply #1 on: Fri, 20 July 2012, 10:51:27 »
I don't think it's possible.  It's a key that doesn't send any scan codes, it just gives access to a different layer on the keyboard.
Offline alaricljs
  • I be WOT'ing all day...
« Reply #2 on: Fri, 20 July 2012, 11:25:57 »
I can confirm that Igthorn is correct.  The only way to remap that key would be to modify the board/controller itself.
Filco w/ Imsto thick PBT
Offline aesthetics1
« Reply #3 on: Fri, 20 July 2012, 11:30:45 »
It isn't possible to remap *only* the FN key. I've read that you can remap FN key + the media/sleep keys on the keyboard. You can for example remap the FN + F1 key from Mute to another function with AutoHotKey. You would just reassign mute for example to another function/macro.
This is why I didn't pick up the camo board ;( haha.
Home: Filco Majestouch TKL MX Red | Work: Ducky Shining (Blue LED) MX Black | Collection: CM Quickfire Rapid MX Red
Offline xyril
    • Youtube Channel (full of typing and gaming vods)
« Reply #4 on: Fri, 20 July 2012, 22:24:45 »
Hey hows your Camo Filco Quality :D? Im getting one of those, since its pretty much keep all the media keys ;)
Offline Mugen
« Reply #5 on: Sat, 21 July 2012, 09:07:41 »
the Fn key is really annoying. i didn't think about it when i bought it, if i was buying one today i would buy a different model.
Aside from the Fn key the keyboard is amazing, quality top notch.
Thanks for the response guys.
