Author Topic: It's in the mail...  (Read 3177346 times)
Offline Travellerr
Re: It's in the mail...
« Reply #2700 on: Mon, 25 November 2013, 19:20:32 »
I was actually considering buying one of the leopold fc660m keyboards. Is the quality of the board relatively good? If anyone knows the keyboard is  good quality and comfortable to use I would appreciate them getting back to me because I am about to pull the trigger and buy one of these.  ;D so please respond with so feedback  :thumb:
Leopold FC660C- Realforce 87u 55g- QFR mx Blues
Offline Pacifist
  • on hiatus
« Reply #2701 on: Mon, 25 November 2013, 19:26:52 »
Is that the topre version?
« Reply #2702 on: Mon, 25 November 2013, 19:29:17 »
Custom Zipper Pouch from Etsy to hold special keycaps :)
3x5 (15 keys) metal bracket to hold switches for my own switch tester/ keycap display
 ;D
« Reply #2703 on: Mon, 25 November 2013, 19:29:18 »
No. Topre is fc660c
 ;D
Interesting!
Offline VesperSAINT
  • vpsert
  • #CustomKorean
« Reply #2704 on: Mon, 25 November 2013, 19:29:22 »
Leopold is a great company, and I've only heard good things about the FC 660M, other than the pad printing on the keycaps. Another concern may have to do with the spacebar stem placement, as they are not usually compatible with other spacebars. You'd have to get a universal spacebar to fit that. Other than that, you will get an awesome sturdy keyboard with top of the class construction. I own the 660C, which has amazing construction, and the outside construction seems near identical to the M.
Offline BakaPhoenix
« Reply #2705 on: Tue, 26 November 2013, 07:23:57 »
I'm waiting for my ducky shine 3 tkl with cherry mx blue and white led :D
Offline Jixr
« Reply #2706 on: Tue, 26 November 2013, 15:16:21 »
Just another set of white pbt front printed keycaps from qtan for me!
Offline Awful
  • Don't Topre.
« Reply #2707 on: Wed, 27 November 2013, 13:12:44 »
White HHKB (with blanks) and a set of blank black keys. I'm going to have a permanent boner until Christmas when I actually get to use it -_-
I hate everything.
Offline Lastpilot
  • Power stance
« Reply #2708 on: Fri, 29 November 2013, 08:58:53 »
New computer! Just ordered :D
*BASE_PRICE: [+895]
BLUETOOTH: None
CAS: Corsair Carbide AIR 540 w/ USB 3.0, Dual Chamber Direct Airflow, Full Side Panel Window [+114]
CASUPGRADE: None
CD: 24X Double Layer Dual Format DVD+-R/+-RW + CD-R/RW Drive (BLACK COLOR)
CD2: None
COOLANT: Standard Coolant
CPU: AMD FX-8350 4.00 GHz Eight-Core AM3+ CPU 8MB L2 Cache & Turbo Core Technology [+34]
CS_FAN: Maximum 120MM Color Case Cooling Fans for your selected case [+15] (White Color [+0])
ENGRAVING: None
FA_HDD: None
FAN: Corsair Hydro Series H60 High Performance Liquid Cooling System 120MM Radiator & Fan [-7] (Dual Enermax Enlobal Silent High Performance 120MM Fans (Push-Pull) [+45])
FLASHMEDIA: None
FREEBIE_MB: FREE! 802.11n WiFi USB Adapter [+0]
FREEBIE_VC1: Batman Arkham Origins + Assassin's Creed Black Flag + Tom Clancy's Splinter Cell: Blacklist Game Coupon [+0]
FREEBIE_VC2: None
HDD: 2TB (2TBx1) SATA-III 6.0Gb/s 64MB Cache 7200RPM HDD (Single Drive)
HDD2: None
HEADSET: ZALMAN ZM-HPS200 GAMING HEADSET [+0]
IUSB: Built-in USB 2.0 Ports
KEYBOARD: (Keyboard & Mouse Combo) Cooler Master Storm Devastator Gaming Keyboard & Mouse Combo [+0]
MEMORY: 16GB (8GBx2) DDR3/1866MHz Dual Channel Memory (ADATA XPG V2)
MONITOR: None
MONITOR2: None
MONITOR3: None
MOTHERBOARD: GIGABYTE 970A-DS3P AMD 970 ATX w/ Ultra Durable 4 Classic, On/Off Charge, GbLAN, 2 PCIe x16, 3 PCIe x1, 2 PCI
MOUSE: None [+0]
NETWORK: Onboard Gigabit LAN Network
OS: Microsoft(R) Windows 8.1 (64-bit Edition) + Office 365 FREE 30 Days Trial
OVERCLOCK: No Overclocking
POWERSUPPLY: 750 Watts - Corsair RM750 80 PLUS GOLD Certified Fully Modular Ultra Quiet Power Supply [+65]
RUSH: NO; READY TO SHIP IN 5~10 BUSINESS DAYS
SERVICE: STANDARD WARRANTY: 3-YEAR LIMITED WARRANTY PLUS LIFE-TIME TECHNICAL SUPPORT
SOUND: HIGH DEFINITION ON-BOARD 7.1 AUDIO
SPEAKERS: None
TEMP: None
TVRC: None
USBFLASH: None
USBHD: None
USBX: None
VIDEO: NVIDIA GeForce GTX 770 2GB GDDR5 16X PCIe 3.0 Video Card [+181] (Major Brand Powered by NVIDIA)
VIDEO2: None
VIDEO3: None
WNC: None
_PRICE: (+1342)
_view_: {0B6F9FB3-F5E7-4FF7-9C98-D8B7DEB69F2F}
_load_: 11/28/2013 10:52:43 PM
                                                   SUBTOTAL  $1,342.00
                                            Sales Tax (N/A)      $0.00
                                       Shipping: UPS Ground     $75.00
                                          Shipping Discount    $-75.00
                                                GRAND TOTAL  $1,342.00
Offline davkol
  •  Post Editing Timeout
« Reply #2709 on: Fri, 29 November 2013, 11:51:01 »
Another 20" 4:3 LCD.
I wish Intel HD supported triple-head through digital outputs. It really bothers me, because both AMD and nVidia have awful drivers, I don't care about GPU performance, and the cheapest graphic card, that supports triple head, appears to be €50 Sapphire HD6450 FLEX with only 2-year warranty (nearly every other card has one extra year).
Offline Av180
« Reply #2710 on: Fri, 29 November 2013, 15:34:06 »
White Poker 2
Thick black legends on white/beige imsto pbt dyesubs
few dipped caps
Mellow Yellow usb cable :>
excited
KMAC 62g Clear
Poker 2 Stock Red
Leopold FC200RE Stock Clear
Offline BucklingSpring
« Reply #2711 on: Fri, 29 November 2013, 19:09:23 »
Mailman dropped this at my door yesterday.
The seller didn't package it properly. Keyboard box was inserted in a plastic envelope with no protection. This thing got bounced around badly. Box was punched, crushed and all corners rounded. I didn't have much hope when I opened it but... Miracle, all keys work fine (for now)
46263-0
If anyone wonders, I have a kooking mat under the board to keep it in place.
Not really needed for the KBT because it comes with big nice rubber feet.
« Last Edit: Fri, 29 November 2013, 19:11:32 by BucklingSpring »
Boards I own, click ->
« Reply #2712 on: Fri, 29 November 2013, 19:16:33 »
8 Pantone 210 C Cranium
Offline Dubsgalore
« Reply #2713 on: Sat, 30 November 2013, 12:55:22 »
LZCE
Offline Photoelectric
« Reply #2714 on: Sun, 01 December 2013, 18:29:01 »
  • Canon 500D macro lens
  • Dolica AX620B100 Professional Tripod
  • Red office chair
  • Hakko 888D
  • A pair of specialized tweezers for soldering and other tasks
  • LED pin housings for solderless LEDs
Hopefully haven't forgotten anything.  Also realized that I can actually fine-tune white balance on my camera rather than use presets...  Really a facepalm moment--I should have known that long ago.  Can finally have better color accuracy.
« Last Edit: Sun, 01 December 2013, 18:31:42 by Photoelectric »
Offline Pacifist
  • on hiatus
« Reply #2715 on: Sun, 01 December 2013, 18:30:28 »
Stuff from John's sale, most excited for my beast tools to finish modding my 11900. Using a binder clip took forever and barely worked
Offline do_Og@n
« Reply #2716 on: Sun, 01 December 2013, 19:03:42 »
  • Red office chair
  • Hakko 888D
Christmas is coming early huh?
To bad you use a canon though. ;)
« Reply #2717 on: Sun, 01 December 2013, 20:07:20 »
I use a Panasonic :)  Also I don't normally get stuff for winter holidays so... it works out.  Better to buy stuff I need on Black Friday deals than stuff I don't need for other occasions.
Offline bueller
  • MX baller
  • Church of the Ergo Clear
« Reply #2718 on: Sun, 01 December 2013, 20:14:36 »
  • Red office chair
  • Hakko 888D
If you want the best color accuracy just shoot RAW and leave it on Auto, then you can go and fine tine the WB after the fact :)
It's the one thing I miss about selling off all my camera equipment, my Nexus 4 can NEVER get the WB right.
« Reply #2719 on: Sun, 01 December 2013, 20:15:57 »
I would if I could.  Only JPEG on this camera :(  Still, it was a real bargain when I got it, so I make do.  But I plan on getting a new one next year.  Was going to be this year but didn't see any good deals on something that would be a dramatic upgrade.  It's okay though, now that my stupid omission of white balance fine-tuning has been remedied, photos should come out better (I was cycling through preset white balance settings, of which there are a lot, but indoors, none are quite right, so manually tweaking the white balance colors is great now).
« Last Edit: Sun, 01 December 2013, 20:17:41 by Photoelectric »
Offline neunelfer
  • HHKB Pro
« Reply #2720 on: Sun, 01 December 2013, 21:21:25 »
Apple TV for my dad.
« Last Edit: Mon, 02 December 2013, 08:32:43 by neunelfer »
Offline do_Og@n
« Reply #2721 on: Mon, 02 December 2013, 00:10:56 »
Some cameras will let you balance the white levels by taking a photo of a blank sheet of white paper in the light element your shooting in it should balance your white levels.
Offline 1pq
  • Hipster Doofus
« Reply #2722 on: Mon, 02 December 2013, 00:48:10 »
Always better to shoot in RAW so you can adjust later, though. Plus, lossless edits are nice :D
main kbs:  87UB (55g)  Custom Filco TKL (62g clears)
WTS JD40, Custom Ergoclear Filco
WTB ROHS Red BBv2 (Topre), OG EK Tri-Color Skull (TOPRE)
« Reply #2723 on: Mon, 02 December 2013, 01:15:05 »
You quoted the post where it says directly that there's no RAW format possible!  In either case, I'm good now with manual white balance settings.  And I always do post-processing later anyway to make sure all the colors look proper.  But starting out with good white balance is important.
« Reply #2724 on: Mon, 02 December 2013, 03:26:45 »
Some various keycaps from a couple of recent sales.
Some other stuff that I've forgotten about.
Tai Hao.
Offline BliTzKiN
« Reply #2725 on: Mon, 02 December 2013, 10:41:14 »
Tracking says my ergodox kit just arrived in my country :D
Offline Mr. C
« Reply #2726 on: Mon, 02 December 2013, 11:04:35 »
I just ordered a Black RealForce 87U 55g. Needs to be my last keyboard purchase for a while (yeah right). I plan to swap out the white and grey keys from my RealForce White 87U 45g. I will then probably silence mod the 45g. I hope this RealForce 55g is the one keyboard to rule them all.
Offline ideus
  • Björkö.
« Reply #2727 on: Mon, 02 December 2013, 11:07:49 »
How do you feel the small shift key in the right side?
Offline ideus
  • Björkö.
« Reply #2728 on: Mon, 02 December 2013, 11:10:23 »
What difference do you notice in the feel of the sphericals compare with regulars keys?
R4 SPH set from komar007:
Photo Credit: komar007
Model M 1390131:
Photo Credit: eBay seller inovativecreations
Diatec Tall Sphericals (SA-profile from Signature plastics):
Photo Credit: diatec.com
Purchased using tenso.com buyer service.
Offline Candyflip
« Reply #2729 on: Mon, 02 December 2013, 16:13:54 »
Even tho I haven't tried topre I think I would like it + the TKL factor just make the perfect keyboard, only missing is maybe alu body?
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #2730 on: Mon, 02 December 2013, 16:24:31 »
Not in the mail but going to pick up my steel for my Brushed Behemoth project tomorrow from the shop.  I am getting an 18"x18"x1/2" and a 18"x8"x1/4" piece of 304 stainless for $50.  Only reason I am getting this kind of a deal is because they had a large project come in using stainless and I am just getting a couple drops from behind the shear.
Offline missalaire
  • Great Finder of Great Finds
« Reply #2731 on: Mon, 02 December 2013, 17:19:41 »
Astro A40 Audio System (White)
Black N7 Elite Armour Stripe Hoody
Na'Vi MLG t-shirt
IGN IPL Pro League t-shirt
GNC Pro Performance AMP Creatine 189
GNC Membership card
I love my credit card <3
« Last Edit: Wed, 04 December 2013, 14:26:05 by missalaire »
Offline Candyflip
« Reply #2732 on: Mon, 02 December 2013, 17:27:36 »
Na'Vi MLG t-shirt
GNC Membership card
that NaVi shirt <3
Offline missalaire
« Reply #2733 on: Mon, 02 December 2013, 17:32:59 »
Na'Vi MLG t-shirt
GNC Membership card
that NaVi shirt <3
I know, its so sexy.
http://mlgproshop.com/product.php?id_product=113
Offline phatdood9
« Reply #2734 on: Mon, 02 December 2013, 18:20:23 »
Got a hhkb and some blank pink caps from ek!
Couldn't resist :D
Offline Pacifist
  • on hiatus
« Reply #2735 on: Mon, 02 December 2013, 18:21:16 »
110 clears and a quiet matias switch from mk.com
Offline Linkbane
« Reply #2736 on: Mon, 02 December 2013, 22:05:38 »
Some Klipsch earbuds (headphones are falling apart), and my TKL Shine 3 Yellow with Blues and blank caps!
Also hopefully a few Clear switches from spamray.  :cool:
Quickfire TK MX Blue Corsair K60 MX Red Ducky Shine 3 Yellow TKL MX Blue Leopold FC660C
Current best: 162 wpm.
« Reply #2737 on: Mon, 02 December 2013, 22:39:57 »
soonish.....got stuck taking my kid to dance class tonight
Offline Linkbane
« Reply #2738 on: Mon, 02 December 2013, 22:40:36 »
High society, that is.  ;)
« Reply #2739 on: Mon, 02 December 2013, 22:44:29 »
For some reason, I picture your kid dancing like one of these:
Offline terran5992
  • One With The Cup Rubber
« Reply #2740 on: Mon, 02 December 2013, 22:47:39 »
Is it 1980 again?
« Reply #2741 on: Mon, 02 December 2013, 22:47:50 »
haha far from it....believe me...
and nubs that's not so far from the truth!
« Reply #2742 on: Mon, 02 December 2013, 22:53:43 »
Is it 1980 again?
Yes, though I blame the 1980s ness on the lack of good videos of those dances anywhere.
I knew it!
Offline riotonthebay
  • Cherry Peasant
  • keycult.com
« Reply #2743 on: Mon, 02 December 2013, 22:54:01 »
110 clears and a bag of springs from blues. Ergo clears inc.
White blank PBT caps.
Soon: 5 custom dyesubs.
« Reply #2744 on: Mon, 02 December 2013, 23:06:26 »
You got lube right?  Cause you're gonna want lube.
Offline pichu23
  • ୧༼ಠ益ಠ༽୨ FITE ME
  • ʕ ͡·ᴥ ͡· ʔ
« Reply #2745 on: Mon, 02 December 2013, 23:23:10 »
may i ask where did you get the clears from ? 7bit from DT ?
Offline stancato9
« Reply #2746 on: Mon, 02 December 2013, 23:40:54 »
Probably mechanicalkeyboards.com
Poker 2 - MX Red
Offline pichu23
  • ୧༼ಠ益ಠ༽୨ FITE ME
  • ʕ ͡·ᴥ ͡· ʔ
« Reply #2747 on: Mon, 02 December 2013, 23:59:55 »
oohh. thanks. just ordered some switches :)
Offline Pacifist
  • on hiatus
« Reply #2748 on: Tue, 03 December 2013, 00:07:55 »
did you use the mkbfcm code to get 10% off?
Offline pichu23
  • ୧༼ಠ益ಠ༽୨ FITE ME
  • ʕ ͡·ᴥ ͡· ʔ
« Reply #2749 on: Tue, 03 December 2013, 00:09:41 »
it didn't work for some reason. lol.  ;D
