Author Topic: Weird stabilizers on my Filco.  (Read 3397 times)
Offline krat3z3
« on: Sat, 21 July 2012, 09:37:32 »
Hi, I have received my new Filco keyboard few days ago. The feel of cherry blue is great, I am glad that I picked up this one. Everything seems and feels amazing except stabilizers. Left shift, right shift and enter work quite strage. For example: when I press down left shift from side "Z" letter, especially top corner the key is stiffer then when I press shift on the middle or outside. Right shift, enter work similiar so they are stiffer from the inside too. However spacebar and backspace work perfectly fine. I imposed grease already, anywere stabilizers moves so bottom and white hold are greased now but it didn't help at all. If everything is greased and work kind of smooth why does it behave like that?
It start to be annoying, I commonly type two capital letters instead one. May it be fault of cherry switch, isn't it strage it happends on the widest stabilized keys?
Sorry for my broken english but please answer if you had experience with this or you know how to fix it. Thanks
Offline thegunner100
  • (╯'□')╯︵</3 ノ( '-'ノ)
    • The Emotional Skyscraper
Re: Weird stabilizers on my Filco.
« Reply #1 on: Sat, 21 July 2012, 10:16:00 »
Pics would help.
Input Devices:CM QF Rapidx2 ~ REALFORCE 87uw 45/55g ~ Logitech G5v2 ~ Wacom Bamboo CTH-460
Audio Setup: look me up on head-fi
Check out my blog on touhou/doujin music, audiophile gear, and doujin games!
Offline Djuzuh
« Reply #2 on: Sat, 21 July 2012, 10:33:05 »
Remove the keycap if you have a decent tool to do so, and look if everything is alright.
Mine for example had a leg broken.
And post pics, lots of pics.
Offline krat3z3
« Reply #3 on: Sat, 21 July 2012, 14:30:58 »
http://imgur.com/a/9h8Vj
For me those keycaps (cross sticking with switch) are skew, except backspace which work good. Do you agree with me or skew like this is normal?
Offline Lethal Squirrel
  • I <3 60%
« Reply #4 on: Sat, 21 July 2012, 19:22:13 »
I honestly could't tell there was anything wrong. :(
Offline SerenadedAbyss
    • Orezaku
« Reply #5 on: Sat, 21 July 2012, 23:29:48 »
It looks like you had the grease on really heavy. But anyway, re-seat the keys and make sure that they are straight. No key should have an angle.
« Last Edit: Sat, 21 July 2012, 23:44:50 by SerenadedAbyss »
-/ Rosewill RK-9000BR - Leopold CODE VB2 TKL BROWN \-
« Reply #6 on: Sat, 21 July 2012, 23:45:00 »
The L shift and enter stems look a little skewed.... but im not too sure on that. Otherwise, they look like they should fit just fine.
Offline krat3z3
« Reply #7 on: Sun, 22 July 2012, 04:24:43 »
Right, from the start stabilizers looked good to me as well. I was looking for reason why it is siffer on the side. Read some and decided to lube stabilizers but it didn't help at all. What about keycaps, they seem to me like twisted (except R4 backspace, which one work fine). Maybe when it isn't perfectly straight and I press down the key it try to turn and stabilizer holds it, then press become harder. That make sense to me, what do you think?
« Reply #8 on: Sun, 22 July 2012, 08:20:41 »
Only way to test, aside from just looking at it, is to use another set of keycaps if you have one. Have you tried taking the surrounding keys out and then pressing the stiff keys?
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #9 on: Sun, 22 July 2012, 10:35:13 »
try popping the stabilizer bar out of the clips with your finger nail, tweezers, etc.........clean everything off, apply just a smidge of lube to stabilizer bar and reinstall. is there a piece of obscure plastic, trash in the "clip" resticting it? if the bar is rough just run some sandpaper over it.
thats a lot of greace you got in there.
if the stabilizer bar is not fully seated it will be stiff on that side
like gunner said try or swap out another keycap
Luga G80-1865/MX Reds + Dolch G80-1813/MX Blues + G80-3700HQAUS + DK9008G2 Pro/MX Browns Thick PBT + DK9008G2 Pro/MX Clears Thick PBT +  QFR TKL/Ghetto Greens + Cherry G80-1800/MX Blues + IBM Model M SSK Bolt Modded + IBM Model M + IBM Model F + IBM AT F + Cherry G80-1000 (HAD)/MX Vintage Blacks + Razer BWU/MX Blues + Leading Edge DC2214/Blue Alps + Compaq MX11800/Browns + Chicony 5181/Monterey Blues + Chicony 5161/MX Black Cherry Clone + Focus 2001/White Alps + Chicony 5191/White Futabas + Olivetti ANK27-101 + Dell (Old Logo) AT101/Black Alps + NMB RT8255C+/Black Space Invaders + Unitek K260/Green Alps + Apple M0116/Orange Alps + AEK II M3501/Cream Alps + AEK M0115/Orange Alps + NEC  APC412/Blue Sliders + NEC APC410/Blue Sliders + Omnikey /White Alps + Wang/Yellow Alps (Omrons) + Laser/White SMK + Fame/Blue Aruz + AEK II M3501/Salmon Alps + Zenith ZKB-2R/Green Alps + Wang 724/Orange Alps + DK1087/Green Alps + Zenith ZKB-2/Yellow Alps + Dell Old Logo AT101/Salmon-Pink Alps + Leading Edge AK1012/White SMK's + Magitronic SK-1030/White (Linear) Futaba's + Packard Bell/White (Clicky) Futaba's + Datacomp DFK101/White  Alps + SGI AT101/Dampened White Alps + NMB AQ6RT-72511/Grey Space Invaders (Hi-Tek) + Datacomp/Blue Alps + Phillips 2812/White Space Invaders (Linear) + Dah Yang K251/Vintage MX Blues + Chicony 5161/DS Caps/Vintage MX Blue + Archie-NMB AQ659ZRT-725/Black Space Invader (Tactile) + IBM Model M 71G4644 (RD) Bolt Modded with Soarers Converter + IBM Model M Silver Label 1390131 + Cherry G80-1501/Vintage MX Clears + Focus FK8000/Linear Futabas + Gateway 2000 Anykey Programmable/Maxi-Switch + Dell GY13PVAT101/Dye Sub Caps/Salmon Alps + Chicony 5161/White Alps + AST K0B101/Slider over RD + Qtronix QX-32H + Everex/NMB RT8255CW+ Black Space Invaders-Split Erase + Tandon/NMB AQ659ZRT-101A/Beige Space Invaders + Cherry G80-11903 MNRUS/MX Blacks + Apple IIGS A9M0330/SMK Whites + WYSE PCE/MX Blacks + Chicony 5160AXT/Clicky Futaba + Cherry G80-0528/Vintage MX Blacks + Dell AT101/Linear (Modded) Black Alps+Topre 55g
Offline krat3z3
« Reply #10 on: Sun, 22 July 2012, 11:21:15 »
I have not any extra keycaps. May I swap enter with shift? Size is the same right?
ps. Do you really think that keycaps are ok?
« Last Edit: Sun, 22 July 2012, 11:24:45 by krat3z3 »
« Reply #11 on: Sun, 22 July 2012, 11:28:45 »
They're the same size, but different profile. It's worth a try I suppose.
Offline krat3z3
« Reply #12 on: Sun, 22 July 2012, 13:42:18 »
Solution:
I almost gave up, that was my last idea. Last but successful, I pull out keycap and underneath are two white legs. I pulled out this one closer to stiffer side for like 0,5mm and everything work great now! If you read this because you have the same problem be careful if you pull out this for more then 1mm stiff may change side. Summarizing white legs are very important and when they are not in the perfect position feel may not be perfect.
« Last Edit: Sun, 22 July 2012, 13:44:14 by krat3z3 »
« Reply #13 on: Sun, 22 July 2012, 14:01:17 »
I'm glad you found a solution! Never would have thought that pulling out the costar stabilizer tab would help, since they're usually supposed to be in all the way.
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #14 on: Sun, 22 July 2012, 19:11:18 »
good job.....
Offline touchtype
« Reply #15 on: Mon, 23 July 2012, 01:17:09 »
