Author Topic: What did you get in the mail today?  (Read 25573366 times)
0 Members and 16 Guests are viewing this topic.
Offline iamtootallforthis
  • Something a lot Funnier
  • I like green stuffs.
    • WTB/WTTF Thread
« Reply #33150 on: Mon, 08 June 2015, 21:11:36 »
Because Youtube videos are super****ed right now on here
How I'm feeling right now:
**** YEAH! Look forward to seeing pictures!
Offline PunksDead
  • hspernks
  • keyboard poser
« Reply #33151 on: Tue, 09 June 2015, 00:15:34 »
Powder blue v2 set :D
Offline byker
  • Literally Canada
« Reply #33152 on: Tue, 09 June 2015, 00:18:18 »
Looks like it matches the modifiers pretty well!  :)
Offline PunksDead
  • hspernks
  • keyboard poser
« Reply #33153 on: Tue, 09 June 2015, 00:21:10 »
Im really feeling the powder colors
Im going to end up swapping back to stock grey mods since they go so well with the soft colors.
Addicted to bro sets
« Reply #33154 on: Tue, 09 June 2015, 00:23:22 »
You go well with my... drapes you daft man.
Offline R1N3
« Reply #33155 on: Tue, 09 June 2015, 00:24:05 »
mods bro set when?
Offline trizkut
« Reply #33156 on: Tue, 09 June 2015, 00:24:23 »
Weather me some mods, PD!
The board looks great
Offline Sed8op8
  • Keyboard Padawan
« Reply #33157 on: Tue, 09 June 2015, 03:58:52 »
sexy as hell..... :thumb:
Offline baldgye
  • Will Smith Disciple
« Reply #33158 on: Tue, 09 June 2015, 04:21:49 »
I love LOVE your board
Offline azhdar
  • Praise the AZERTY god
« Reply #33159 on: Tue, 09 June 2015, 04:25:03 »
http://www.ebay.com/itm/281476427201?afsrc=1&rmvSB=true&afsrc=1&rmvSB=true
Plug and play a remapping on the G80-5000.
I picked one of these up from Orihalcon like a month ago for my F AT, loving it! Great converter, and really simple to program.
Yeah, that thing is amazing, the mx5000 was only bugging me because I missed a few bind and the non plug'n play, now it is perfect.
Azerty Propagandiste
Offline beehatch
  • baehatch
« Reply #33160 on: Tue, 09 June 2015, 06:25:22 »
I've always loved this board of yours. I wish I could make some modifiers like that :P
    • WTB/WTTF Thread
« Reply #33161 on: Tue, 09 June 2015, 06:34:07 »
Lovely board!
Offline billnye
  • ability man
« Reply #33162 on: Tue, 09 June 2015, 07:17:17 »
Offline Jokrik
« Reply #33163 on: Tue, 09 June 2015, 07:39:08 »
Sorry to keep star wars crapping :( :( but I can't hold myself to this one
Offline beehatch
  • baehatch
« Reply #33164 on: Tue, 09 June 2015, 07:45:27 »
I like the nips.
Offline Jokrik
« Reply #33165 on: Tue, 09 June 2015, 07:48:59 »
I like the nips.
I knew you would....  :confused:
this one isn't hairy though, dont you like it hairy?
Offline greath
  • A waffle is like a pancake with a syrup trap.
« Reply #33166 on: Tue, 09 June 2015, 07:54:38 »
1800 Leeku PCB + plate. Kin's shipping took 3 days from Korea...  :eek:
As a side note. The resistors/diodes I'm going to have to solder are the size of fleas. Looks like I have to buy an Optivisor now to put this together.
Offline sethk_
  • Grand Master Wizard Pizza
  • www.kbdhub.com
    • My webstore
« Reply #33167 on: Tue, 09 June 2015, 08:14:38 »
What solder setup are you using? I soldered mine on with this: http://www.ebay.com/itm/271171818538?_trksid=p2060353.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT on my Hakko FX888D, and it did the job. They are really easy if you have tweezers and the proper sized tip.
Offline beehatch
  • baehatch
« Reply #33168 on: Tue, 09 June 2015, 08:18:50 »
I like the nips.
I do like my dudes fuzzy. No hair is just as good though, I don't judge. I still like them nips.
Offline greath
« Reply #33169 on: Tue, 09 June 2015, 08:19:42 »
An Edysn 951sxe. The standard ("medium") tip. Mkawa was saying it should be a good tip for the small SMD soldering. I've just never done SMD soldering before and I'm nervous.
Offline greath
« Reply #33170 on: Tue, 09 June 2015, 08:24:44 »
I like the nips.
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #33171 on: Tue, 09 June 2015, 08:24:57 »
I never did before either, and I thought it would be really hard, but if you take your time you should get the hang of it fast. What I did was put solder on the SMD pads, get the component in tweezers, hold it on the cold solder joints, and then heat up one side, and then onto the next side. Then it should be set in place.
Offline beehatch
  • baehatch
« Reply #33172 on: Tue, 09 June 2015, 08:26:15 »
I like the nips.
That's too fuzzy. I can take a hairy ass, but not a super hairy back.
Offline greath
« Reply #33173 on: Tue, 09 June 2015, 08:28:50 »
Thanks for the tips :)
I'm planning on buying and optivisor for the job to reduce eye strain if nothing else. Nervously excited but not going to start until next week.
BTW: The sip sockets I got from kin don't have any plastic to separate them. Do you think this will be a problem?
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #33174 on: Tue, 09 June 2015, 08:43:44 »
You actually need to take the SIP sockets out of the plastic when using them in the switches. I left the plastic on for the CSN LEDs, but that is all. I can take some pictures.
Offline greath
« Reply #33175 on: Tue, 09 June 2015, 08:47:06 »
That's fine then. I was just worried that they might touch and short something without the plastic.
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #33176 on: Tue, 09 June 2015, 08:49:41 »
Nope! When you are about to solder them in though, make sure you have an LED in them so they are properly aligned though.
Offline Evo_Spec
  • (╯°ヮ°)╯︵⌨
« Reply #33177 on: Tue, 09 June 2015, 10:57:37 »
noooo, don't cut them out!!!! those 3 sets of SIP sockets are for the indicator lights! keep them in the plastic and just solder them onto the PCB!!!
If these are SIP sockets that are going into switches than yeah, cut them out of the plastic.
Edit: this right? https://geekhack.org/index.php?topic=68443.msg1742665#msg1742665
Yeah DON'T cut those out, Kin know's what he's doing and that's why he left them in the plastic.
« Last Edit: Tue, 09 June 2015, 10:59:14 by Evo_Spec »
GON NerD TKL DTA Edition
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #33178 on: Tue, 09 June 2015, 10:58:41 »
All of his are separated AFAIK
Offline HPE1000
  • Keycap Paparazzo
« Reply #33179 on: Tue, 09 June 2015, 10:59:13 »
Awesome picture :)
Offline Evo_Spec
  • (╯°ヮ°)╯︵⌨
« Reply #33180 on: Tue, 09 June 2015, 11:01:31 »
Check my edit, you'll understand.
https://geekhack.org/index.php?topic=33130.msg1773226#msg1773226
Offline greath
« Reply #33181 on: Tue, 09 June 2015, 11:02:19 »
There where a couple not-seperated sip sockets in a bag with the LED board (evo's pic shows this). I left those alone.
There was also a bag of a couple hundred sip sockets without plastic that I've been slowly putting into switches.
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #33182 on: Tue, 09 June 2015, 11:03:18 »
There where a couple not-seperated sip sockets in a bag with the LED board. I left those alone. There was also a bag of a couple hundred sip sockets without plastic that I've been slowly putting into switches.
This is what mine looks like:
Untitled by skurela, on Flickr
Offline greath
« Reply #33183 on: Tue, 09 June 2015, 11:05:13 »
Sweet. Thanks for the pic. Yeah I'll have to check but I'm worried mine might be touching each other inside some of the switches.
Offline Evo_Spec
  • (╯°ヮ°)╯︵⌨
« Reply #33184 on: Tue, 09 June 2015, 11:05:25 »
Sorry guys, i'm like on tons of crack right now (not literally) and i read this all wrong.
Just continue as you were.....i'll go sleep now....
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #33185 on: Tue, 09 June 2015, 11:06:13 »
Yep! Although touching won't affect them I think unless you solder them together by accident
Offline Evo_Spec
  • (╯°ヮ°)╯︵⌨
« Reply #33186 on: Tue, 09 June 2015, 11:09:06 »
Yeah, just do what Pwn said and install the LED in the sockets before soldering, it'll separate the SIP sockets and prevent them from touching.
Edit: Also for the SMD components there's 2 methods you can use.
This
or this (i don't have a wide tip so this is what i do)
http://www.gonskeyboardworks.com/manuals/129-nerd-side-ledsmd-led-soldering.html
« Last Edit: Tue, 09 June 2015, 11:17:21 by Evo_Spec »
Offline exitfire401
  • The Force is Re/\l
« Reply #33187 on: Tue, 09 June 2015, 12:39:02 »
It's finally here!
Purple slider goodness.
It's evident within 10 minutes of typing that I need to swap the domes to 55g in this thing. REALLY can't stand 45g Topre myself. and the 30 barely feels like it returns with the silenced slider.
Offline strict
  • TKL Zealot
« Reply #33188 on: Tue, 09 June 2015, 12:47:50 »
It's finally here!
55g silenced AE is as good as it will ever get, I've sincerely debated picking up both boards from widebasket to do this same swap. If I didnt think my wife would divorce me for spending $800 on keyboards I probably would have done it already. Though I guess I could sell off the non-silenced variable AE that would be created ...
Offline exitfire401
« Reply #33189 on: Tue, 09 June 2015, 12:53:03 »
It's finally here!
Well, all you have to do is purchase a 55g off of EK (what I'll be doing). It's $200 cheaper haha. But yeah, the only reason I was allowed to get this by the wife was that I sold the HHKB/23u.
Offline Axollott
« Reply #33190 on: Tue, 09 June 2015, 17:26:27 »
This.
Offline missalaire
  • Great Finder of Great Finds
Offline katushkin
  • Too Keycool for School
  • Just the guy
« Reply #33193 on: Tue, 09 June 2015, 17:46:14 »
Offline missalaire
« Reply #33194 on: Tue, 09 June 2015, 17:52:23 »
My DXRacer is here :D
http://www.dxracer.com/us/en-us/product/1/pc_gaming_chair/formula_series/oh-fe08-nw/
Does it get you better benchmarks?
Better benchmarks, framerates, KDA... you name it. I think I'm gonna go pro and start streaming for a living :P
« Reply #33195 on: Tue, 09 June 2015, 17:53:20 »
BENCHmarks xD  <3  Looks rad.
« Reply #33196 on: Tue, 09 June 2015, 18:09:41 »
plates for my car
Offline smeckledorfed
« Reply #33197 on: Tue, 09 June 2015, 18:19:24 »
A pretty awesome tabletop game and my first keycap puller...
Offline Jokrik
« Reply #33198 on: Tue, 09 June 2015, 18:58:04 »
plates for my car
Registration plate? You are going legal now?
« Reply #33199 on: Tue, 09 June 2015, 19:09:27 »
plates for my car
i got 6 months to go plate less, going to see how long after the 6 till i get pulled over.
