Author Topic: Hi !  (Read 3593 times)
Offline Rsk
Hi !
« on: Sat, 21 July 2012, 14:13:03 »
So, Here i'm
I'm an hardcore gamer, looking for his first mechanical keyboard here.
I actually use a Logitech G11...
Offline reaper
Re: Hi !
« Reply #1 on: Sat, 21 July 2012, 15:34:51 »
Welcome aboard and I used to own a G15 & a G19 (actually they're still in the closet somewhere lol), got a Filco "Otaku" brown and haven't touched the Logitechs since. =P
Din Eli
Offline braaaiiins
Re: Hi !
« Reply #2 on: Sat, 21 July 2012, 18:17:45 »
Welcome! I recommend modded cherry mx switches! Personally I love using my poker with clear stems and right now it has a mixture of red and black springs. Also, if you get a PCB mounted board, I recommend getting some kind of rubber to put underneath. I have zero flex in my poker now and it feels solid, so don't let PCB mount discourage you! They're also a million times easier to modify.
Offline wisie
Re: Hi !
« Reply #3 on: Sat, 21 July 2012, 19:55:21 »
Welcome. Time to get you off that Logitech ;)
Offline Wildcard
  • When caffeine isn't enough
Re: Hi !
« Reply #4 on: Mon, 23 July 2012, 22:51:50 »
The heavier the better, I guess I'm just a sucker for a plate mount. A bit stiff, you bet! But the feel, is oh so great.
Welcome to Geekhack!
