Author Topic: What did you add to your Keyboard today? - Post Your Pics  (Read 5489098 times)
Offline Smeagol_RP
  • your ad here
    • Steam
« Reply #1500 on: Sun, 25 November 2012, 19:28:17 »
I was not enjoying the result  :(
So...
It was not exactly the result expected, but better than before.
  • CM QFR (Clears) | CM QFR (Blues) | KBT Poker II (62g Browns) | CM Alcor
Offline MMB
« Reply #1501 on: Sun, 25 November 2012, 19:28:42 »
Nice bruh-boost!
Offline boost
  • BOSTMOBILE
  • NY Giants!!!
« Reply #1502 on: Sun, 25 November 2012, 19:29:14 »
So...
Nice mod.. I really like that idea :)
-Enzo Ferrari
Offline sth
  • 2 girls 1 cuprubber
« Reply #1503 on: Sun, 25 November 2012, 19:30:20 »
Smeagol_RP that's awesome!
Offline JSaintS
  • Formerly eNrageDSainT
    • JSaintS
« Reply #1504 on: Sun, 25 November 2012, 19:52:42 »
So...
how have you done that? :D
Offline MMB
« Reply #1505 on: Sun, 25 November 2012, 19:53:38 »
Looks like that 356N that was on ebay. That person drilled tiny holes on the top of each keycap. I like the effect.
Offline DanGWanG
  • Higher Standards
    • DanGWanG's Keyboard Blog
« Reply #1506 on: Sun, 25 November 2012, 19:56:09 »
What's inside the keycap though? Was that just spray painted?
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #1507 on: Sun, 25 November 2012, 20:00:08 »
Keycap inside was coated with dark matter... lol. Good job drilling evenly. Most attempts at making led window I have seen were not a success.
« Reply #1508 on: Sun, 25 November 2012, 20:06:30 »
plasti-dip maybe
Offline rayuki
  • RAAAAAAR
« Reply #1509 on: Sun, 25 November 2012, 20:08:07 »
Offline sth
« Reply #1510 on: Sun, 25 November 2012, 20:09:56 »
double post from my thread
this is generally frowned upon...
Offline MMB
« Reply #1511 on: Sun, 25 November 2012, 20:10:11 »
in b4 demik
Offline DanGWanG
  • Higher Standards
« Reply #1512 on: Sun, 25 November 2012, 20:13:35 »
rayuki...what have you done to that beautiful keyboard....
« Reply #1513 on: Sun, 25 November 2012, 20:14:21 »
http://geekhack.org/index.php?topic=37741.0
you need props that bad?
sad.
Offline MMB
« Reply #1514 on: Sun, 25 November 2012, 20:15:33 »
It's a tragedy....
« Reply #1515 on: Sun, 25 November 2012, 20:22:35 »
needs more unicorn vomit.
Offline SmallFry
« Reply #1516 on: Sun, 25 November 2012, 20:28:32 »
I thought he sold that board... 0.0
Offline Smeagol_RP
  • your ad here
    • Steam
« Reply #1517 on: Sun, 25 November 2012, 20:34:01 »
Thank you guys  :)
I've got some caps and I'll test the tiny holes at the top.
Yep, just spray for plastics.
Offline SmallFry
« Reply #1518 on: Sun, 25 November 2012, 20:40:52 »
Are those PBT caps? Also, nice mod. How did you pop the hole in the corner? A dremel/drill press? Finally, what size did you use?
Edit: WASD textured keys. I assume a set of ABS blanks. Either way nice mod!
« Last Edit: Sun, 25 November 2012, 20:42:47 by SmallFry »
« Reply #1519 on: Sun, 25 November 2012, 20:41:43 »
How did you get it so neat?  Did you just tape it up?
Offline gameaholic
« Reply #1520 on: Mon, 26 November 2012, 03:43:33 »
What case is this?
and what keyboard and case is this?
IBM Model M SSK, Filco MJ2 Ninja TKL with Reds ergo-clears, CM Storm QFR 55g Whites, Poker II with Reds
Offline singaporean123
  • I like keycaps and I cannot lie
« Reply #1521 on: Mon, 26 November 2012, 04:08:55 »
poker and mx mini? not too sure..
Offline Ovoxo
« Reply #1522 on: Mon, 26 November 2012, 04:20:36 »
1st is a 356 Mini
2nd is a MX Mini
« Reply #1523 on: Mon, 26 November 2012, 06:33:16 »
I know that at least the MX mini didn't come with that case.  It originally had an acrylic case.  I think they are LZ cases.
Offline rayuki
  • RAAAAAAR
« Reply #1524 on: Mon, 26 November 2012, 07:58:57 »
Not today, but didn't get to take a picture yesterday;
Bad phone pic because my camera isn't here atm
Rainbow caps from Feng
There was no ISO enter in the pack even though the description said so, I've messaged Feng about it but haven't heard back yet. So for now I'll have to live with the black enter messing up everything.
Next step is getting rid of the branding on the case; I've been looking into either painting it or getting a clean one from CM.
Also note the awesome right winkey...
i think mine came with an iso enter so i'll check and if it does you can have it.
Offline rayuki
  • RAAAAAAR
« Reply #1525 on: Mon, 26 November 2012, 08:06:00 »
Unless your one of the elite few of course lol. im working my way up from the bottom....
its still a work in progress... other then the dodgy modifiers whats wrong with it?
yep, i sold it to myself. had to pay out the bloody teeth.
« Last Edit: Mon, 26 November 2012, 08:08:07 by rayuki »
Offline Smeagol_RP
  • your ad here
    • Steam
« Reply #1526 on: Mon, 26 November 2012, 11:27:29 »
It's a ABS set from WASD Keyboards. Unfortunately I didn't find the ISO set in PBT and others caps to complete this layout (ABNT  :(). Drill press with a drill bit of 1.5mm.
Yeah I really liked the textured caps.  ;D In fact I also bought a "space" and  a "L shift" textured to complete the "gamer pack".  :p
« Last Edit: Mon, 26 November 2012, 13:12:46 by Smeagol_RP »
Offline LollyWater
« Reply #1527 on: Mon, 26 November 2012, 20:59:13 »
Some changes applied today ;p
Where did you get those caps?  :)
Offline sth
« Reply #1528 on: Mon, 26 November 2012, 21:08:28 »
dude you have a cheat and a dolch set, PLEASE.
Offline MMB
« Reply #1529 on: Mon, 26 November 2012, 21:42:29 »
imsto dye subs w/hangul + desko RGB dye subs (thanks bro)
Offline mistakemistake
  • Global Loveinator
« Reply #1530 on: Mon, 26 November 2012, 21:45:26 »
dayum son
Offline jessecoleman
« Reply #1531 on: Mon, 26 November 2012, 21:59:07 »
I got the Techkeys gold pack over the long weekend and some of feng's goodies this evening.
8522-0
Offline DanGWanG
  • Higher Standards
« Reply #1532 on: Mon, 26 November 2012, 22:10:17 »
holy moly men
Offline sth
« Reply #1533 on: Tue, 27 November 2012, 02:58:51 »
« Reply #1534 on: Tue, 27 November 2012, 03:18:33 »
Very smooth, sth ):
Offline SmallFry
« Reply #1535 on: Tue, 27 November 2012, 07:17:47 »
Looking sharp!
Offline nntnam
« Reply #1536 on: Tue, 27 November 2012, 07:48:27 »
Man, you are the best hunter ever 0_o
░▒▓ KMAC | FILCO MJ2 | HHKB | PHANTOM ▓▒░
Offline Acetrak
  • ssk.ℜ
  • gnawm_
« Reply #1537 on: Tue, 27 November 2012, 07:54:56 »
Nice Sth, I like how you use the f-keys instead of the usual 1-0  :)
Offline GoatMaster
  • Formerly Franatic89
« Reply #1538 on: Tue, 27 November 2012, 09:37:31 »
Some new cherry dyesubs on my mini - yea, I know it's a double-shot capslock, but :P
What keyboard is this ?
Offline mars-bar-man
« Reply #1539 on: Tue, 27 November 2012, 09:44:58 »
KBC Poker I believe? Although the odd modifiers down the bottom kind of threw me a little.
Nope, ignore that, I have no idea :/
« Last Edit: Tue, 27 November 2012, 09:47:27 by mars-bar-man »
KBC Poker w. MX Blues
Offline boost
  • BOSTMOBILE
  • NY Giants!!!
« Reply #1540 on: Tue, 27 November 2012, 09:48:22 »
356Mini. It's a Korean custom keyboard
-Enzo Ferrari
Offline MMB
« Reply #1541 on: Tue, 27 November 2012, 10:31:07 »
No sir. Only patience :P
« Reply #1542 on: Tue, 27 November 2012, 10:37:21 »
Is that her name, Patience? Your Korean insider, I mean. :P
It helps when you have all sorts of rare stuff to trade, also.
Offline MMB
« Reply #1543 on: Tue, 27 November 2012, 12:36:18 »
No. I got them from USA. I don't have anything rare, bro. So much speculation -_-
« Reply #1544 on: Tue, 27 November 2012, 12:39:45 »
Bro Caps are rare at the moment. ;D
Offline MMB
« Reply #1545 on: Tue, 27 November 2012, 12:43:24 »
For now.... ;)
Offline whiskerBox
« Reply #1546 on: Tue, 27 November 2012, 19:22:13 »
@Sth Looks sick man love it
"I'm on a mission to bring down GH's anarchy of moderators" -RIPSTER jr.
« Reply #1547 on: Tue, 27 November 2012, 20:23:03 »
And yet Dan has at least six of them...
« Reply #1548 on: Tue, 27 November 2012, 21:26:01 »
And you wonder where MMB gets his Korean customs...
Offline boost
  • BOSTMOBILE
  • NY Giants!!!
« Reply #1549 on: Tue, 27 November 2012, 21:37:51 »
I has 0 brocaps
-Enzo Ferrari
