Author Topic: What did you add to your Keyboard today? - Post Your Pics  (Read 5606321 times)
« Reply #9750 on: Fri, 08 December 2017, 20:05:42 »
Cobbled together a board from parts I had laying around, and added some Retro DSA.  I really like it.
Offline Glod
  • Also Known As Ergonomech
    • YouTube Channel
« Reply #9751 on: Sat, 09 December 2017, 20:48:39 »
What is that texture on the case? What material
« Reply #9752 on: Sat, 09 December 2017, 20:59:04 »
It's ABS. Long time ago Big Blue Saw got some super cheap plastic and offered very low prices on waterjet cutting. I dug out a few of my existing designs and took advantage. Turns out it was textured, which I wasn't expecting. At first I was mad but this looks pretty good. Some of the other pieces have scratches, though, which ruins the effect. (unfortunately, BBS almost always damages the finish on the workpieces, I only use them when I have to)
By the way, ABS is not good for cases. It's not strong enough. I made the other parts with acrylic.
Offline sncbraxsc2
  • ⭐Domesticated Dweeb⭐
« Reply #9753 on: Wed, 14 March 2018, 11:32:04 »
I really like that layout.
I put some nice blanks on my spare board to quicken/naturalize my touch typing. I make errors too often in the y/u/i/o area
Offline embew
« Reply #9754 on: Sun, 18 March 2018, 00:43:51 »
Added a SP DSA (color: GQH) set to a lunar Rama M65-A with Zealios 78g R9 switches.
« Reply #9755 on: Sun, 18 March 2018, 02:47:59 »
cmon man u gotta use some thicc caps for that thicc bezel
« Reply #9756 on: Mon, 19 March 2018, 00:46:03 »
fact
Offline Glod
    • YouTube Channel
« Reply #9757 on: Fri, 23 March 2018, 15:42:14 »
 I am curious what geekhack thinks of this
Ping! by almightyglod, on Flickr
« Reply #9758 on: Sun, 01 April 2018, 13:39:46 »
Finally cobbled together some pieces to make a keyboard.
192867-0
192869-1
« Reply #9759 on: Sun, 22 April 2018, 13:49:13 »
Swapped out my FC980M caps, not a perfect replacement, the kit I ordered was missing some keys.
Offline pr0ximity
« Reply #9760 on: Sun, 22 April 2018, 22:47:48 »
Went back to black
Offline E3E
« Reply #9761 on: Mon, 23 April 2018, 07:03:06 »
Hey, are those some katakana Topre keys on the top board? Looks IBM esque with the arrow side-legends too. Do you mind if I ask where you got them? Katakana sublegends are my favorite. :D
« Reply #9762 on: Mon, 23 April 2018, 07:49:36 »
I'll see if I can dig up the info and pm you.
Offline pixelpusher
« Reply #9763 on: Tue, 01 May 2018, 23:36:34 »
Please tell me where he got those keycaps!  Too awesome
Offline Duckyreddy
  • Better skadoodle, poodle.
« Reply #9764 on: Wed, 02 May 2018, 00:19:31 »
Looking sharp!
What set is that?
Ducky One Cherry MX Silent Reds
Leopold FC660M MX Blue
Logitech G403/ Razer Naga 2014
« Reply #9765 on: Wed, 02 May 2018, 06:16:41 »
Looking sharp!
What set is that?
Found them on ebay no idea who makes them.
Offline Duckyreddy
« Reply #9766 on: Wed, 02 May 2018, 06:27:54 »
Looking sharp!
What set is that?
mysterious set hahah!
Offline davkol
  •  Post Editing Timeout
« Reply #9767 on: Sat, 05 May 2018, 12:17:36 »
Added KBDfans black dye-sublimated PBT keycaps to Raptor K1 (Cherry G80-18xx).
It's a disappointment:
  • 6u spacebar has the middle stem in the wrong spot, thus doesn't work.
  • 1.75u right Shift is wrong row/profile.
  • I had to use 00 for the ISO key between left Shift and Z.
  • There was no 1u Menu key, I had to use Fn instead.
Offline elcubismo
    • Reddit page
« Reply #9768 on: Wed, 09 May 2018, 00:44:48 »
PPS keycaps with CMY PBT blank mods on my Space Station Norbatouch
Leopold FC660C lubed, silenced with landing pads | Norbatouch lubed, silenced with hyperspheres | Poker II MX Blue with vortex aluminum case, vortex red/white doubeshot pbt caps and o-rings | CODE TKL MX Clear with Miami | Unicomp Buckling Spring | GMMK with rainbow vomit switches, mostly jailhouse blues and pandealios
Offline rundeploy
« Reply #9769 on: Wed, 30 May 2018, 05:20:05 »
V60 in a "Pexon" style case, with an actual Pexon cable!
Can anyone inform me please what keyset is that please ?
Offline pnkpanther65
« Reply #9770 on: Thu, 07 June 2018, 08:53:31 »
Added more pink
Offline bjayswift
« Reply #9771 on: Thu, 07 June 2018, 09:26:41 »
Added the bot as my crown jewel to my TX1800V2
TX1800V2
Offline nephiel
« Reply #9772 on: Fri, 08 June 2018, 14:48:22 »
Which profile is the Shift? Judging from the pic, it may be the right profile but printed upside-down.
Stop wasting space! Chop your spacebar into bits!
NPH60: a custom 60% w/TrackPoint & split spacebar
« Reply #9773 on: Sun, 29 July 2018, 17:54:53 »
nylon outemu switch tops
still vintage cherry clear on the bottom and stem
the tighter fit makes for a snappier upstroke, pleasant surprise, was not expecting any change in feel.
Offline sundin
« Reply #9774 on: Mon, 30 July 2018, 03:49:38 »
More pink
Offline EMC Labs
« Reply #9775 on: Mon, 05 August 2019, 02:12:58 »
Added Cherry 1.5x modifiers and 1x Windows keys (thanks metafour!) to my Phantom.  100% Cherry keys now =)
Does anyone know what keyboard this is?
Thanks in advance.
Offline funderburker
« Reply #9776 on: Mon, 05 August 2019, 02:50:44 »
Oh that's nice. Real nice!
Keyboard design by Skepur
Offline user 18
« Reply #9777 on: Mon, 05 August 2019, 15:50:15 »
Thanks in advance.
IIRC Phantom refers to the PCB. See https://deskthority.net/wiki/Phantom_instruction_guide
There's no standard Phantom case, if that's what you're asking about -- I believe the phantom PCB is compatible with Filco cases, so that may help narrow things down (don't quote me on that, the phantom GB was before my time)
Avatar by ashdenej
« Reply #9778 on: Mon, 05 August 2019, 15:55:49 »
phantom pcb in an acrylic case made by user litster
Offline EMC Labs
« Reply #9779 on: Tue, 06 August 2019, 02:20:39 »
Cheers, found it.
Offline EMC Labs
« Reply #9780 on: Tue, 06 August 2019, 02:21:07 »
Thanks in advance.
Thanks for the help.
Offline Sintpinty
  • Carbon Based Life Form
    • My Roblox Profile
« Reply #9781 on: Thu, 08 August 2019, 09:37:21 »
Dirty kid finger prints
Just my thoughts
Offline katiuse
« Reply #9782 on: Tue, 30 March 2021, 08:06:06 »
The Bro Set GB keyset.  :D  More pics here.
Where can I find this beautiful Keyboard to buy?
