Author Topic: What did you add to your Keyboard today? - Post Your Pics  (Read 5645118 times)
Offline avantdark
« Reply #9700 on: Tue, 28 February 2017, 23:33:52 »
Put Gateron greens on my Masterkeys Pro M
Offline OfTheWild
  • Make things. Have fun.
    • Studios of the Wild
« Reply #9701 on: Thu, 02 March 2017, 00:06:31 »
Added some bling to the HHKB. Thats +5hp at least
-Dana
Offline pixelpusher
« Reply #9702 on: Thu, 02 March 2017, 21:12:56 »
NICE!  I'm planning to put Gateron yellows in a rapid-i im getting off of ebay.
Offline zslane
« Reply #9703 on: Thu, 02 March 2017, 23:31:53 »
I finally received my Datamancer wood case for my Penhurst Pok3r:
161921-0
Offline OfTheWild
« Reply #9704 on: Thu, 02 March 2017, 23:44:02 »
but really though... how is it typing on those 'typewriter' key caps? The wife is always talking about wanting some.
-Dana
Offline zslane
« Reply #9705 on: Thu, 02 March 2017, 23:49:55 »
It's different. It's fun (if you like old typewriters). It's what you make of it, I guess.
My typing speed seems to be about the same as with any other set of keycaps (80-90wpm).
Offline OfTheWild
« Reply #9706 on: Fri, 03 March 2017, 00:22:12 »
Interesting. I was hoping someone would have them at a meet so I could test them out. They seem to go up for sale on massdrop every once in a while. Maybe i'll find a used set to try out one day.
-Dana
« Reply #9707 on: Fri, 03 March 2017, 00:40:36 »
With regards to typing speed I'd assume they're like any other uniform flat profile, in my case I generally type a bit faster (5-7 wpm) using uniform flat profiles because you don't have to lift your fingers and can almost slide between keys. From there it's just a matter of if you like how the keycaps feel on your fingers when you use them, I'm not a huge fan of the typewriter style keycaps but I think that has to do more with the sound that how they feel.
Offline suntorywhisky
    • IG
« Reply #9708 on: Sun, 05 March 2017, 17:24:41 »
Added some gold to my HHKB today
Offline avantdark
« Reply #9709 on: Wed, 15 March 2017, 14:22:55 »
New Caps for my mc pro m
Gesendet von iPhone mit Tapatalk
Offline osi
« Reply #9710 on: Tue, 11 April 2017, 09:06:00 »
Gave the hhkb a lube job and cleaning
« Reply #9711 on: Tue, 11 April 2017, 09:44:24 »
Good for another ~3 months? :D
Offline osi
« Reply #9712 on: Tue, 11 April 2017, 10:41:58 »
Yes. I try and shoot for 6 months but it all depends in how much I use it.
The last tube of lube lasted me 3 runs but I'll be lucky to get 2 out of my current batch from tech keys
*shakes fist*
Offline Severe
  • HHKB Zealot
« Reply #9713 on: Fri, 14 April 2017, 00:12:38 »
They looked great on the website but now I'm my board I'm not so sure I'm a fan
HHKB Pro 2 Black Lubed 55g
Logitech G502 (Gaming) Logitech MX Master 2 (Day to day)
Offline lzrdwzrd
« Reply #9714 on: Fri, 14 April 2017, 22:37:18 »
Popped in some lubed Zelios 67s into my new Winkeyless pcb and case
and did a rgb check
Really impressed with the quality and service from Winkeyless  :thumb:
SteelSeriesLeopoldZowie
6gV2 (mx black)FC660C/EGFK1
Offline pixelpusher
« Reply #9715 on: Sat, 15 April 2017, 20:09:49 »
Swapped out Cherry browns on my Pok3r with Gateron greens.  Lubed the stabilizes whilst I was at it165964-0
    • IG
« Reply #9716 on: Sun, 16 April 2017, 07:21:48 »
M-10A counts, right?
Offline BB-GR8
« Reply #9717 on: Sun, 16 April 2017, 16:22:38 »
Gave my Super Fungkeys a much more deserving home today after building my WhiteFox Purple Zealios.  :thumb:
Now just waiting on that replacement keycap...
Offline Severe
  • HHKB Zealot
« Reply #9718 on: Mon, 17 April 2017, 20:37:29 »
New Keyboard cable from WASD
Offline iLLucionist
  • Topre is Love.
« Reply #9719 on: Sun, 23 April 2017, 17:06:56 »
*shakes fist*
Do you really have to lube that often? Does the lube wear out or something? Evaporate?
Offline orpheo
« Reply #9720 on: Mon, 24 April 2017, 06:24:17 »
Offline Pwner
  • soon™
« Reply #9721 on: Sat, 06 May 2017, 13:16:11 »
Replaced the stock green lock LED's with sip'd red 1.8mm LED's.  Tossed some red GMK accent caps on yesterday.
Offline Sniping
« Reply #9722 on: Sat, 06 May 2017, 13:18:34 »
Always nice to see non-ANSI customs :) glad you found the layout you needed
Offline ramnes
  • T fou, mec?
« Reply #9723 on: Sat, 06 May 2017, 13:19:31 »
Nice one! Clean and simple.  :thumb:
Offline SBJ
  • Tactile pls
« Reply #9724 on: Wed, 24 May 2017, 14:06:28 »
Added alu frame.
I like how it turned out.
Offline 2ter
« Reply #9725 on: Sun, 28 May 2017, 15:54:29 »
yesterday i added o-rings, floss, typewriter keycaps and a repaired cable to my model m.
today i added a skull-key.
Offline mrduul
« Reply #9726 on: Sun, 28 May 2017, 16:40:07 »
 :eek:
That is really sick!!!  ;D
Offline widdlekitty
« Reply #9727 on: Mon, 29 May 2017, 18:39:58 »
Made some modifiers to add a little more life to the viper.
« Reply #9728 on: Mon, 29 May 2017, 19:19:35 »
Best Viper ever  :cool:
Offline iamtootallforthis
  • Something a lot Funnier
  • I like green stuffs.
    • WTB/WTTF Thread
« Reply #9729 on: Mon, 29 May 2017, 19:36:22 »
So many colors!  Loving all the 420s
Offline switchnollie
  • sleever supreme
  • greyhat co-leader
« Reply #9730 on: Mon, 29 May 2017, 20:46:31 »
wey keycaps & a vandal
Offline xine007
« Reply #9731 on: Mon, 29 May 2017, 20:52:03 »
Love the colors!
« Reply #9732 on: Mon, 29 May 2017, 20:55:24 »
My oldest wanted to hang out and do keyboard things.
    • WTB/WTTF Thread
« Reply #9733 on: Mon, 29 May 2017, 20:55:28 »
**** man that's clean. Loving all those sublegends and that vandal
Offline funderburker
« Reply #9734 on: Tue, 30 May 2017, 05:56:40 »
What POS board is that? I'm not really an ortholinear type of guy but that's looks quite nice because it's not a 40%. Not that I'm against 40% (had one and loved to bits) but I a 60% ortholinear would probably be cool. But well, it defeats the purpose I think (because of the length you need to reach to keys and stuff).
Keyboard design by Skepur
« Reply #9735 on: Tue, 30 May 2017, 06:42:24 »
I can't remember. It was from eBay a while ago.
It is just used for her to put keycaps on, I couldn't get it to work.
Offline PollandAkuma
« Reply #9736 on: Thu, 01 June 2017, 17:17:21 »
snk cosplay??? nice caps!
  • sleever supreme
  • greyhat co-leader
« Reply #9737 on: Fri, 02 June 2017, 23:23:54 »
Offline zeltner
« Reply #9738 on: Wed, 28 June 2017, 08:29:52 »
I put this together last night. Previously was an older s60-x (non led version) with Gateron reds. I didn't really like the feel of linear though so decided to do an upgrade. Now it is a new s60-x with Gateron blues. Purple plate. GMK plum.
171810-0
Offline FloFoer94
« Reply #9739 on: Wed, 28 June 2017, 08:59:23 »
Added thin o-rings, Tai-Hao Doubleshot PBT German ISO Keycaps as a replacement for the stock caps and a wooden wrist rest.
171816-0
« Last Edit: Wed, 28 June 2017, 09:12:21 by FloFoer94 »
« Reply #9740 on: Wed, 28 June 2017, 09:15:17 »
Let me know when you don't want that Moai anymore!  :-X
Offline zeltner
« Reply #9741 on: Wed, 28 June 2017, 09:26:56 »
That picture doesn't even do the Moai justice. This one is a little bit better (still not great though) you can see some of the swirls in it.
171819-0
« Reply #9742 on: Wed, 28 June 2017, 09:46:44 »
 :-X
Offline zeltner
« Reply #9743 on: Thu, 29 June 2017, 07:21:23 »
Finally got around to swapping GMK carbon from the novatouch to the DAS. Complete with matching carbon volume wheel.
171888-0
171890-1
Offline ramnes
  • T fou, mec?
« Reply #9744 on: Mon, 30 October 2017, 14:34:49 »
mummerrrrr
« Last Edit: Mon, 30 October 2017, 14:42:08 by ramnes »
Offline mogo
« Reply #9745 on: Thu, 02 November 2017, 11:10:16 »
I'm seeking something for the top left key, although the Heiroglyphics Third Eye will do for now i guess.
Offline OneNightFriend
« Reply #9746 on: Fri, 03 November 2017, 20:02:04 »
Thinkster is what you need
Offline mogo
« Reply #9747 on: Sat, 04 November 2017, 08:53:14 »
Working on it.  :thumb:
Offline Glod
  • Also Known As Ergonomech
    • YouTube Channel
« Reply #9748 on: Mon, 27 November 2017, 18:20:37 »
Absolutely terrible pictures but
Added EnjoyPBT caps to my DZ60 (purple on white)
2017-11-27_07-07-23 by almightyglod, on Flickr
2017-11-27_07-07-37 by almightyglod, on Flickr
Added Brown BOX switches and DSA Hyperfuse to the K-Type
2017-11-27_07-10-39 by almightyglod, on Flickr
2017-11-27_07-04-24 by almightyglod, on Flickr
Offline divito
« Reply #9749 on: Sat, 02 December 2017, 21:28:43 »
Finally put my Galaxy Class blanks on my Varmilo.
183412-0
Varmilo (MX Grey) KeyCool 87 (MX Clear) Quickfire Stealth (MX Green)
