Author Topic: What did you add to your Keyboard today? - Post Your Pics  (Read 5612040 times)
« Reply #9550 on: Thu, 12 May 2016, 01:05:07 »
GMK Dolch and GMK RGBYK...it's delish! Pretty much all I want from a keyboard.
spacebar is broken
Offline Crossfire
« Reply #9551 on: Thu, 12 May 2016, 01:30:44 »
spacebar is broken
At least my thumb is not  :-*
« Reply #9552 on: Thu, 12 May 2016, 01:31:19 »
spacebar is broken
got some weak thumbs
Offline Crossfire
« Reply #9553 on: Thu, 12 May 2016, 01:32:40 »
too hard of a spring in that spacebar switch...friggin 65g bouncing at my flesh :)
« Reply #9554 on: Thu, 12 May 2016, 01:34:30 »
spacebar is broken
weak thumbs, as sifo said. MAN UP! YOUR BLOODLINE DEPENDS ON IT!
Offline naasfu
  • The Curator
  • CURSE YOU HE-MAN
« Reply #9555 on: Thu, 12 May 2016, 02:15:56 »
Bae #1 and Bae #2. Bae #2 now has 100% more Alps novelties on the F row.
look at dem sexy boards and caps! <3
spacebar is broken
more like lazy ass thumbs.
Offline Crossfire
« Reply #9556 on: Thu, 12 May 2016, 02:18:54 »
« Last Edit: Thu, 12 May 2016, 11:36:54 by Crossfire »
Offline alienman82
« Reply #9557 on: Thu, 12 May 2016, 11:54:20 »
removed.
« Last Edit: Thu, 01 March 2018, 15:14:01 by alienman82 »
Offline E3E
« Reply #9558 on: Tue, 17 May 2016, 12:26:44 »
Apologize in advance for the terrible pics. :)
Winkeyless
OR
Winkey'd
Oh well, it doesn't matter much, but the blockers will be good when I want to use some unmodified classic sets without winkeys. The current set is a Dell AT101 set dyed black. Has mild shine on it. I was considering dyeing a mint set I just acquired black, but it's reeeeally hard to find a completely unshined AT101 set, which is already rather rare to begin with, so I'll keep them as is.
It's easy to swap between the two since the board is hotswappable like my Eagle.
And for some GORE:
I had to modify my Duck Blockers because they were not made with Alps plates in mind. Funny, because the Leeku PCB does have mounts for them.
Offline nightdriver
  • life is like t. rex
« Reply #9559 on: Tue, 17 May 2016, 13:53:43 »
cyan GMK spacebar
Offline DanielT
« Reply #9560 on: Wed, 18 May 2016, 02:10:20 »
I have converted my NerD60 [CTRL]ALT Edition to TMK firmware  :cool:
Offline ghostjuggernaut
« Reply #9561 on: Wed, 18 May 2016, 04:34:22 »
I'm curious if there was a specific reason why, or if you did it because why not?
Offline DanielT
« Reply #9562 on: Wed, 18 May 2016, 05:03:34 »
Because I started to hate the default firmware with all the bugs, not working in BIOS, causing crashes and simply having me tied to windows for programming. TMK has a tons of features and it's well worth doing this, if you have the balls to risk bricking the board.
After you make the conversion you can't go back to GON firmware anymore (unless you get his bootloader)
« Reply #9563 on: Wed, 18 May 2016, 05:22:32 »
I don't have a gon anymore, but wasn't aware of its limitations. I do enjoy TMK though. Glad to hear it worked out for you.
« Last Edit: Wed, 18 May 2016, 07:53:56 by ghostjuggernaut »
Offline Dernubenfrieken
« Reply #9564 on: Wed, 18 May 2016, 06:30:23 »
Green EnjoyPBT Dyesubs and Red GMK.
137383-0
Offline amos5606
« Reply #9565 on: Wed, 18 May 2016, 11:18:14 »
The cherokey fit my 87u so much :cool: :cool:
« Last Edit: Wed, 18 May 2016, 12:32:28 by amos5606 »
What will fill your hearts with delight ,,
Offline alienman82
« Reply #9566 on: Wed, 18 May 2016, 12:48:18 »
removed.
« Last Edit: Thu, 01 March 2018, 15:11:41 by alienman82 »
Offline omgar
« Reply #9567 on: Wed, 18 May 2016, 22:30:57 »
Playing with colors.
Offline jaffers
Offline avantdark
« Reply #9569 on: Thu, 19 May 2016, 06:42:47 »
Made some Model M Lego adapters.
« Reply #9570 on: Tue, 24 May 2016, 03:06:48 »
Offline HPE1000
  • Keycap Paparazzo
« Reply #9571 on: Tue, 24 May 2016, 07:18:44 »
added some paint
odd looking hhkb
Offline dgneo
  • Supervillain
« Reply #9572 on: Tue, 24 May 2016, 07:40:18 »
added some paint
odd looking hhkb
Really digging that color, looks great with the flakes!
Offline HPE1000
  • Keycap Paparazzo
« Reply #9573 on: Tue, 24 May 2016, 09:44:32 »
added some paint
odd looking hhkb
Offline tigersharkdude
« Reply #9574 on: Tue, 24 May 2016, 11:31:09 »
CMY MODS yesterday
« Reply #9575 on: Tue, 24 May 2016, 22:24:16 »
Offline xtrafrood
  • formerly csmertx
  • Polycarb believer
    • csmertx.com
« Reply #9576 on: Sun, 29 May 2016, 12:32:31 »
With Enjoy PBT Dye-Sub(A.K.A. Gateron Dye-Sub)
and + GMK blue enter :)
Damn, that blue enter key looks nice
Edit - Page 183.. why the hell was I on that page. I clicked on show new replies then clicked on this thread.. my brain
« Last Edit: Sun, 29 May 2016, 12:37:08 by csmertx »
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #9577 on: Sun, 29 May 2016, 12:38:36 »
Bring back sth. You are living his topre blanks dream.
Offline Kemindo
  • one world one promise
« Reply #9578 on: Sun, 29 May 2016, 13:44:13 »
Nice . Hard to find the nib like it  :thumb:
Peace and Service
Offline Moistgun
  • Slippery When Wet
« Reply #9579 on: Sun, 29 May 2016, 14:00:06 »
Someone needs some row three blanks
Offline beehatch
  • baehatch
« Reply #9580 on: Sun, 29 May 2016, 14:02:05 »
make the man some
Offline Moistgun
  • Slippery When Wet
« Reply #9581 on: Sun, 29 May 2016, 14:24:06 »
make the man some
Im working on it Bee.
Offline zombiegristle
« Reply #9582 on: Tue, 31 May 2016, 20:18:43 »
I soldered on the diodes for my Kinesis Advantage mod. I'm swapping both keywells to Gateron Blues using spare PCBs so I can easily swap back to the original Cherry Browns if desired, along with swapping the thumb clusters with what I'm calling "Ghetto-ron Greens"; left the Cherry brown bases soldered on and swapped the tops/stems for Gateron Blues, and swapped the springs to 80g. I also desoldered two of the thumb switches on the left hand and swapped them out for Cherry Lock switches to use as layer toggles with a layout I'm working on as a long-term ongoing project.
I think I did all right for my first-ever soldering attempt. :D
« Reply #9583 on: Tue, 31 May 2016, 23:32:53 »
Finally swapped some stems and springs.
Offline kenmai9
  • Unicornforce
  • Skrrr
« Reply #9584 on: Wed, 01 June 2016, 00:13:25 »
Finally found some combination for these purple mods I got from secret santa.. in 2013.
138576-0
138578-1
138580-2
138582-3
Offline E3E
« Reply #9585 on: Sun, 12 June 2016, 10:12:14 »
Decided to bling out the connector on my Alps NCR Leeku 3000 build.
This thing cost me $25 after getting a friend to proxy the connector since I couldn't find a place that sold it in the US.. The entire cable was made from parts I bought from around the web. :)  Not Yarbo
Used some neoprene tube to sleeve the last bit before the cable enters the connector since the opening was a lot bigger than its diameter. Really happy that my idea for solving that worked well. :D
« Last Edit: Sun, 12 June 2016, 10:15:11 by E3E »
Offline Signature
  • master of puppers
  • * Marketplace Moderator
  • snoozing
« Reply #9586 on: Sun, 12 June 2016, 11:24:13 »
Looks hella good...
Offline Kemindo
« Reply #9587 on: Sun, 12 June 2016, 15:30:45 »
CMY MODS yesterday
 :thumb: :thumb:
Peace and Service
Offline funderburker
« Reply #9588 on: Wed, 15 June 2016, 15:03:16 »
Found the default HHKB keycaps and put them back, added the Reaper. BAM!
Keyboard design by Skepur
« Reply #9589 on: Fri, 17 June 2016, 15:26:36 »
CROSSSSSSSSSPOSTTTTTTTTT
Offline mogo
« Reply #9590 on: Fri, 17 June 2016, 16:29:13 »
HNNNNNNNNNNNNNNNNNNNNNNNNGH
**** that's a beautiful board. Sifo, I can't believe you've done this.  :thumb:
Offline Karura
  • Professional Canadian
  • SKidata life.
« Reply #9591 on: Sat, 18 June 2016, 14:07:18 »
Got some new keys for my keyboard today. :)
« Reply #9592 on: Sat, 18 June 2016, 14:14:20 »
Speechless...
Offline rm-rf
« Reply #9593 on: Wed, 22 June 2016, 17:16:10 »
added  a few items to my board today..
got some nightcaps... and i added the fabled 5%nipple key to my board.
« Reply #9594 on: Wed, 22 June 2016, 18:00:28 »
excuse me sir u have some things i want
« Reply #9595 on: Wed, 22 June 2016, 18:42:00 »
TIME TO SPAM
« Reply #9596 on: Sun, 26 June 2016, 12:45:33 »
TIME TO SPAM
PM'ed about the purple blanks. BTW, gorgeous setup. ;)
« Reply #9597 on: Mon, 27 June 2016, 03:19:12 »
My setup for the next couple of hours. Will add some purple blanks, will look so sweet!  ;D
Offline SBJ
  • Tactile pls
« Reply #9598 on: Mon, 27 June 2016, 09:15:36 »
Looks really good man.
HHKB is so classy that way IMO, it doesn't take much for it to look really good.
Offline Jokrik
« Reply #9599 on: Mon, 27 June 2016, 09:17:16 »
What is this magic?
