Author Topic: Filco majestouch vs Filco Majestouch 2  (Read 3092 times)
Offline xyril
    • Youtube Channel (full of typing and gaming vods)
« on: Sun, 22 July 2012, 07:21:32 »
Really whats, the different between those 2 ? Some says its just remodel keyboard for higher price
Do you think its worth to buy MJ2 over MJ1??? This question has been in my head for months ....
Trying to get a       Filco Majestouch 2 Camoflage.TKL           and               Filco Majestouch NinjaTKL...
Offline thegunner100
  • (╯'□')╯︵</3 ノ( '-'ノ)
    • The Emotional Skyscraper
Re: Filco majestouch vs Filco Majestouch 2
« Reply #1 on: Sun, 22 July 2012, 08:30:24 »
http://deskthority.net/news-reviews-f4/diatec-announces-filco-majestouch-2-tenkeyless-88-series-t204.html
The difference is that the MJ1 uses a one-sided PCB whereas the MJ2 uses a 2-sided PCB, resulting in a slightly different feel. It's not too noticeable, so just go for whichever one you can get!
Input Devices:CM QF Rapidx2 ~ REALFORCE 87uw 45/55g ~ Logitech G5v2 ~ Wacom Bamboo CTH-460
Audio Setup: look me up on head-fi
Check out my blog on touhou/doujin music, audiophile gear, and doujin games!
Offline xyril
« Reply #2 on: Sun, 22 July 2012, 09:54:30 »
Does it really necessary to have 2 PCB?? . I mean what does it do. :S
Offline MMB
« Reply #3 on: Sun, 22 July 2012, 10:27:21 »
Having a 2-sided PCB makes no difference in 'feel', especially when it's plate mounted. It's just the design of the PCB to allow more circuit leads, typically for more complex controllers and other on-board devices.
One-sided PCB also makes life easier for soldering/desoldering.
Offline stingrae
« Reply #4 on: Sun, 22 July 2012, 10:33:09 »
Also as far as I know Ninja models are majestouch 2 unless i'm terribly mistaken.
Filco Ninja Tenkeyless  -Noppoo Choc MiniCm Storm Quickfire Rapid
Offline Kasperb22
« Reply #5 on: Sun, 22 July 2012, 19:32:34 »
Diatec's website shows identical PCBs between the Ninja and Majestouch 2.
« Reply #6 on: Sun, 22 July 2012, 21:42:14 »
The Ninjas are only MJ2. You can get ninja keycaps for the MJ1 if that's what you want though.
Offline xyril
« Reply #7 on: Mon, 23 July 2012, 02:23:29 »
nvr knew the Ninja were MJ2 :O.... seems my retailer "put filco ninja tenkeyless (brown)". hmmm....
Offline stingrae
« Reply #8 on: Mon, 23 July 2012, 08:51:53 »
I just remembered this question being asked (regarding Ninja models) :) didn't have time to go find the proof, sorry :).
