Author Topic: Chording keyboards?  (Read 3717 times)
Offline mathiasx
    • My Blog
Chording keyboards?
« on: Sun, 22 July 2012, 21:47:26 »
What's available out there for chording keyboards? Is it better to build one with quality switches? Things like the Frogpad don't look all that great to me, and I don't have a necessity to wear one (it can sit at a desk that I'm sitting at.)
Currently, I'm considering getting something like the Belkin n50 /n52 / Razor Nostromo gamepad and modding it into a chording keyboard. I'm a bit of a programmer / hardware maker type and so I'd probably use a Teensy USB board (I've got a ton of Arduino experience.) Thoughts?
Offline josh6135
Re: Chording keyboards?
« Reply #1 on: Fri, 03 August 2012, 02:36:53 »
I have used a Nostromo for The Witcher and it was very comfortable and customizable. I have basically no idea outside of a quick Google search what chording is. Overall the Razer software let's you create macros, sorry for probably not helping you at all.
Offline braaaiiins
« Reply #2 on: Fri, 03 August 2012, 14:59:33 »
Chording keyboard would be interesting. Chording is just using a combination keys for letters. You could do the whole alphabet with just 5 keys I think. I think it would get pretty messy for special characters and function keys though.
