Advanced search
bounce or buckle?
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Have you read the
geekhack TOS
lately?
Home
Watched
Unread
Notifications
IRC
Wiki
Search
Spy
Login
Register
geekhack
geekhack Community
Keyboards
Y key won't work
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Y key won't work (Read 2152 times)
Lethal Squirrel
Thread Starter
I <3 60%
Y key won't work
on:
Wed, 25 July 2012, 19:11:53 »
I just plate mounted my Poker, and everything went smooth. It only took 2 hours, But my Y key won't work. I really don't know why, because the solder is fine. I even tried a different switch. Is there any possibility I fried something?
Logged
MMB
I no longer use this account. Please email me.
Re: Y key won't work
Reply #1 on:
Wed, 25 July 2012, 19:13:33 »
Did you rip an eyelet or trace? It's possible you may have done one or the other if you weren't careful at any point. I would try using one more new switch just to be sure, if it still doesn't work, inspect the area around that switch for any damage.
Logged
Lethal Squirrel
Thread Starter
I <3 60%
Reply #2 on:
Wed, 25 July 2012, 19:15:15 »
I tried several switches. and I can't see any damage. Ill upload a pic in a sec.
Logged
limmy
Reply #3 on:
Wed, 25 July 2012, 19:17:54 »
Did you try to resolder the diode? You may have damaged the solder on the diode in the process of desoldering.
Logged
Lethal Squirrel
Thread Starter
I <3 60%
Reply #4 on:
Wed, 25 July 2012, 19:22:05 »
I'm not sure what you mean by "diode" D'x
Here's a pic. My soldering is not the cleanest
(it does't really look that bad in person)
EDIT: the Y solder points look worse than the rest because of desoldering and resoldering in new switches over and over
EDIT 2: I just fixed that ****ty solder point on U
Last Edit: Wed, 25 July 2012, 19:24:38 by Lethal Squirrel
Logged
limmy
Reply #5 on:
Wed, 25 July 2012, 19:27:23 »
That black square thing right beside D21 is the diode. Also, I would recommend you resolder the joint on U key.
Just put hot iron on it briefly until you see the solder melt. It is important you touch the legs and the metal thing on the PCB at the same time with your iron. Plus, I would recommend you clean out the flux residue using isopropyl.
Logged
MMB
Reply #6 on:
Wed, 25 July 2012, 19:27:42 »
Here is your problem:
You broke the trace next to the eyelet.
Logged
limmy
Reply #7 on:
Wed, 25 July 2012, 19:32:57 »
Nice catch, MagicMeatball! High resolution photo FTW!
Logged
MMB
Reply #8 on:
Wed, 25 July 2012, 19:34:50 »
I typically use a trace pen, you can get at Radio Shack, usually. Or you can try to solder it together. Would require much care in doing so, though.
Logged
Lethal Squirrel
Thread Starter
I <3 60%
Reply #9 on:
Wed, 25 July 2012, 19:45:12 »
Thanks much for the help! I just used a tiny little piece of wire to bridge it. Works great! typing on it right now :3
Last Edit: Wed, 25 July 2012, 19:58:15 by Lethal Squirrel
Logged
MMB
Reply #10 on:
Wed, 25 July 2012, 19:50:27 »
Are ou t ping on it now?
Logged
Lethal Squirrel
Thread Starter
I <3 60%
Reply #11 on:
Wed, 25 July 2012, 19:57:47 »
YYYYYYYYYYYYYYYYYYYes I am!!!!!
Logged
MMB
Reply #12 on:
Wed, 25 July 2012, 19:59:12 »
Logged
Lethal Squirrel
Thread Starter
I <3 60%
Reply #13 on:
Wed, 25 July 2012, 20:04:02 »
xD made me lol
Logged
Print
Pages: [
1
Go Up
« previous
next »
geekhack
geekhack Community
Keyboards
Y key won't work
