Author Topic: fancy 104 sets of Cherry Corp 2-tone PBT lasered KeyCaps?  (Read 2381 times)
Offline spolia optima
« on: Thu, 26 July 2012, 06:21:47 »
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=130736288008&ssPageName=ADME:B:SS:US:1123#ht_1367wt_1168
I'm sure it would need a moogle kit for matching filco/leo/ducky/etc... Oh well, that's cherry corp for you!
besides, PCB mounted offers a far better typing experience and that's the cold hard truth oops how'd that get there
My plan is to replace the innards (nappy MY switches) with the guts of a G80-3000 MX. Yummers.
« Last Edit: Thu, 26 July 2012, 06:28:18 by spolia optima »
keyboards!
Offline sth
  • 2 girls 1 cuprubber
Re: fancy 104 sets of Cherry Corp 2-tone PBT lasered KeyCaps?
« Reply #1 on: Thu, 26 July 2012, 17:00:29 »
Spolia - the modifiers should work fine. you learn something new every day... thanks lysol :)
You might need a different spacebar. Caps should work too if you are using a g80.
The case is slightly different and will require some dremeling to get a few support posts out of the way. I've been planning on doing the very same mod for a while now but have just been a bit too busy to get around to it.
« Last Edit: Thu, 26 July 2012, 18:00:08 by sth »
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #2 on: Thu, 26 July 2012, 17:54:55 »
Nope, MY 1.25 keys have a stupid off center stem for no reason. Also the stabilzed keys will only work with costar style as they have wire clips as part of the keycap like on shifts, enter, etc and MY and MX controller pcb are generally not interchangeable so that nice 4 port usb hub... so in short it would be a lot more effort that it's worth probably.
Price is not too bad, could make a soft MY board by removing the springs from the switches, it is not great but a big improvement.
Offline sth
« Reply #3 on: Thu, 26 July 2012, 17:59:40 »
Cool, I will update my post to reflect. Are the stabilizer bits actually molded on? I have a 3700 with lasered PBT and the enter and + are normal cherry style. I also have had MY doubleshot boards that have cherry stabilizers that are not built in to the key.
« Reply #4 on: Thu, 26 July 2012, 18:56:09 »
Yes the stab 'clips' are part of the keycap, but only applies to most recent MY PBT, I haven't seen them do it on the pom version yet, and of course they did use the same doubleshots for both back then. No clue why Cherry does some of these things, seems it would be cheaper to only have one keycap mold and use it for everything.
« Last Edit: Thu, 26 July 2012, 19:00:11 by lysol »
