Author Topic: A question about SP PBT and KBC PBT, any different?  (Read 8932 times)
Offline qtan5370
« on: Fri, 27 July 2012, 00:45:06 »
Any different between SP made PBT caps and KBC made PBT?
I mean, consider the thick ,height, size etc.
Can people own both tell me about this?
Thanks a lot.
Look for Keyboard? Check my offers. I have most major keyboard and some caps for you, if you don\'t see it there, ask me. I am Top rated seller on eBay now, and have retail store in China selling keyboard and other gaming staffs.
My eBay store http://stores.ebay.com/E-sports-Gaming-equipments?_rdc=1
My store(lower price than eBay): http://www.keyboardwow.com
Offline WRXChris
Re: A question about SP PBT and KBC PBT, any different?
« Reply #1 on: Fri, 27 July 2012, 01:08:37 »
SP PBT caps are lower profile (height) than KBC PBT caps.  They are very similar in thickness, the SP cap may be slightly thicker but I don't have a micrometer to verify.
KBC cap is black, SP is brown.  Both caps are R4.
Offline ZcHuer
« Reply #2 on: Sat, 28 July 2012, 08:21:30 »
KBC also has thick and cherry profile PBT key caps ...
fartq
  •  Guest
« Reply #3 on: Sat, 28 July 2012, 08:25:26 »
imsto can produce thicker cherry profile PBT caps. he has never branded them as KBC afaik.
i do have a micrometer, and iirc the KBC and SP PBT caps are both about 1.0mm thick (+/- reasonable tolerances)
Offline TheSoulhunter
  • ~ BOOO ~
« Reply #4 on: Tue, 31 July 2012, 08:23:50 »
Seems the SP caps lack the nice texture of the KBCs :(
A Ghost From The Past
« Reply #5 on: Tue, 31 July 2012, 09:44:02 »
I don't know about KBC's PBT, but SP's PBT is certainly quite nicely textured. I have a whole 'board with it that I used every day for a long while, and SP's PBT was more than adequate.
Offline tsangan
  • 1000/600
« Reply #6 on: Tue, 31 July 2012, 09:53:12 »
SP PBT feels better then any PBT KBC has put out so far
thick keycap =/= always good
Keyboardless
Offline kaiserreich
  • HHKB Elite
« Reply #7 on: Fri, 03 August 2012, 10:42:46 »
It's the texture that counts
  • ~ BOOO ~
« Reply #8 on: Fri, 03 August 2012, 11:27:28 »
...but SP's PBT is certainly quite nicely textured.
On the image they look smooth/non-textured,
perhaps just the top of the cap is textured?
Offline jil_jil32
  • Tokyo Press <3
« Reply #9 on: Fri, 03 August 2012, 11:36:26 »
Yep, only the top of SP's PBT keycap is texture, same with the ABS cap I think.
Offline nntnam
« Reply #10 on: Sat, 04 August 2012, 04:27:23 »
Where do you find this brown SP PBT cap? I see the text on it, so is it dye-sub PBT? Have never seen any group buy on the brown dye-sub PBT.
Btw, I have a PBT dye-sub keyset from SP, and the texture on it gives me very nice feeling and may be as nice as the texture on topre's caps. The texture on KBC PB,T in some ways, feels like the SP ABS,  rougher than SP PBT.
« Last Edit: Sat, 04 August 2012, 04:32:43 by nntnam »
░▒▓ KMAC | FILCO MJ2 | HHKB | PHANTOM ▓▒░
Offline jil_jil32
  • Tokyo Press <3
« Reply #11 on: Sat, 04 August 2012, 04:31:00 »
Offline MMB
« Reply #12 on: Sat, 04 August 2012, 04:31:27 »
It looks to be the same color as the dyesub Pedobear keycap.
Offline nntnam
« Reply #13 on: Sat, 04 August 2012, 04:33:57 »
Aww, See that, thanks MMB, jil_jil32.
