Author Topic: Are Key Cool keyboards plate mounted?  (Read 3849 times)
Offline Lethal Squirrel
  • I <3 60%
« on: Fri, 27 July 2012, 10:41:54 »
Title says it.  ;D
Offline therecorder
Re: Are Key Cool keyboards plate mounted?
« Reply #1 on: Fri, 27 July 2012, 12:16:17 »
  • I <3 60%
« Reply #2 on: Fri, 27 July 2012, 20:38:18 »
That doesn't really answer my question. all he says is it has an improved PCB. that doesn't mean its not plate mounded. Unless I'm missing something. :\
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #3 on: Fri, 27 July 2012, 20:46:44 »
It's essentially Leopold's brother with costar stabalizer, and yes it is plate, just as Leopold. They are like a Frankenstein of Leopold fc700 pcb and fc200 case for less cost basically.
  • I <3 60%
« Reply #4 on: Fri, 27 July 2012, 21:05:26 »
Thanks much!
Offline therecorder
« Reply #5 on: Fri, 27 July 2012, 21:40:11 »
Sorry about the hastiness and incompleteness of my answer...  Glad Lysol made everything clear.
  • I <3 60%
« Reply #6 on: Sat, 28 July 2012, 00:28:48 »
It's no problem :)
Offline WRXChris
« Reply #7 on: Sat, 28 July 2012, 02:04:53 »
wow you guys just gave me a great idea; I've thinking about your poker plate mod, Lethal Squirrel, and where to get a cheap plate with costar stabs to make a filco-esque poker, and I think you just answered my question!  If only they made a board with MX clears for harvesting...
Offline therecorder
« Reply #8 on: Sat, 28 July 2012, 02:15:06 »
http://item.taobao.com/item.htm?id=13514954417
I bought one of each of the listed Keycool keyboards (White87, Black87, & White84).  They are LE Editions, with Clears, but they are about $20 more than a regular Keycool.  Got them using Qtang as an agent.
Offline WRXChris
« Reply #9 on: Sat, 28 July 2012, 02:40:05 »
thanks, I'll look into that!  Sucks that I only have 2 pokers and 2 plates already otw and will probably be able to find some clear stems before the plates arrive, but the costar stabs sure are tempting!
Offline WRXChris
« Reply #10 on: Sat, 28 July 2012, 06:09:09 »
I just realized that the leopold spacebar puts the switch in the wrong place for a poker. Damn.
« Reply #11 on: Sat, 28 July 2012, 08:16:19 »
Spacebar switch has the correct placement, it's the stabilizers spacing that is closer together. If you are considering getting one to cut up for modding, punching 2 new stab mounts in the plate shouldn't be too difficult. I strongly considered doing that on one of the Leopolds I owned so I could use regular spacebars instead of modding the spacebars all the time, just fix the cause of the problem.
