Author Topic: key-bored.net  (Read 21843 times)
Offline longweight
  • philanthropist
key-bored.net
« on: Sat, 28 July 2012, 06:28:15 »
Hi all,
I have put a review of my HHKB2 on my site, hopefully it will add something to the community!
http://www.key-bored.net/happy-hacking-keyboard-hhkb2/
« Last Edit: Sat, 28 July 2012, 14:08:12 by longweight »
Offline longweight
  • philanthropist
Re: HHKB2 Review
« Reply #1 on: Sat, 28 July 2012, 07:07:48 »
Can someone please tell me who created the GIF's I have used in the switch guide? I wanted to ask permission but I put that up during the outage so couldn't ask.
Offline longweight
  • philanthropist
Re: key-bored.net
« Reply #2 on: Sat, 28 July 2012, 14:08:47 »
Offline Lethal Squirrel
  • I <3 60%
Re: key-bored.net
« Reply #3 on: Sun, 29 July 2012, 08:45:38 »
I made them : )
It's okay if you use them  :D
Offline longweight
  • philanthropist
Re: key-bored.net
« Reply #4 on: Sun, 29 July 2012, 08:59:19 »
Thank you!
Want me to credit you for them?
  • I <3 60%
Re: key-bored.net
« Reply #5 on: Sun, 29 July 2012, 09:05:11 »
Nah you don't really have to. It's all good.
Offline longweight
  • philanthropist
Re: key-bored.net
« Reply #6 on: Sun, 29 July 2012, 09:52:23 »
Thanks :) I'd love to create one for Topre but my image editing-fu is weak.
  • I <3 60%
Re: key-bored.net
« Reply #7 on: Tue, 31 July 2012, 22:07:30 »
Are you challenging me?! It's on!
« Last Edit: Tue, 31 July 2012, 22:12:32 by Lethal Squirrel »
Offline longweight
  • philanthropist
Re: key-bored.net
« Reply #8 on: Wed, 01 August 2012, 06:01:57 »
That wasn't my intention but it would be amazing if you did!
  • I <3 60%
Re: key-bored.net
« Reply #9 on: Wed, 01 August 2012, 09:51:46 »
I'm making it now! it should take a few days though.
Offline longweight
  • philanthropist
Re: key-bored.net
« Reply #10 on: Wed, 01 August 2012, 10:00:31 »
You legend!
Offline OddOne
Re: key-bored.net
« Reply #11 on: Wed, 01 August 2012, 11:52:12 »
K60 review: http://www.key-bored.net/corsair-k60/
Hey longweight,
Something I've been wondering since first seeing the K60... could it be modded to be fully mechanical?  i.e. would a cherry switch fit in the cutout where the rubber domes poke through?  I know there would be a few other hurdles to get past a well (i.e. spider web of wires...), but if the switch won't fit, that kinda ends the idea right there...
|  CM Quickfire Rapid   |   Rosewill RK-9000BR  |  CM Quickfire Rapid  |
Offline kaiserreich
  • HHKB Elite
Re: key-bored.net
« Reply #12 on: Tue, 14 August 2012, 08:03:44 »
dat grass
Offline longweight
  • philanthropist
Re: key-bored.net
« Reply #13 on: Tue, 14 August 2012, 08:21:39 »
Hey longweight,
I'm not too sure! It's a possibility but I didn't take it apart to have a look. Do rubberdomes have the same pinout as MX switches?
Offline OddOne
Re: key-bored.net
« Reply #14 on: Tue, 14 August 2012, 21:13:03 »
No, you would need to run wires to each switch and then run them back to the circuit board. I assume there is some sort of connector between the RD and main board. Would be quite a challenge, but possible. But again if the switches wouldn't fit, it would be a show stopper.
If I ever see one for cheap, I might give it a go...
Offline hazeluff
  • 光復香港
    • Hazeluff
Re: key-bored.net
« Reply #15 on: Tue, 14 August 2012, 21:59:13 »
I'd like to use it if you are willing to share with all of us = 3
Fight For Freedom. Stand with Hong Kongers
Re: key-bored.net
« Reply #16 on: Tue, 14 August 2012, 23:37:33 »
Offline longweight
  • philanthropist
Re: Re: key-bored.net
« Reply #17 on: Tue, 14 August 2012, 23:59:31 »
Re: key-bored.net
« Reply #18 on: Wed, 15 August 2012, 00:04:05 »
dat grass
Is plastic.  Isn't it??
Might be....
Either that or someone has cut each blade of grass individually ;-)
