Author Topic: was replacing key caps and this friken happened....  (Read 4541 times)
Offline phx
« on: Mon, 30 July 2012, 08:36:13 »
installed a couple of red key caps yesterday but decided to switch it back in morning, pulled it out and this happened...
tried to just insert it back but it's next to impossible, what do I do now?
Offline boost
  • BOSTMOBILE
  • NY Giants!!!
Re: was replacing key caps and this friken happened....
« Reply #1 on: Mon, 30 July 2012, 08:40:37 »
Install a new switch. It's pretty cheap but you need know how to solder.
Magicmeatball can do it for you.
-Enzo Ferrari
Offline phx
« Reply #2 on: Mon, 30 July 2012, 08:44:12 »
I'm trying to take off the plate but even that's impossible >.>
removed 5 scrolls, think that should be all of them.
I know how to solder, if I remove the key would I be able to put it back together or do I have to buy new ones?
Offline alaricljs
  • I be WOT'ing all day...
« Reply #3 on: Mon, 30 July 2012, 08:47:50 »
Switches are easily taken apart and put back together, only question is whether the housing or stem got damaged.
Filco w/ Imsto thick PBT
Offline longweight
  • philanthropist
« Reply #4 on: Mon, 30 July 2012, 08:48:11 »
You can't remove the plate without desoldering all of the switches.
Offline alaricljs
« Reply #5 on: Mon, 30 July 2012, 09:01:40 »
I was under the impression he was talking about extracting it from the case... but yeah, you need only desolder the 1 broken switch and go from there.
Offline phx
« Reply #6 on: Mon, 30 July 2012, 09:04:05 »
well, I managed to force it back in, might have slightly broken it.
now onto more bad news, I was washing it yesterday afternoon, aired it dry until this morning, plugged it in and it wasn't recognized... either I broke the keyboard replacing the switch or worse I permanently broke it because it's not fully dry yet.
Offline longweight
  • philanthropist
« Reply #7 on: Mon, 30 July 2012, 09:10:21 »
How did you wash it?
Offline phx
« Reply #8 on: Mon, 30 July 2012, 09:18:26 »
just rinsed it with warm water.
Offline alaricljs
« Reply #9 on: Mon, 30 July 2012, 09:23:00 »
Jamming the stem back in would at worst have forked that 1 key, the rest of the board should function properly.  Watch for the blinkin LEDs on USB init and should give you more info on how the controller is behaving.
Offline longweight
  • philanthropist
« Reply #10 on: Mon, 30 July 2012, 09:26:40 »
You rinsed the PCB with water? Did you get the USB controller wet? How long did you leave it to dry?
Offline phx
« Reply #11 on: Mon, 30 July 2012, 09:38:29 »
I left it to dry for around 15 hours.
when plugged in it just says unrecognized USB device and all the LEDs are on.
now it's sitting next to the window drying again.
Offline longweight
  • philanthropist
« Reply #12 on: Mon, 30 July 2012, 09:44:25 »
Hopefully it will have only bridged a couple of irrelevant tracks, if it has bridged something bad then it might be dead...
Offline phx
« Reply #13 on: Mon, 30 July 2012, 09:56:25 »
yep, fingers crossed.
thanks for all the help guys :D
Offline Rafen
« Reply #14 on: Mon, 30 July 2012, 11:02:02 »
I did this to my board about 2 weeks ago. The key I was putting on was made way to tight to even fit on the stem. All I did was desolder  the switch and opened the housing and put the stem back in and soldered it  back. It only took me about half an hour. So if the keyboard starts to work again just do that and it will be like a new again. Just make sure when you are removing caps that you wiggle the keycaps off and don't just "yank" them.
Good luck and hope everything works out.
Offline dotancohen
    • Dotan Cohen
« Reply #15 on: Mon, 30 July 2012, 14:01:16 »
Finally, someone figured out how to swap the springs on a plate-mounted cherry. Thanks, I'm getting to work now!
Offline Rafen
« Reply #16 on: Tue, 31 July 2012, 05:28:11 »
I really hope your not serious? If you are I hope you have a blast trying to get the stem back in the housing without trying to desolder  the switch from the plate.
Offline Christown
  • MX Blue >
« Reply #17 on: Tue, 31 July 2012, 07:15:13 »
Yeah i don't think it was a serious post, has sarcasm written all over it lol.
Offline Rafen
« Reply #18 on: Tue, 31 July 2012, 15:20:07 »
Yeah I think it was too early in the morning for me to comprehend that post haha.
Offline dotancohen
    • Dotan Cohen
« Reply #19 on: Wed, 08 August 2012, 05:26:10 »
Since the housing cracked it was actually quite easy to get back in. But it seems that the super glue dripped down inside, I can't press the button any more. Good thing that I tested only on the Scroll Lock switch. I'll test using thick epoxy on the Pause switch next.
Offline daerid
    • Rossipedia
« Reply #20 on: Wed, 08 August 2012, 10:55:13 »
I've never heard of somebody washing a PCB. My first reaction is: are you nuts? In my experience, electronics and water never mix, no matter how long you let something dry.
Offline thegunner100
  • (╯'□')╯︵</3 ノ( '-'ノ)
    • The Emotional Skyscraper
« Reply #21 on: Wed, 08 August 2012, 10:57:36 »
When has water-immersion been a good thing for exposed electronics?
Input Devices:CM QF Rapidx2 ~ REALFORCE 87uw 45/55g ~ Logitech G5v2 ~ Wacom Bamboo CTH-460
Audio Setup: look me up on head-fi
Check out my blog on touhou/doujin music, audiophile gear, and doujin games!
Offline nala
  • sup son ¯\_(ツ)_/¯
« Reply #22 on: Wed, 08 August 2012, 16:45:59 »
You can soak it with alcohol and then turning it on fire. That might fix the switch and will also help drying the PCB.
Just like this:
Collection: Filco Majestouch-2 TKL ~ Filco Majestouch-2 TKLRazer BlackWidowUltimate
Offline daerid
    • Rossipedia
« Reply #23 on: Thu, 09 August 2012, 10:49:04 »
Maybe it's just how much I've spent on keyboards in the last few years, but that pic is stirring some serious rage
« Reply #24 on: Fri, 10 August 2012, 02:10:16 »
It's okay: Looks like a pad-print ABS RD to me. Now if those cyrillic legends were dyesub cherry, I'd be mad.
Having to repair (and replace) a large number of keyboards that have been damaged by water, beer wine, vodka, juice, soda, and apple sauce really lets me keep my cool when seeing other damaged 'boards.
