Author Topic: Black on Black - filco majestouch 2 tenkeyless  (Read 8282 times)
Offline nh3728
« on: Tue, 31 July 2012, 04:06:52 »
HI GH!
I am looking for some black on black key-caps for my filco majestouch 2 tenkeyless, UK Layout.
Something like this topre keyboard.
Any suggestions where i can get some?
Thanks
Offline peizilla
Re: Black on Black - filco majestouch 2 tenkeyless
« Reply #1 on: Tue, 31 July 2012, 06:11:15 »
You're probably looking for a PBT black laser engraved kit then.
http://www.vendio.com/stores/E-sports-Gaming-equipments/item/pbt-key-caps/87-set-pbt-black-engraved-keyc/lid=18974429
Or alternativly, you can stay around for a group buy or a seller from the classifieds.
« Last Edit: Tue, 31 July 2012, 06:16:16 by peizilla »
Offline nh3728
« Reply #2 on: Tue, 31 July 2012, 06:17:09 »
I don't want them engraved. Thats why i posted the related picture.
I have no idea what technique they use to make black-printed(lasered) on black/dark grey keycaps.
« Last Edit: Tue, 31 July 2012, 06:27:42 by jrdjarrold »
« Reply #3 on: Tue, 31 July 2012, 09:42:43 »
They use Dye-sublimation on PBT plastic. The plastic is dark gray, and the dye is black. I had heard that Vortex was wanting to make keycaps like that, though who knows if they'll ever actually do it.
Offline nh3728
« Reply #4 on: Tue, 31 July 2012, 09:53:12 »
thanks. Is ' Vortex' a website/company or somebody on the marketplace section? Link if possible. thanks buddy.
Offline Xerobasix
« Reply #5 on: Tue, 31 July 2012, 21:34:33 »
like these?
http://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=69
edit: although, those have some led cut outs...
« Last Edit: Tue, 31 July 2012, 21:37:35 by Xerobasix »
CM Quickfire Rapid - Brown | Blue | Red
« Reply #6 on: Tue, 31 July 2012, 21:40:32 »
thats engraved.
he wants black legends
Offline MMB
« Reply #7 on: Tue, 31 July 2012, 21:43:06 »
I think we can bank on them not doing it. But you never know.... lulz.
Offline magnetic
    • Slighted
« Reply #8 on: Wed, 01 August 2012, 11:15:13 »
I've been looking for dark grey caps with black lettering for a good while (also uk iso filco tkl), and had no luck.
the closest i've come is SP but it costs almost the same as a decent keyboard to have them make a set just for you.
i've gone with the engraved set for now, had to order a few iso caps from wasd to make up for the fact that NO ONE LIKES ISO :(
« Reply #9 on: Wed, 01 August 2012, 19:16:10 »
Full PBT set from SP should be about $95, as long as you can get 25 orders. Be happy you don't have topre, they have that colour scheme, but it costs even more for a full set. Unfortunately, PBT is expensive.
