Author Topic: everytime I try to open a link with geekhack.org  (Read 6391 times)
Offline FinancialWar
« on: Tue, 31 July 2012, 09:22:26 »
no input file specified error
User chrome on windows 7 64bit.  Any hints
fartq
  •  Guest
Re: everytime I try to open a link with geekhack.org
« Reply #1 on: Tue, 31 July 2012, 09:40:37 »
i'm not sure what you mean by this. can you give me an example url?
Offline alaricljs
  • I be WOT'ing all day...
« Reply #2 on: Tue, 31 July 2012, 10:33:28 »
That's the error when you try an old vB link.
Filco w/ Imsto thick PBT
fartq
  •  Guest
« Reply #3 on: Tue, 31 July 2012, 17:32:35 »
rknize should be pushing in something that fixes up old links transparently later today (may be already in there?)
Offline rknize
    • metaruss
« Reply #4 on: Tue, 31 July 2012, 18:15:31 »
showthread.php links should work.  showwiki.php links are momentarily disabled.
Russ
