Author Topic: spilled fanta onto filco keyboard  (Read 5557 times)
Offline FinancialWar
« on: Tue, 31 July 2012, 09:26:53 »
hello guys, it's been a while.
unfortunately I spilled some fanta onto my filco 104, what should I do.
ps. please don't provide me links to another geekhack thread, for some reason I get the "no file input specified" error.
Offline Lethal Squirrel
  • I <3 60%
Re: spilled fanta onto filco keyboard
« Reply #1 on: Tue, 31 July 2012, 09:45:23 »
I would desolder all the switches, and take each one apart and clean it. It sounds kinda crappy, and a ton of work, but I think that's all you can really do. :c
I tried putting my Blackwidow in the dishwasher when I spilled rockstar on it, but It made the switches barely clicky.
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #2 on: Tue, 31 July 2012, 09:59:36 »
Define 'some' a few drops between a few switches, the entire bottle over the entire board? Sugar waters are the worst to deal with, but if it's a small amount it may not be too bad assuming you did unplug it right away of course.
Offline Zykos
« Reply #3 on: Tue, 31 July 2012, 17:59:21 »
I would thoroughly clean it before using it.
« Reply #4 on: Tue, 31 July 2012, 21:07:02 »
what about sink it in distilled water?
  • I <3 60%
« Reply #5 on: Wed, 01 August 2012, 00:21:40 »
It should be okay, But I doubt it will ever feel the same :(
« Reply #6 on: Thu, 02 August 2012, 09:32:29 »
so basically after one spill, the keyboard is dead weight either way.
Offline WRXChris
« Reply #7 on: Thu, 02 August 2012, 10:04:35 »
not necessarily, but as someone else mentioned, sugar water is one of the WORST things that can happen to mechanical devices.  You could try to clean it with water, but if the soda made it into any of the switches the only way to restore them to their original condition would be to desolder, disassemble, thoroughly clean, and resolder any sticky switches. Good luck!
Offline jellowiggler
« Reply #8 on: Thu, 02 August 2012, 13:32:13 »
Dishwasher time!
Mike -jellowiggler-
Filco MJ2 Tenkeyless / Rosewill RK-9000 / IBM Model M 1391401 / Logitech DiNovo Edge / MS Sidewinder X4
Offline Djuzuh
« Reply #9 on: Thu, 02 August 2012, 15:07:45 »
Dishwasher time!
Don't dishwash a mechanical keyboard.
It's not a rubberdome.
Offline nala
  • sup son ¯\_(ツ)_/¯
« Reply #10 on: Fri, 03 August 2012, 21:21:18 »
Just try cleaning it with distilled water and canned air. I have a Filco TKL w/ blues that I spilled vitamin water on and even though I was able to remove almost all the sugar remains from it, it still clicks, but the sound and feel is completely different. If you don't mind about that, then you're good. Just put the keyboard upside down and try to pour distilled water inside the switch and canned air to remove the sugar remains.
Remember to make sure it dries completely before connecting it, so give it 3 or 4 days, just to be completely sure that moist isn't inside.
Collection: Filco Majestouch-2 TKL ~ Filco Majestouch-2 TKLRazer BlackWidowUltimate
Offline whiskerBox
« Reply #11 on: Fri, 03 August 2012, 22:02:52 »
Seems like every 3 months or so 1 of these spilled threads pops up. Makes me nervous.
"I'm on a mission to bring down GH's anarchy of moderators" -RIPSTER jr.
  • I <3 60%
« Reply #12 on: Fri, 03 August 2012, 22:09:33 »
I spilled rockstar energy drink on my first mechanical a week after I got it. Didn't care much, it was a blackwidow xD
Offline thegunner100
  • (╯'□')╯︵</3 ノ( '-'ノ)
    • The Emotional Skyscraper
« Reply #13 on: Fri, 03 August 2012, 22:29:31 »
Hmm, where's ripster's info when we need it...?
Input Devices:CM QF Rapidx2 ~ REALFORCE 87uw 45/55g ~ Logitech G5v2 ~ Wacom Bamboo CTH-460
Audio Setup: look me up on head-fi
Check out my blog on touhou/doujin music, audiophile gear, and doujin games!
« Reply #14 on: Sat, 04 August 2012, 06:52:04 »
I have dismantled the keyboard up to this point, I don't know how to take the keys from the backboard, what should I do from here?
20120804_212416 by 日本光学, on Flickr
Offline Djuzuh
« Reply #15 on: Sat, 04 August 2012, 07:00:31 »
you need to desolder them if you want to go any further
Offline Christown
  • MX Blue >
« Reply #16 on: Sat, 04 August 2012, 07:06:06 »
Looks very dirty and sticky, not a pretty sight.
You'll have to desolder each switch from the back of the pcb, clean them and then resolder them back on.
« Last Edit: Sat, 04 August 2012, 07:07:50 by Christown »
Offline cactux
  • Topre Knight
« Reply #17 on: Sat, 04 August 2012, 07:06:12 »
0) Disconnect the keyboard
1) Remove all the keycaps using a keycap puller
2) Get Isopropyl alcohol and some Q-tips, cotton balls
3) Look for all the sticky spots and clean with the Qtip+ Isopropyl alcohol
4) Try to remove all the sugar  from the surface, switches and from the pcb.
5) Try to find out if  the soda did not go inside the switches (sticky spots)
   a) If the soda went inside the  switch, you may have to open an clean the switch.
The sad story
Fanta lovers
http://www.overclock.net/t/1257257/spilled-coke-into-my-mechanical-keyboard#post_17299358
Interesting Approach
Remove Keycaps
Open Filco
Open Switches
Order some stuff on line
http://www.jaycar.com.au/
a) Isopropyl Alcohol 99.8%
http://www.jaycar.com.au/productView.asp?ID=NA1066
b) Isopropyl Alcohol Cleaning Pads
http://www.jaycar.com.au/productView.asp?ID=NA1060&CATID=75&form=CAT2&SUBCATID=961#1
c) keycap puller
  http://www.auspcmarket.com.au/info/KE-FKP01/1948/
« Last Edit: Sat, 04 August 2012, 07:40:37 by cactux »
[FS]☠ The temple lol ->HERE<-
« Reply #18 on: Sat, 04 August 2012, 08:16:53 »
is desolder and resolder a complicated process?
Offline longweight
  • philanthropist
Re: Re: spilled fanta onto filco keyboard
« Reply #19 on: Sat, 04 August 2012, 10:34:45 »
No but it will take ages!
Offline nala
  • sup son ¯\_(ツ)_/¯
« Reply #20 on: Sat, 04 August 2012, 18:11:50 »
If you got skills to desolder and resolder and do it clean, then go for it. You got nothing to lose, your keyboard is kinda ****ed up (in case some keys are really sticky) so just take the risk and hope for the best.
« Reply #21 on: Mon, 06 August 2012, 00:17:18 »
I decided not to desolder and resolder because
1. Don't have the knowledge or skilled to do it properly.
2. Don't have the time.
3. Too much risk of wrecking the keyboard physically.
So I bought one liter bottle of distilled water, waited until noon time when the sunlight is the strongest, pour the distilled water over the sticky switches and pressed the button repeated, I proceeded to empty the whole bottle over the board and the back. The board was soaked in water inside out, then I shake the water out and left it in the sun for rest of the afternoon. reconnected the cable, test it and it worked like new, the sticky keys are back to normal responsiveness, no damaged to electronic components.
The only thing is that I have now void the warranty by take the keyboard apart.
Offline Neo.X
« Reply #22 on: Wed, 08 August 2012, 15:39:06 »
WOW, it's amzing, I don't know you can fix the keyboard like this. Thanks for sharing
All those keyboards will be lost in time....
Offline Djuzuh
« Reply #23 on: Wed, 08 August 2012, 15:56:16 »
Only as extreme solution. Mech keyboards don't like water.
Offline nala
  • sup son ¯\_(ツ)_/¯
« Reply #24 on: Wed, 08 August 2012, 16:39:23 »
I'm glad that worked. You had nothing to lose so yeah, it was either desolder and solder or 'soak' it in distilled water. It would've been ideal if you only did it on the affected keys, but at least it worked. You might want to try putting some lubricant back in the switches and the stabilizers as probably most of it wore off with the Fanta and the distilled water. PFTE dry lube works amazing on Cherry MX switches, and for the stabilizers you can get the grease that EKB sells that works really good too: http://elitekeyboards.com/products.php?sub=access,misc&pid=mechlube
Offline Gerk
« Reply #25 on: Wed, 08 August 2012, 23:00:52 »
I think you voided the warranty right about the time the fanta hit the PCB personally  :p
Glad it worked out for you though, you got lucky.
Rosewill RK-9000RE (reds) | Das Keyboard Model S Professional Silent (browns) | Leopold TKL (browns) | F21-7D "Mechanical Keyboard" (Blue Alps) | Filco Majestouch TKL (blues) | Goldtouch V2 x 2 | Matias Ergo Pro x 2 | Kinesis Freestyle Pro (browns) | Kinesis Freestyle Edge (reds)
