Author Topic: Battle Of The Esc Keys  (Read 14868 times)
Offline rdjack21
« Reply #50 on: Wed, 12 August 2009, 22:21:27 »
Quote from: quadibloc;109328
I would have to admit that I'd be unlikely to choose the version with blank keycaps. And having to shift in order to use the backspace key does strike me as odd; why do pencils have erasers?
Well actually it has a dip switch where you can change that. You can either have Backspace or delete as the primary. I flipped that switch on mine because I use it more than the delete key.
Keyboards
Topre Capacitive: Realforce 87U, Realforce 86U, HHKB Pro 2, Topre MD01B0, Topre HE0100, Sun Short Type, OEM NEO CS (x2), NISSHO Electronics KB106DE
Buckling Spring: IBM Model M Space Saver (1291472), Unicomp Customizer x 2
Cherry Brown: Filco FKBN87M/EB, Compaq MX11800
Black Alps: ABS M1
Not so great boards Rare Spring over dome OKI, Sun rack keyboard
Trackballs - Trackman Wheel (3), Trackman marble (2)
Keyboards I still want to get - Happy Hacking Keyboard Pro 2 the White version, Realforce 23U number pad in black and maybe white, μTRON ergo board with Topre switches.
Previously owned - [size=0]SiiG MiniTouch (White Alps), Scorpius M10 (Blue Cherry), IBM Model M13[/size]
Offline rdjack21
« Reply #51 on: Wed, 12 August 2009, 23:58:41 »
Quote from: ripster;109366
I use a kinda weird variation of the HHKB layout but it makes sense to me. \ becomes Backspace, BS becomes Delete.  That way I have easy access to both.   It corresponds to the HHKB layout when FCN key is used as a modifier.  The rest of the FCN Key HHKB layout is garbage to me because I want to use my right hand less not more so I shift it over to Raj's left handed WASD layout.
I'm the opposite I use my left hand quite a bit (Alt/Control combo keys) in the code editors I use all day. So the right hand Fn key actually moves some of the work over to my right hand which helps balance things a little better. Even though it would be nice to have a Fn key on the other side of the board. I actually figure that is why they put the Fn key on the right to begin with. It is called the Happy Hacking Keyboard for a reason. It was orginally layed out for coders who heavily use Ctrl and Alt all the time. And to be honest the more I use it the more I like it. But I would swap Home/End with PgUp/PgDn mostly because I use them more and where they are at is a streach.
« Last Edit: Thu, 13 August 2009, 00:00:54 by rdjack21 »
Keyboards
Black Alps: ABS M1
Offline megarat
  • (Not My Real Name)
    • http://www.megarat.com
« Reply #52 on: Fri, 14 August 2009, 15:34:29 »
I just posted about this in the eBay finds forum, but here's another (presumably) unmodded, wild-type keyboard with a red escape key.
Here's the item photo, transplanted:
Home/Work:  Custom Filco FKBN87Z/EB and SGI 041-0136-001 chimera (original white ALPS, not simplified, rubber-dampened)
Gaming:  Wolfking Warrior with custom-colored layout, HHKB Lite 2 (Rubber dome)
Offline cmr
« Reply #53 on: Fri, 14 August 2009, 17:09:27 »
Quote from: itlnstln;107130
You know what, that was it.  I remember I was looking for a "Panic" button.  I think bhtooefr has one that was a Cherry replacement key, or something, and I went to search Google to fime something similar.  The ones I had originally found were adhesive (not stickers like Hooleon's, though).  Nevermind.
iFail.
my 'X%&#!' key had an adhesive pad on the bottom, but when i peeled it away, behold, it was merely a cherry key cap.
Offline quadibloc
  • Layout Fanatic
    • John Savard's Home Page
« Reply #54 on: Fri, 14 August 2009, 20:44:55 »
Quote from: megarat;109774
I see that your link reveals what I was going to mention - that this keyboard is from the EPSON QX-10 computer, the one with the VALDOCS operating system to protect your valuable documents.
In the meantime, I took another look at the Happy Hacking keyboard, thought about it, and came up with a suggestion for something more moderate with wider appeal. Remember that the original PC keyboard combined the numeric keypad with the cursor keypad? That would be one way of "getting rid of" most of the space the numeric keypad takes up without losing it entirely.
Well, why not take it one step further, and also use the numeric keypad as a substitute for the function keys?
Offline nanu
    • http://T-T.be/portal
« Reply #55 on: Sat, 15 August 2009, 07:37:49 »
Quote from: ripster;109796
guy took a dremel tool, sacraficed a Cherry Key and epoxied on the stem.  That is a lot of work and requires more precision than it first looks.
I'm thinking I must do this now, to use arbitrary keycaps with a cherry stem.  It beats molding and casting which some kbdmaniacs are doing, since I'm reluctant to get all the stuff needed for that..
What I first tried for stem conversion is epoxying aquarium tubing, but it's flexible material.  The current revision is to use a straight pin through the tubing as an anchor so it stays on longer.
It is noticeably wobbly—if you strike the key oddly, it will twist; a good sign to take a break, maybe.
Offline rdjack21
« Reply #56 on: Mon, 17 August 2009, 11:13:59 »
Quote from: nanu;109850
I may have to look that up. I keep thinking I want to try molding my own keys mostly so I can get some cupped keys on a modern keyboard. But also so I can play with different materials as well. Do you have a link to the thread for this?
Keyboards
Black Alps: ABS M1
Offline Bollwerk
« Reply #57 on: Mon, 17 August 2009, 16:16:57 »
Quote from: ripster;110195
EliteKeyboards now advertises the Red ESC key as a included item with their Filco Cherry Switch keyboards (he generally shipped them depending on availability gratis).
What? I ordered just recently, but befor that. I hope, I'll get one as well...^^
hope hope hope hope... xD
\\Cherry:
*G80-1800, G80-3700, G80-1000, G80-1501, G80-2550,
*G81-8308, G81-1800, G81-1000, G84-4100, G84-4700
\\Others:
*Chicony E8H5IKKB-5162
*Mtek FKF456K-104
*Filco FKBN87M/EB
Offline ohdh2003
metal esc keycap
« Reply #58 on: Fri, 21 August 2009, 08:43:00 »
Here are two examples of metal (aluminium) keycaps.
How much better to get wisdom than gold, to choose understanding rather than silver! [Proverbs 16:16]
Offline timw4mail
    • https://timshomepage.net
« Reply #59 on: Fri, 21 August 2009, 08:52:29 »
I want aluminum keycaps!
How do those feel in comparison to the plastic keycaps around them?
Buckling Springs IBM Model F AT, New Model F 77, Unicomp New Model M
Clicky iOne Scorpius M10, OCN-branded Ducky DK-9008-C, Blackmore Nocturna, Redragon Kumara K552-1, Qtronix Scorpius Keypad, Chicony KB-5181(Monterey)
Tactile Apple AEKII (Cream damped ALPS), Filco FKBN91M/JB (Japanese Tenkeyless), Cherry G84-5200, Cherry G84-4100LPAUS, Datalux Spacesaver(Cherry ML), Redragon Devarajas K556 RGB, Newmen GM711, Poker II (Cherry MX Clear), Logitech G910 Orion Spark, Logitech K840
Linear Lenovo Y (Gateron Red), Aluminum kiosk keyboard (Cherry MX Black)
Offline sixty
    • http://deskthority.net
« Reply #60 on: Fri, 21 August 2009, 09:10:29 »
Quote from: ohdh2003;111022
Wow this is totally awesome. Did the poster say how much one cost to make and how long it took?
Thanks for posting this!
Offline ohdh2003
« Reply #61 on: Fri, 21 August 2009, 09:37:58 »
Quote from: sixty;111031
I don't know the cost and time for making. They're maniatic production so, you may not buy them. I guess makers of them may not make anymore.
Offline ohdh2003
« Reply #62 on: Fri, 21 August 2009, 09:44:18 »
Quote from: timw4mail;111028
I have chance to touch an aluminum keycap, the red one. The weight was similar to plastic one. It was not much cold as I thought.
Offline lowpoly
« Reply #63 on: Fri, 21 August 2009, 09:46:10 »
Quote from: ohdh2003;111041
That's what I wondered. Thanks for posting these.
Offline keyb_gr
  • Cherrified user
    • My keyboard page (German)
« Reply #64 on: Fri, 21 August 2009, 10:58:49 »
I'd guess keeping the keycap mass down helps.
Offline ohdh2003
« Reply #65 on: Sat, 22 August 2009, 05:30:44 »
Quote from: ripster;111039
That is just awesome.  Check around KBDmania for details.
That PS/2 cord looks like it has been RitDyed!
Good observation:) that chord painted by sort of spray like this http://itempage3.auction.co.kr/DetailView.aspx?itemNo=a520189843&frm3=V2
Offline clickclack
  • Board Chow EXTRAORDINAIRE
« Reply #66 on: Tue, 25 August 2009, 16:46:04 »
This thread is really unhealthy :(
now all I want to do is mod the crap out of stuff (more so than I already do)
*smacks forehead*
I really need to find out which keyboards have what stem and what tolerances/heights so I can figure out what's compatible with what I have.
hmm.... *scurries off*...
« Last Edit: Tue, 25 August 2009, 16:47:14 by clickclack »
862+ keyboards and counting!   R.I.P.ster          Vendor link ->Clack Factory
Offline timw4mail
« Reply #67 on: Tue, 25 August 2009, 17:52:25 »
Anyone know of a way to get a set of blue aluminum keycaps?
Offline timw4mail
« Reply #68 on: Tue, 25 August 2009, 22:05:46 »
The double-shot molding on the Next keyboard certainly seems to be more precise than on the Cherry key, though.
Offline ohdh2003
« Reply #69 on: Wed, 26 August 2009, 07:05:59 »
Quote from: webwit;111845
More from those maniacs:
The more I see colored keys, the less I want them. Well, that's probably not entirely true. But that korean photo forum manages to make them look tired.
That's truly awesome. Because that was made with "gold". (You may know the gold protect for the teeth.) So that gold keycap is  very experimental and very expansive.
« Last Edit: Wed, 26 August 2009, 07:08:46 by ohdh2003 »
Offline Rajagra
« Reply #70 on: Wed, 26 August 2009, 08:00:30 »
Don't mean a thing if it ain't got that bling:
(doo-ah, doo-ah, doo-ah, doo-ah, doo-ah, doo-ah, doo-ah, doo-ah, doo-ah)
Offline itlnstln
« Reply #71 on: Wed, 26 August 2009, 08:06:56 »
Quote from: ripster;111908
Actually I think that's an optical illusion because of the different texture (the Cherry is pretty textured). If you look at the extreme closeup you can see the lines where the plastics meet.
That, and Cherry uses a goofy, bubbly font where NeXT, and everyone else, uses fonts with crisper edges.
Offline itlnstln
« Reply #72 on: Wed, 26 August 2009, 09:29:42 »
Quote from: ripster;112019
Bubbly font is an apt description. Any of our German members ever figure out what this font is??
Fugly Sans-Serif Bold
Offline Bollwerk
« Reply #73 on: Wed, 26 August 2009, 09:33:45 »
We've got something here called "Normschrift". It would be sort of standard lettering.
We use it for traffic signs, technical drawings and other stuff. It looks a lot like that.
EDIT: Maybe DIN ISO 3098
« Last Edit: Wed, 26 August 2009, 09:39:16 by Bollwerk »
\\Cherry:
\\Others:
*Mtek FKF456K-104
*Filco FKBN87M/EB
Offline quadibloc
  • Layout Fanatic
« Reply #74 on: Wed, 26 August 2009, 10:02:36 »
The sign in your photo appears to show printing in Copperplate Gothic.
I don't recognize the font in which the letter R is on the key in your photograph.
As to the letters on many computer keyboards in the old days, they are indeed drafting-style letters, made with a particular tool, about which information is available here:
http://www.mccoys-kecatalogs.com/KELeroy/1960Brochure/1960KELeroyBroch.htm
Because you can choose the diameter of the pen used in this, you can produce letters made from thin lines, or letters made from thick lines the rounded ends of which are obvious.
It's difficult to find photos of old-style computer terminals quickly on the Web, but in addition to my 122-key keyboard from Memorex-Telex, another example is at:
http://world.std.com/~jdostale/kbd/SpaceCadet.html
the famous Space Cadet keyboard. One recognizable thing about the font is the very wide % sign.
Offline itlnstln
« Reply #75 on: Wed, 26 August 2009, 10:21:46 »
Quote from: quadibloc;112033
This was in reference to a running joke.  The pic is from a show in the US called New Yankee Workshop where the host (in the pic), Norm, builds incredible furniture.  Ripster was playing on words using the host's name, Norm, as the joke.
Offline Bollwerk
« Reply #76 on: Wed, 26 August 2009, 10:24:31 »
Maybe it isn't standard lettering. Or an older one than the current. Frankly, I'm not sure, what the hell it could be...
\\Cherry:
\\Others:
*Mtek FKF456K-104
*Filco FKBN87M/EB
Offline clickclack
« Reply #77 on: Wed, 26 August 2009, 14:27:06 »
Quote from: ripster;112029
My family and I call him the anal retentive carpenter (everything he uses is like laser guided, screwdriver, ruler, bandsaw...haahaa)
Anywho.... moving on...
I just thought I would mention that I have seen many more rubber dome keyboards that have double shot keys than mechnaical boards. I just figured that was an interesting tid bit.
Offline o2dazone
« Reply #78 on: Thu, 27 August 2009, 13:39:13 »
Quote from: webwit;112321
This guy just the Internet:
http://www.kbdmania.net/xe/photo/860813
he just my Internet as well...damn
Offline wellington1869
« Reply #79 on: Tue, 01 September 2009, 20:09:51 »
It looks like wet paint. Nice.
never mind which keyboard it came from, which keyboards will it fit?! :)
using: ms 7000/Das 3
Offline msiegel
« Reply #80 on: Tue, 01 September 2009, 20:15:12 »
Quote from: ripster;113819
I'll post tomorrow the keyboard it came from.
that thing looks amazing :)
is there a good source of double-shot alps keycaps, anywhere?
Offline rdjack21
« Reply #81 on: Wed, 02 September 2009, 01:40:56 »
Nice... Looks like you put it on your Filco tenkeyless board. So I'm guessing that key cap came from some cherry board.
Keyboards
Black Alps: ABS M1
Offline AndrewZorn
« Reply #82 on: Wed, 02 September 2009, 01:57:48 »
if you want smooth, why not just polish an already famous/good/owned double-shot key?
Offline quadibloc
  • Layout Fanatic
« Reply #83 on: Wed, 02 September 2009, 08:12:10 »
Isn't plastic too soft to really allow itself to be polished well?
Offline itlnstln
« Reply #84 on: Wed, 02 September 2009, 08:16:35 »
That key is from a Cherry keyboard.  The font is a dead giveaway.  It would either be a G80 or G81 series model.
Offline rdjack21
« Reply #85 on: Wed, 02 September 2009, 11:42:59 »
Oh man no bonus points for guessing that you put it in your Filco Blue Cherry Tenkeyless board.
Keyboards
Black Alps: ABS M1
« Reply #86 on: Wed, 02 September 2009, 12:26:03 »
Quote from: rdjack21;113968
rdjack - the t-shirt in your avatar is Da bomb. I havent attempted to make one yet. One day it'll be avail on cafe press though, for sure, lol. I'll see to it ;)
Offline rdjack21
« Reply #87 on: Wed, 02 September 2009, 13:10:10 »
Quote from: wellington1869;113977
I just hope webwit doesn't throw a fit when he sees it :) He is the one that photo shopped it. But even if he does I just needed a little soft landing today.
Keyboards
Black Alps: ABS M1
« Reply #88 on: Wed, 02 September 2009, 13:48:45 »
Quote from: rdjack21;114014
thats a soft landing alright
Offline MsKeyboard
« Reply #89 on: Wed, 02 September 2009, 13:56:41 »
webwit,
You owe me.. ONE MILLION DOLLARS
I hope you had the accent right!
Offline quadibloc
  • Layout Fanatic
« Reply #90 on: Fri, 04 September 2009, 21:45:26 »
The keycap you're converting from happens to be exactly the same style as is on my Memorex-Telex 122-key keyboard.
Offline sixty
« Reply #91 on: Tue, 08 September 2009, 09:10:55 »
almost!
Offline Shawn Stanford
« Reply #92 on: Tue, 08 September 2009, 16:17:53 »
The best four minutes of Python's best movie. You are my hero...
The Brat Prince of COBOL
Offline Hak Foo
  • Make America Clicky Again!
« Reply #93 on: Tue, 08 September 2009, 20:29:15 »
I want a Commodore-style Run-Stop key.
Overton130, Box Pale Blues.
Offline msiegel
« Reply #94 on: Tue, 08 September 2009, 22:37:18 »
Quote from: Hak Foo;115971
how about an atari-style reset key, that makes a farty sound? XD
you guys must remember that :)
Offline Hak Foo
« Reply #95 on: Tue, 08 September 2009, 22:40:17 »
Well, the VIC 20 and 64 had those gorgeous cupped keys.... did the Atari 800?  I know the XL series had non-cupped keys (I've got a 600XL and 800XL)
Offline quadibloc
  • Layout Fanatic
« Reply #96 on: Tue, 08 September 2009, 22:47:11 »
Quote from: Hak Foo;115993
did the Atari 800?
Yes, definitely. It was only after the IBM PC started the trend, by noting that cylinder keys were almost as good - and lent themselves much better to stickers on the top face of the keys - that everyone else switched too, because suddenly cupped keys looked old-fashioned.
Offline itlnstln
« Reply #97 on: Thu, 05 November 2009, 12:27:55 »
Nice comparison, ripster.
Offline itlnstln
« Reply #98 on: Thu, 05 November 2009, 12:55:06 »
The Cherry ones don't look dirty, but they are more of a cream color than stark white.
Offline clickclack
« Reply #99 on: Mon, 09 November 2009, 03:41:27 »
Quote from: ripster;130707
And although it is a repost I just want to show this one to the KBDMania guys because, well, if you're American you might as well be obnoxious since everyone expects you to be.
Haahaaa, living the dream! =P
