Author Topic: M4-1 Opening Up and Trackpoint Repair?  (Read 5381 times)
Offline ch_123
« on: Wed, 29 July 2009, 19:04:15 »
Nice work. I have to try this out on my defunct German-layout M4-1.
Offline huha
« Reply #1 on: Wed, 29 July 2009, 20:51:10 »
Have you tried checking if the resistors still work as they should using a multimeter?
If they do, I'm pretty sure it's the cable. These cables are quite bad; my Endurapro had some problems because the cable came loose.
-huha
Unicomp Endurapro 105 (blank keycaps, BS) // Cherry G80-3000LSCDE-2 (blues, modded to green MX) // Cherry G80-3000LAMDE-0 (blacks, 2x) // Cherry G80-11900LTMDE-0 (blacks, 2x) // Compaq G80-11801 (browns) // Epson Q203A (Fujitsu Peerless) // IBM Model M2 (BS) // Boscom AS400 Terminal Emulator (OEM\'d Unicomp, BS, 2x) // Dell AT102DW (black Alps) // Mechanical Touch (chinese BS) Acer 6312-KW (Acer mechanics on membrane) // Cherry G84-4100 (ML) // Cherry G80-1000HAD (NKRO, blacks)
Offline lowpoly
« Reply #2 on: Thu, 30 July 2009, 05:49:38 »
Did you check the mouse buttons for continuity with the cable removed?
And you could measure resistance on the trackpoint module, also with the cable removed. Not sure if you've already done that.
Offline lowpoly
« Reply #3 on: Thu, 30 July 2009, 10:13:36 »
The one in my mini (a Trackpoint IV) looks completely different. So do the capacitve samples I have. Any hint on the manufacturer?
Edit: here's the capacitive one:
« Last Edit: Thu, 30 July 2009, 10:26:00 by lowpoly »
Offline rdh
« Reply #4 on: Thu, 30 July 2009, 10:45:47 »
Quote from: ripster;105571
So is that how a trackpoint works - those maze like things on the size somehow sense movement and vary resistance??
Exactly.  Here's a Wikipedia article on strain gauges.
at home: IBM "Space Saving" Model M
at work: Topre Realforce 87UKB55
