Author Topic: Doctor, One of my balls feels heavy  (Read 5173 times)
Offline lowpoly
« on: Tue, 04 August 2009, 07:39:10 »
You can use it to make panoramic photos.
Not sure if it is reflective enough. Maybe you can polish it.
Offline bigpook
« Reply #1 on: Tue, 04 August 2009, 08:00:07 »
or you  can tell friends and neighbors its a movie prop from Phantasm.
Offline Rajagra
« Reply #2 on: Tue, 04 August 2009, 09:38:41 »
The 50mm one I got for my Trackman FX was a bit too small. I knew I'd need a caliper one day! You just can't measure these by eye, even at arm's length.
Not that it matters, the old sensor doesn't work on plain steel anyway. (Maybe sandpapering would help?)
Early days, though, my master plan is still "on track." :laugh: A properly engineered support system is my next step.
Offline Rajagra
« Reply #3 on: Tue, 04 August 2009, 09:59:41 »
Trackballing Duke Nukem style... NSFW.
Offline bloodien0se
« Reply #4 on: Wed, 05 August 2009, 14:23:01 »
I've been looking to do something similar with my trackman wheel. Just needs a little more weight but I cant find anything in the 1 1/4 to 1 3/8in size that isn't a super expensive designer marble. I'm sure steel would be too hard for the optical to track.
Offline Rajagra
« Reply #5 on: Wed, 05 August 2009, 16:06:01 »
Quote from: bloodien0se;107257
Hmm, my logitech trackman marble can't track when I pass my finger over the sensor, yet it works while I use a cotton bud to clean off the fingerprint!? It may not be the ideal donor for my project. Logitechs are probably dependent on the dotted pattern on their marbles.
EDIT> I opened the Trackman Wheel so I could test the sensor directly against some steel spheres. It didn't work. A G9 mouse works fine, but using a mouse sensor would cause the inverted axis problem.
« Last Edit: Thu, 06 August 2009, 16:02:00 by Rajagra »
Offline bloodien0se
« Reply #6 on: Wed, 05 August 2009, 18:16:05 »
Quote from: Rajagra;107284
Mine works with my finger? Not accurately mind you, but not a whole lot worse than an optical mouse. It obviously needs some sort of texture but something like this stone sphere both has a lot of texture to it and looks awesome, would also have a good amount of weight.
Offline DrunkenDonut
« Reply #7 on: Wed, 05 August 2009, 18:37:47 »
I dunno... those things are usually polished quite a bit, so they actually won't have very much texture to them. Some can get quite spectacular though, and pricey too.
*Hang on to your wallet!*
BTC E5X5R5BTC-5339R-0 (\'90), MS Natural Keyboard Pro (\'99), Sun Type 5c, 2x 1391401, DASK3ULT (\'08), ABS M1, Dell AT101W, M4-1
FKBN87M/EB (\'09), FKBN87ML/EB (\'09), FKBN87Z/EB (\'09), FKBN87MC/NPEC (\'09), G80-3000LQCDE-2 (\'11)
Offline CreamyNutButter
  • Trackball Gamer
« Reply #8 on: Thu, 06 August 2009, 19:57:46 »
A 2.25 inch ball made from solid osmium (the heaviest natural element) would weigh about 1958 grams (about 4 1/3 pounds)
Trackballs: Kensington Orbit with Scroll Ring and Logitech Marble
Keyboards: Who cares?
  • Trackball Gamer
« Reply #9 on: Thu, 06 August 2009, 21:05:22 »
It lasts longer than the average Dell computer, so why not?
At least someone is satisfied with his Dell - http://www.youtube.com/watch?v=hiCwQB4X8Bc
Offline itlnstln
« Reply #10 on: Fri, 07 August 2009, 07:53:13 »
Quote from: CreamyNutButter;107783
I have a Dell laptop and had multiple desktops at work.  All of them have been great.  My mom had a Dell laptop that ended up being a POS, though.
  • Trackball Gamer
« Reply #11 on: Sat, 08 August 2009, 14:41:13 »
LOL, I just enjoy bashing Dell because it bundles adware toolbars with its computers.
Offline itlnstln
« Reply #12 on: Mon, 10 August 2009, 07:31:35 »
Quote from: CreamyNutButter;108284
Oh, don't worry.  The first thing I do with an off-the-shelf rig is obliterate the HDD, and do a clean install of the OS.  The setup discs we get here at work have a clean OS on them, and the crapware comes on a seperate disc.
Offline Hak Foo
  • Make America Clicky Again!
« Reply #13 on: Mon, 10 August 2009, 10:24:39 »
I won't buy Dell kit after that kid in the ads.  Still.  It's hard for me to even consider an AT101W.
Overton130, Box Pale Blues.
Offline D-EJ915
« Reply #14 on: Mon, 10 August 2009, 12:09:05 »
Quote from: ripster;107766
I could go unnatural with element 118. Unfortunately it disappears every 1/1000 second.
use dark matter (from futurama) instead ;) lol
Offline chimera15
« Reply #15 on: Sat, 24 October 2009, 18:06:00 »
Really interesting.  I always wondered if something like this would work.  Thanks a lot for showing me that it wouldn't.  Saved me some money.
Alps boards:
white real complicated: 1x modified siiig minitouch kb1903,  hhkb light2 english steampunk hack, wireless siig minitouch hack
white with rubber damper(cream)+clicky springs: 2x modified siig minitouch kb1903 1x modified siig minitouch kb1948
white fake simplified:   1x white smk-85, 1x Steampunk compact board hack
white real simplified: 1x unitek k-258
low profile: 1x mint m1242 in box
black: ultra mini wrist keyboard hack
blue: Japanese hhk2 lite hack, 1x siig minitouch pcb/doubleshot dc-2014 caps. kb1903, 1x modified kb1948 Siig minitouch
rainbow test boards:  mck-84sx
Offline chimera15
« Reply #16 on: Sat, 24 October 2009, 19:22:48 »
Quote from: ripster;128078
It works.  Just not for my application (this would be great for someone doing fine detail work constantly).  Something weighted in between might be better for what I do.
Somebody try dipping the ball in PlastiDip.  Or my condom idea.  Well, maybe not the second one.
Well, not just the weight, but also Rajagra, stating that the trackman fx optical sensor didn't pick it up.
Alps boards:
Offline TWX
« Reply #17 on: Sat, 24 October 2009, 20:31:00 »
Quote from: Rajagra;106834
Heh.  I had forgotten that the Duke had a comeback for just about every situation.  I'm a little surprised they didn't work, "Wanna dance?" and "Shake it, Baby!" into the repertoire...
TWX
C:\>echo y|format C: /q
Offline timofonic
« Reply #18 on: Wed, 02 June 2010, 21:56:54 »
A steel ball, that seems lovely :D
Offline timofonic
« Reply #19 on: Thu, 03 June 2010, 03:15:11 »
Where to get steel balls usable by L-Track trackballs? Sorry if I wasn't explicit enough...
