Author Topic: NeXT Keyboard - For REAL this time  (Read 5833 times)
Offline itlnstln
« on: Wed, 12 August 2009, 13:51:07 »
You forgot to spell "Alps" like this: ALPS.  You almost had them all covered.
Offline itlnstln
« Reply #1 on: Wed, 12 August 2009, 13:52:36 »
This would be a nice 'board to harvest replacement keys for those of you with black Dell AT-101Ws.
Offline ch_123
« Reply #2 on: Wed, 12 August 2009, 14:08:52 »
I was even thinking for my white alpS Dell.
Your Dell has white Alps?
Offline itlnstln
« Reply #3 on: Wed, 12 August 2009, 14:10:16 »
Quote from: ch_123;109184
I think he meant white as in the case color as opposed to the black version I mentioned earlier.
That, and I think he was looking for another spot to insert the word "Alps."
Offline ch_123
« Reply #4 on: Wed, 12 August 2009, 14:13:29 »
So profound is the effect that Geekhack has had on me than when people start talking about colours in relation to keyboards, I immediately assume they are talking about keyswitches...
That, and Ripster said "White Alps Dell" which is rather misleading.
« Last Edit: Wed, 12 August 2009, 14:15:44 by ch_123 »
Offline watduzhkstand4
« Reply #5 on: Wed, 12 August 2009, 14:25:52 »
wow that thing is ancient but for $40, it seems like it's too much for a replacement
KEYBOARDS
Cherry Blue *Filco Tenkeyless w/ blank keys* w/ red ESC key thanks to Megarat
Cherry Red Noppoo Choc Mini
IBM Model M 1391401 12/15/88
Siig Minitouch w/ White Alps
SOLD
HHKB Pro 2 white w/ blank keys red ESC key and blank WASD keys
HHKB L-2
Cherry Brown Compaq mx11800
Dell AT101W
Cherry Red Leopold 104-key Otaku FC500RR/ABN
Offline JohnElliott
« Reply #6 on: Wed, 12 August 2009, 14:47:58 »
I think that's a non-ADB keyboard; the ADB ones have round buttons rather than keys for power, volume and brightness, as I recall. And the power button's green.
Offline keyb_gr
  • Cherrified user
    • My keyboard page (German)
« Reply #7 on: Wed, 12 August 2009, 16:21:57 »
Nice. You've got to admit that the NeXT concept was pretty neat back in the day.
Offline D-EJ915
« Reply #8 on: Wed, 12 August 2009, 16:34:26 »
if you gut that I'm going to kick you in the nuts 10 times each day for 5 days straight
Offline megarat
  • (Not My Real Name)
    • http://www.megarat.com
« Reply #9 on: Wed, 12 August 2009, 16:40:55 »
A quick note for those who may be seeking to harvest the keys from this puppy:
There were multiple variants of the NeXT Alps keyboard, and this appears to be the one with the L-shaped enter key and some special characters keys (tilde, pipe, etc.) banished over to the numpad.  (Since they're on a different row, they will likely have a different conformation for their striking angle.)
I believe that makes this the "later" variant.  Another (earlier?) variant has the almost-standard layout, as pictured in the advertisement above.
« Last Edit: Wed, 12 August 2009, 16:46:44 by megarat »
Home/Work:  Custom Filco FKBN87Z/EB and SGI 041-0136-001 chimera (original white ALPS, not simplified, rubber-dampened)
Gaming:  Wolfking Warrior with custom-colored layout, HHKB Lite 2 (Rubber dome)
Offline megarat
« Reply #10 on: Wed, 12 August 2009, 16:43:41 »
Quote from: D-EJ915;109231
Only ten times a day?  Hell, compared to middle school, that's nuthin.
« Last Edit: Wed, 12 August 2009, 16:47:03 by megarat »
Offline D-EJ915
« Reply #11 on: Thu, 13 August 2009, 16:13:51 »
o.o what do you intend to do with this anyway...you obviously don't have a NeXT lol
Offline itlnstln
« Reply #12 on: Thu, 13 August 2009, 16:42:29 »
Quote from: D-EJ915;109565
I think he was looking to reuse the keycaps.
Offline ch_123
« Reply #13 on: Sat, 15 August 2009, 16:12:01 »
You mean ADB, right? You'll need an Griffin iMate for that.
ADB ^
PS/2  for reference ^
« Last Edit: Sat, 15 August 2009, 16:15:48 by ch_123 »
Offline o2dazone
« Reply #14 on: Sat, 15 August 2009, 16:17:19 »
Are you going straight to sandblasting? I bet at low psi it'd remove all that gunk no problem.
Offline ch_123
« Reply #15 on: Sat, 15 August 2009, 16:37:22 »
I could have sworn that NextCubes used ADB ports... Maybe it was some early/late production model?
Offline ch_123
« Reply #16 on: Sat, 15 August 2009, 17:02:54 »
I've used some worn out Alps boards, and the wearing out always managed to be consistent across the board. It was particularly noticable with an AEK II I found where every key felt like a rubber dome switch despite the fact that it definitely had white Alps.
Offline keyb_gr
  • Cherrified user
« Reply #17 on: Sat, 15 August 2009, 17:23:47 »
Quote from: ch_123;109931
That wouldn't be wear in the classic sense then. Degradation maybe.
Don't these have rubber dampers? That should only affect bottoming out though.
Offline ch_123
« Reply #18 on: Sat, 15 August 2009, 17:38:50 »
Maybe so. But it didnt click either... I had a good condition AT102W beside it, and it was definitely louder than the AEKII.
Offline timw4mail
    • https://timshomepage.net
« Reply #19 on: Sun, 16 August 2009, 11:21:35 »
Apparently you need to buy your own bandwidth, Ripster...
Buckling Springs IBM Model F AT, New Model F 77, Unicomp New Model M
Clicky iOne Scorpius M10, OCN-branded Ducky DK-9008-C, Blackmore Nocturna, Redragon Kumara K552-1, Qtronix Scorpius Keypad, Chicony KB-5181(Monterey)
Tactile Apple AEKII (Cream damped ALPS), Filco FKBN91M/JB (Japanese Tenkeyless), Cherry G84-5200, Cherry G84-4100LPAUS, Datalux Spacesaver(Cherry ML), Redragon Devarajas K556 RGB, Newmen GM711, Poker II (Cherry MX Clear), Logitech G910 Orion Spark, Logitech K840
Linear Lenovo Y (Gateron Red), Aluminum kiosk keyboard (Cherry MX Black)
Offline Shawn Stanford
« Reply #20 on: Sun, 16 August 2009, 18:59:50 »
Quote from: timw4mail;110053
You son of a *****...
The Brat Prince of COBOL
Offline lecorsair
« Reply #21 on: Tue, 25 August 2009, 23:38:05 »
ripster,
See if you can source this ps2NeXT converter to use your keyboard. I'm so getting one if that works.
http://m0115.web.fc2.com/
