Author Topic: Ripster's Ghetto Mod To Converting Your Model M To USB Using A Blue Cube  (Read 11930 times)
Offline rdjack21
I would cover those exposed wires on the PS/2 side with some liquid tape just to be on the safe side.
Keyboards
Topre Capacitive: Realforce 87U, Realforce 86U, HHKB Pro 2, Topre MD01B0, Topre HE0100, Sun Short Type, OEM NEO CS (x2), NISSHO Electronics KB106DE
Buckling Spring: IBM Model M Space Saver (1291472), Unicomp Customizer x 2
Cherry Brown: Filco FKBN87M/EB, Compaq MX11800
Black Alps: ABS M1
Not so great boards Rare Spring over dome OKI, Sun rack keyboard
Trackballs - Trackman Wheel (3), Trackman marble (2)
Keyboards I still want to get - Happy Hacking Keyboard Pro 2 the White version, Realforce 23U number pad in black and maybe white, μTRON ergo board with Topre switches.
Previously owned - [size=0]SiiG MiniTouch (White Alps), Scorpius M10 (Blue Cherry), IBM Model M13[/size]
Offline MsKeyboard
« Reply #1 on: Thu, 20 August 2009, 20:19:10 »
Ripster, You're the MAN!
I would really love to do this mode, just don't have the guts.  Thanks for the detailed description.
Later........
Offline rdjack21
« Reply #2 on: Thu, 20 August 2009, 20:48:26 »
Well I have to say ripster good work! I keep thinking that I would like to mount a usb connector inside the 87U case so I could have a removable cable on it. Removable cables really make it easy to switch boards out.
Keyboards
Black Alps: ABS M1
Offline pfink
« Reply #3 on: Thu, 20 August 2009, 20:56:59 »
Quote from: ripster;110918
I recommend starting first with the blue cube.  It'll give you some solder practice and if you screw up you're only out $7 instead of a rare Model M.
Where's the cheapest place to pick up the blue cubes? They're up to $15 clickykeyboards.com.
Offline rdjack21
« Reply #4 on: Thu, 20 August 2009, 21:06:43 »
At the start of the article he linked to the site he bought it at. If you click the link you will see that he paid $7.29 for it unless as he advises he bought 10 of them then he paid $6.93 for them.
EDIT: that was kinda of rude sorry about that. Here is the link from the first page of the fine article Blue Cube
« Last Edit: Thu, 20 August 2009, 21:09:21 by rdjack21 »
Keyboards
Black Alps: ABS M1
Offline pfink
« Reply #5 on: Thu, 20 August 2009, 21:25:17 »
Quote from: rdjack21;110940
Didn't see the link. Thanks.
Offline Hakhu
N-Key Rollover
« Reply #6 on: Sat, 26 September 2009, 04:28:54 »
I was wondering how much the boards N-Key Rollover performance changed, when switching to USB. Do you have any numbers?
Thanks
Offline JBert
« Reply #7 on: Sat, 26 September 2009, 04:59:24 »
No model M's have N-key rollover AFAIK. It will only get limited down to 6 keys due to the default USB HID protocol.
The storage list:
Currently ignored by: nobody?
[/SIZE]
Offline itlnstln
« Reply #8 on: Mon, 28 September 2009, 08:53:33 »
Aren't Fs NKRO?
Offline JBert
« Reply #9 on: Mon, 28 September 2009, 14:16:58 »
Yes, but you need to have an AT version or a converter supporting it.
The storage list:
[/SIZE]
Offline skriefal
« Reply #10 on: Mon, 28 September 2009, 19:27:44 »
Am I the only Geekhacker to have converted an M to USB using a drop-in USB controller board from Chris Lee, as discussed here?
Offline itlnstln
« Reply #11 on: Tue, 29 September 2009, 07:39:32 »
Quote from: skriefal;121297
I think that post predates most of us (even me, I think). I completely forgot about that one. Ripster's looks a little more fun to me, though.
Oh, I think you are the only one that's done it. I think that post is so old that many of the members that would have tried it aren't active anymore. Back then, too, Filcos and HHKBs were all the rage (does anything really change around here?), and Model M mods, while interesting, would have probably fell by the way side. We, now, have a lot more members with a wider diversity of preferences, so maybe some of these older mods could be ressurected.
Offline skriefal
« Reply #12 on: Tue, 29 September 2009, 08:47:44 »
Yes, it's an older post -- although the related discussion did continue (slowly) for about a year after the initial post.  Perhaps pointing it out here will help revive discussion on the topic of replacement controller boards.
(Typing this on an HHKB, btw... :smile:)
Offline Mnemonix
« Reply #13 on: Tue, 29 September 2009, 14:03:56 »
No, you are not alone. I've done it, too, and it worked great. But take a look here! :)
Offline skriefal
« Reply #14 on: Tue, 29 September 2009, 19:34:06 »
Thanks for the pointer to the other thread.  That looks quite nice.  I'll follow the development in the linked thread.
Offline JohnMD1022
    • http://springcreekrhapsody.blogspot.com
« Reply #15 on: Mon, 02 November 2009, 16:24:53 »
I spent several hours checking parts sources for a mod like this, and here it is... lol
Offline itlnstln
« Reply #16 on: Mon, 02 November 2009, 16:27:06 »
I'm glad you found us.  Welcome to Geekhack!
Offline JohnMD1022
« Reply #17 on: Mon, 02 November 2009, 18:25:41 »
Thanks for the welcome..  :)
btw... there may be nothing new here for a sophisticated group like you, but here's a links site:
http://classickeyboards.100free.com
Offline itlnstln
« Reply #18 on: Tue, 03 November 2009, 07:58:45 »
Quote from: webwit;129991
Why isn't there mouse-flavored cat food?
Good question.  I would imagine that's due to a seemingly high processing cost.  Trying to extract the little meat a mouse has from its tiny skeletal structure would be tedious and painstaking, so the cost of such food would be high.
That said, why is it when you send something by boat it' called "cargo," and when you send something by car it's "shipping?"
Offline timw4mail
    • https://timshomepage.net
« Reply #19 on: Tue, 03 November 2009, 08:00:36 »
Quote from: itlnstln;130080
My guess would be the same reason that the Postal Service delivers the mail, and the Royal Mail delivers the post.
Buckling Springs IBM Model F AT, New Model F 77, Unicomp New Model M
Clicky iOne Scorpius M10, OCN-branded Ducky DK-9008-C, Blackmore Nocturna, Redragon Kumara K552-1, Qtronix Scorpius Keypad, Chicony KB-5181(Monterey)
Tactile Apple AEKII (Cream damped ALPS), Filco FKBN91M/JB (Japanese Tenkeyless), Cherry G84-5200, Cherry G84-4100LPAUS, Datalux Spacesaver(Cherry ML), Redragon Devarajas K556 RGB, Newmen GM711, Poker II (Cherry MX Clear), Logitech G910 Orion Spark, Logitech K840
Linear Lenovo Y (Gateron Red), Aluminum kiosk keyboard (Cherry MX Black)
Offline MFGorilla
« Reply #20 on: Wed, 04 November 2009, 10:48:58 »
why do you park in a driveway and drive on a parkway?
"I want an Official Red Ryder Carbine-Action Two-Hundred-Shot Range Model Air Rifle!"
Using Now: Unicomp Spacesaver (black/grey) | IBM Model M 1391401 White Label| IBM Model M 1394946 by Lexmark
[COMMENT]On The Way: IBM Model M Industrial[/COMMENT]
Wish list: Filco Majestouch tenless with Blue Cherries | Matias Tactile Pro 3 | IBM Model M Space Saver
In Storage: IBM M2, DELL bluetooth wireless
Offline MFGorilla
« Reply #21 on: Wed, 04 November 2009, 12:49:02 »
There can never be enough Casablanca references.
Offline steeef
« Reply #22 on: Tue, 23 November 2010, 16:38:32 »
Nearly finished with this. Had to pick up some heatshrink once I realized that liquid tape doesn't handle being compressed inside the case very well. Tested fine once I had everything plugged in, but after reassembling the case it must have shorted out somewhere.
Cherry MX Blue: Filco Majestouch Tenkeyless. Cherry MX Black: TG3 KBA-BLTD-5RBUVS (Police Cruiser keyboard). Cherry MX Clear: KBC Poker (modded with Ergo Clears) Cherry MX Brown: Goldtouch GTC-077 USB numpad. Buckling Spring: IBM Model M 1391401 (1989-01-03 and 1991-11-21).
Offline ricercar
  • mostly abides
« Reply #23 on: Tue, 23 November 2010, 20:22:17 »
Back from the dead
Offline turbocharged
« Reply #24 on: Mon, 03 October 2011, 12:34:02 »
Most of the pictures in the OP are dead. Any plan to get these live again?
| Deck Legend Fire (MX Blacks) | KBC Poker X (MX Reds) | Cherry G80-11900LTMUS (MX Clears) |  Cherry G80-11900HRMUS (MX "Ghetto Reds")
| IBM Model M 1391401 (BS) | Goldtouch GTC-0033 Keypad (MX Browns) |
[SIGPIC][/SIGPIC]
« Reply #25 on: Mon, 03 October 2011, 14:08:47 »
Thanks man. After 8 months I'm FINALLY going to get around to doing this mod and getting my Model M working.
[SIGPIC][/SIGPIC]
« Reply #26 on: Sat, 08 October 2011, 14:41:58 »
Awesome...thanks.
[SIGPIC][/SIGPIC]
Offline weenis
« Reply #27 on: Tue, 29 November 2011, 13:46:10 »
I just converted my M, and I used the following USB B cable-
http://www.amazon.com/StarTech-1-Feet-Panel-Mount-Cable/dp/B002M8VBIS
Dell AT101W | Unicomp Spacesaver PC | IBM SpaceSaver Keyboard | IBM Black Label M | KBT Oni Brown | Leopold Otaku Brown | Noppoo Choc Mini Brown | IKBC F104 Brown
Offline weenis
« Reply #28 on: Tue, 29 November 2011, 22:12:27 »
I couldn't resist mod'ing my M for USB... with a B interface on the board.
Here she is in all her lack of glory.... I also had the opportunity to make the weight of the board 1/2" lb heavier with 56 pennies and wood glue :D-
I was really bummed that I drilled the holes 1/32" to once side. The tolerances were tight enough that just a smidge off and it's completely noticeable. :(
