Author Topic: Overclock.Net About To Hit 100 Pages On N-key Test  (Read 19666 times)
Offline elbowglue
« on: Sat, 22 May 2010, 19:25:40 »
It's useful, in my opinion to demonstrate that the typical overclock.net user rocks the logitech and saitek keyboards quite often. :P
My keyboards: Filco Cherry Blue Tenkeyless(daily home), Compaq MX11800 (modded to blacks), Compaq "MX 84u",  Wellington\'s Dampened Endurapro, Pinkalicious Filco Blue Cherry, Chicony KB-5191, Chicony KB-5181, Desko MOS 5023 UP "elbowglue" spos (modded to blues), Siig Minitouch (monterey blue), SMK-88 (blue cherries), Ricercar SPOS
Smallest to biggest keyboards in inches (Length X Height) - Length is most important for a midline mouse position
KBC Poker: 11.6 x 3.9 - HHKB: 11.6 x 4.3 - Siig Minitouch (Geekhack Space Saver): 11.6 x 6 - Deck/Tg3 82: 12 x 6 - Noppoo Choc Mini 12.4 x 5.3 - Compaq "MX 84u": 13.1 x 7.5 - Filco Tenkeyless: 14 x 5.3 - Cherry "ricercar spos" G86-62410EUAGSA: 14 x 7.75 - Topre Realforce 86u: 14.4 x 6.65 - Desko "elbowglue spos" MOS 5023 UP: 14.5 x 8.4 - IBM Model M Spacesaver: 15.3 x 7 - G80-1800: 15.9 x 7.1 - Adesso MKB-125B: 16 x 7.3 - Compaq Mx11800, Cherry G80-11900: 16.25 x 7.5 - Filco Standard: 17.3 x 5.4 - Unicomp Endurapro: 17.9 x 7.1 - Adesso MKB-135B: 18.3 x 6.0 - Cherry G80-3000: 18.5 x 7.6 - IBM Model M, Unicomp Customizer: 19.3 x 8.27
Offline elbowglue
« Reply #1 on: Sat, 22 May 2010, 19:49:10 »
Damn you rip.  I try to steer them back on course and you jedi mind trick them into doing it over and over and over.
THE QUICK BROWN FOX JUMPS OVER THE LAZY DOG.
Well **** I didn't know my cheap lenovo S10 keyboard has NKRO!!!
Wooot!
I'd like to see if they sticky that thread, now that would be funny.
« Last Edit: Sat, 22 May 2010, 19:51:51 by elbowglue »
Offline lmnop
« Reply #2 on: Sat, 22 May 2010, 20:13:39 »
there were 2 threads actually, the first was started by Enigma and the second was Pathogen. I had nothing to do with either. I never seen either member before.
Offline Viett
« Reply #3 on: Sat, 22 May 2010, 20:14:04 »
Anyone notice how you can get ghosting over USB on NKRO boards? Try this:
(Left) Control, alt, and shift. Try some 4-6 key combos with Z, X, A, S, Q, W etc. You will notice some strange key behavior -- particularly ghosting. And I mean the correct use of the term. Keys you did not press will be pressed. Of course, the same keyboard using PS/2 behaves normally, with absolutely no ghosting.
I think I read about this issue a while ago, but I haven't actually been able to fully test the issue myself until recently.
Keyboards: FKBN87MC/NPEK, Dell AT101W (Black), IBM Model M 1391401 (91) x 2, Deck 82 Fire, Cherry MX8100 (Clears), Siig Minitouch
Layouts: Colemak (100WPM), QWERTY (100WPM) -- Alternative Layouts Review
Offline ricercar
  • mostly abides
« Reply #4 on: Sat, 22 May 2010, 20:33:01 »
Maybe our thread commenting on their thread hitting 1000 will hit 1000.
Offline ricercar
  • mostly abides
« Reply #5 on: Sat, 22 May 2010, 20:43:00 »
Quote from: ripster;185861
No, no.  You don't get it.  We make fun of the OTHER GUYS
Well **** me slowly with a chainsaw. THAT'S WHY I DON"T HAVE ANY FRIENDS!
Offline elbowglue
« Reply #6 on: Sat, 22 May 2010, 21:57:40 »
Quote from: ripster;185859
On my Realforce 87U I only appear to get it on the 6th key pressed down.  For example, pressing CTRL-zasxd is fine.  As soon as I press something else I get that letter and 1 to 3 ghosted letters. CTRL-zasxdc gives me CTRL-zasxdcw.
At that point I kinda lost interest.  I only have 5 fingers on my left hand you see......
Ouch.  Does this happen with cherry blue filco with NKRO over USB?
Ghosting on the topre.  While this has no relevance in real world usage, it sucks to see this exists.
Offline Infinite north
« Reply #7 on: Sat, 22 May 2010, 22:44:53 »
So reading this the only thing I can think of is that we need to start trolling their tests. so go in and show your nkro filco getting "h qui bon ox mp oer lz d."
Offline Phaedrus2129
« Reply #8 on: Sat, 22 May 2010, 23:06:29 »
Also, many OCNers appear to have questionable taste in visual aesthetics:
http://www.overclock.net/computer-peripherals/738695-keyboard-porn-4.html
Virtually a tie between the Das and Lycosa on looks? What?
Daily Driver: Noppoo Choc Mini
Currently own: IBM Model M 1391401 1988,  XArmor U9 prototype
Previously owned: Ricercar SPOS, IBM M13 92G7461 1994, XArmor U9BL, XArmor U9W prototype, Cherry G80-8200LPDUS, Cherry G84-4100, Compaq MX-11800, Chicony KB-5181 (SMK Monterey), Reveal KB-7061, Cirque Wave Keyboard (ergonomic rubber domes), NMB RT101 (rubber dome), Dell AT101W
Offline Viett
« Reply #9 on: Sun, 23 May 2010, 00:34:04 »
Quote from: elbowglue;185890
Yeah. That's the board I used when I tried it. Judging by the fact that this doesn't happen over PS/2 and that I don't think anyone's come forward with a USB rollover board that doesn't have this issue, I'm thinking it's a USB issue.
But as Ripster said, this really is not that big of an issue. I don't think I've ever needed to press all modifiers plus six keys at the same time.
Offline lmnop
« Reply #10 on: Sun, 23 May 2010, 00:51:10 »
why do you care so much about that thread?
Offline lmnop
« Reply #11 on: Sun, 23 May 2010, 01:11:36 »
Offline In Stereo!
« Reply #12 on: Sun, 23 May 2010, 01:25:48 »
The quick brown fox jumps over the lazy dog.
Offline Rajagra
« Reply #13 on: Sun, 23 May 2010, 01:26:11 »
Quote from: Viett;185853
I mentioned the problem here. I get the same problem on my Realforce 87u, HHKB Pro and DAS III.
It's as if USB has a "memory effect" problem. If you start playing with different keys the original problem clears itself, but if you repeat the test it happens again consistently.
Quote from: Viett;185922
Oh yes it is! It's huge. For the simple reason that it proves sloppy programming, and THAT offends me!
« Last Edit: Sun, 23 May 2010, 01:31:31 by Rajagra »
Offline armenws
« Reply #14 on: Sun, 23 May 2010, 02:02:10 »
you could do some mean mashing with that.
Offline Mental Hobbit
« Reply #15 on: Sun, 23 May 2010, 02:04:16 »
Ha-haa! All you morons wasted $250 on a rubber dome with ghosting issues! :brick:
:pop2:
Typing on blues.
Offline hyperlinked
« Reply #16 on: Sun, 23 May 2010, 02:44:30 »
Quote from: ripster;185838
I like that most of them are getting widely varying results.  I suspect that many are not holding down both shift keys, don't know how to type, don't know how to spell, are drunk, are REALLY drunk, stoned, or are actually gaming the stupid test to appear leet.
Blah, this is why I really don't like mega sites... too low of a signal to noise ratio.
Topre: Realforce 103U Cherry: Filco Majestouch 104 (Brown), Ione Scorpius M10 (Blue)
Buckling Spring: IBM Model M1391401 ALPS: Apple Extended Keyboard II (Cream), ABS M1 (Fukka/Black), MicroConnectors Flavored USB (Black)
Domes: Matias Optimizer, Kensington ComfortType, Microsoft Internet Keyboard
Scissors: Apple Full Sized Aluminum
Pointy Stuff: Razer Imperator, Razer Copperhead, DT225 Trackball, Apple Magic Mouse, Logitech MX1000, Apple Mighty Mouse
Systems: MacPro, MacBook Pro, ASUS eeePC netbook, Dell D600 laptop, a small cluster of Linux Web servers
Displays: Apple Cinema Display 30", Apple Cinema Display 23"
Ergo Devices: Zody Chair, Nightingale CXO, Somaform, Theraball, 3M AKT180LE Keyboard Tray
Offline Arc'xer
« Reply #17 on: Sun, 23 May 2010, 15:10:45 »
Quote from: hyperlinked;185943
In general; I notice the site does provide some inaccurate information to certain products or should I say people aren't providing proper information.
I'm no expert on computer equipment. But often times I see people post like on monitor section or the sound card section. And just out right buy said item by word of mouth and not proper research. Or just remain ignorant on newer technologies, maybe it's just segregated to a few sections of that site. But there really needs to be an overhaul of the information provided.
I'm not saying other electronic equipment sites are perfect but at least you see one or a few people come in who know what they are talking about, provide proper information.
Offline ricercar
  • mostly abides
« Reply #18 on: Sun, 23 May 2010, 15:27:46 »
I have that iRocks backlit gaming board; Jeffrey gave me a review copy last year before he quit Geehack. If anyone needs a specific test, let me know.
Maybe I should use that guy as my avatar. His shades are da bomb, and Photoshop could put about ANYTHING in that hand.
Offline JBert
« Reply #19 on: Sun, 23 May 2010, 16:09:22 »
Quote from: Rajagra;185937
Maybe, just maybe, this is a driver issue in Microsoft's OS. Ever tried it on Linux?
The storage list:
Currently ignored by: nobody?
[/SIZE]
Offline ch_123
« Reply #21 on: Sun, 23 May 2010, 16:44:38 »
THE QUICK BROWN FOX JUMPS O1900312120d3d0001er the lazy dog
Model F through a Blue Cube. The fact that both shifts and V will print 1900312120d3d0001 followed by releasing the shifts (probably reseting the keyboard) is probably to do with the adapter. Rather interesting effect... thanks OCN!
EDIT: Confirmed, the Belkin doesn't show that same effect. Scratch another point for the Belkin being the finest USB adapter on the market.
« Last Edit: Sun, 23 May 2010, 16:47:00 by ch_123 »
Offline muchadoaboutnothing
« Reply #22 on: Sun, 23 May 2010, 17:56:23 »
Quote from: ripster;186116
Lol, Muchadoaboutnothing tries to stem the flow.
"Stemming the flow" seems to be a good way to put it, as people continue posting :rant:
Offline ch_123
« Reply #23 on: Sun, 23 May 2010, 18:19:44 »
Ah come on, I basically won that pissing competition.
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
« Reply #24 on: Sun, 23 May 2010, 21:45:19 »
Quote from: ch_123;186111
Good work! We know now that it isn't perfect!
kishy.ca
Offline Rajagra
« Reply #25 on: Sun, 23 May 2010, 21:48:09 »
Offline sixty
    • http://deskthority.net
« Reply #26 on: Sun, 23 May 2010, 22:13:50 »
Offline EverythingIBM
« Reply #27 on: Sun, 23 May 2010, 22:24:14 »
2-key rollover, nice!
Thanks for the laugh.
Offline clickclack
  • Board Chow EXTRAORDINAIRE
« Reply #28 on: Sun, 23 May 2010, 22:27:56 »
SUPERCALIFRAGILISTICEXPIALIDOCIOUS ...
hmmm... wait, what are we doing again?
I am absolutely sure this is completely inconsequential but I found it impressvie that I could type that with both shifts and spacebar held down.
Why did I find that impressive, well... I figure my computer would have either exploded or would have emitted a beam of light with choir music where I could have indulged in a brief glimps of heaven.
862+ keyboards and counting!   R.I.P.ster          Vendor link ->Clack Factory
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
« Reply #29 on: Sun, 23 May 2010, 22:44:38 »
Blue Cube + 1394946 = "HE QUIK BROWN FO JUPS OER HE LA DOG" repeating what ch did.
kishy.ca
« Reply #30 on: Sun, 23 May 2010, 22:56:45 »
Quote from: sixty;186229
Dude! Missed a chance to have Shift+Shift+Q on there!
Offline Rajagra
« Reply #31 on: Mon, 24 May 2010, 00:00:11 »
http://i.imgur.com/pXLQJ.jpg
Haha. Awesome. But I couldn't leave well alone...
(All credit to sixty for the joke and hard work.)
« Last Edit: Mon, 24 May 2010, 01:15:16 by Rajagra »
Offline GTFO
« Reply #32 on: Mon, 24 May 2010, 00:42:55 »
oh yeah are you one of the people who got banned from OCN?
Offline Brutuz
« Reply #33 on: Mon, 24 May 2010, 00:49:44 »
Hey, I would like to apologize on behalf of OCN for GTFOs behavior, but come on, calling us idiots because we don't really know much about keyboards is about as nice as us calling you guys and gals idiots simply because you (might) not have any idea of how IDE and SATA work.
Offline GTFO
« Reply #34 on: Mon, 24 May 2010, 00:53:29 »
Quote from: Brutuz;186263
Hey, if they use foul language on us, I will be rude to them. Respect is mutual.
Offline Brutuz
« Reply #35 on: Mon, 24 May 2010, 00:54:22 »
Quote from: GTFO;186264
Them calling us idiots does not equate to you calling them "****ing idiots" I think it was?
Offline elbowglue
« Reply #36 on: Mon, 24 May 2010, 00:57:53 »
Quote from: Rajagra;186251
That is really funny.  Exclusive Tucan edition.  That is hi-fricken larious raj :)
« Reply #37 on: Mon, 24 May 2010, 02:19:46 »
None of us actually use computers. it's actually a keyboard fetish forum, hence so many posts about ****ing topre's.
Offline bhtooefr
    • bhtooefr.org
« Reply #38 on: Mon, 24 May 2010, 06:29:49 »
TE UIC RWN  JUS VER TE LAY DG
Dell SK-3205.
(On a serious note, it fails on ASW in a REAL NKRO test. I was hoping it would pass the double-shift test with flying colors, though.)
Offline ch_123
« Reply #39 on: Mon, 24 May 2010, 06:34:59 »
Quote from: kishy;186219
Well, the SGI AT-101 causes the thing to **** itself in the most undignified way possible. Here's another failure, albeit one that will never be encountered during regular use.
What's intresting was that it seems only to be the two shifts and V that causes it.
Offline bhtooefr
    • bhtooefr.org
« Reply #40 on: Mon, 24 May 2010, 06:44:24 »
Of course, I just "beat" that score.
BlackBerry Bold 9700. When both shifts are held, NOTHING gets through.
« Reply #41 on: Mon, 24 May 2010, 08:19:29 »
Don't worry, name-calling is perfectly fine on Geekhack.
And thanks to sixty for making me spill coffe through my nose! ;P
Typing on blues.
« Reply #42 on: Mon, 24 May 2010, 10:46:57 »
Ripster is now trolling an entire forum from Geekhack. What's next?
Offline erricrice
« Reply #43 on: Mon, 24 May 2010, 10:52:14 »
Quote from: muchadoaboutnothing;186368
Today, Overclock.net.....
Tomorrow, the world!!!!!!!!!!
I\'m selling all my Shizz! Please buy it!
White ALPS: Northgate Omnikey 101-NCS(Real-Complicated)****Filco Zero FKBN87Z/EB(Fukka Simplifieds)****Siig MiniTouch(XM Simplifieds)
Black ALPS: Black Dell AT-101W(Real-Complicated)****ABS M1(Modded Black ALPS, Linear)
Buckling Spring: Model M 1391401(1988 & 1993)
Cherry Blues: DAS III Pro
Cherry Blacks: Cherry G80-11900
Cherry Browns: 3X Cherry G80-8113LRCUS-2
Cherry MY: G81-7000HPBUS-2****G81-3000LANUS-0****Modded to 20g
Rubber Dome: HHKB Lite 2 (White & Black)
Logitech G5[/FONT]
Erricrice\'s Song of the Day: Gorillaz - El Maņana
Yup, Blatantly stealing this from you Kishy, hope you don\'t mind, it\'s a great idea.
Offline erricrice
« Reply #44 on: Mon, 24 May 2010, 11:18:45 »
Quote from: ripster;186389
type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385">[/youtube]
Interesting modes of transport you have there in Wales Insancen.
You would think that thing would get great mileage on those downhills...all that weight!
Logitech G5[/FONT]
Offline itlnstln
« Reply #45 on: Mon, 24 May 2010, 11:21:12 »
Quote from: erricrice;186398
That would break a rather elementary law of Physics.  Everything falls at the same rate.
Offline erricrice
« Reply #46 on: Mon, 24 May 2010, 11:27:17 »
Quote from: itlnstln;186400
But the momentum would keep it going for much longer than a normal car once you reach the end of the hill though.
Either way it was meant to be a dumb joke lol
Logitech G5[/FONT]
Offline erricrice
« Reply #47 on: Mon, 24 May 2010, 11:28:08 »
Quote from: ripster;186404
I think the real troll is the Logitech G11 Product Manager.
He has been planting this test ALL OVER THE INTERNET in an attempt to boost sales.  If I followed that thread that's what I would buy.
I don't think anyone is following the thread, seeing as no one even tried to argue with you on your 5 trollish posts.
Logitech G5[/FONT]
Offline itlnstln
« Reply #48 on: Mon, 24 May 2010, 13:46:20 »
Quote from: ripster;186411
I thought you knew OCN members can't read?
At least WE are more mature around here at Geekhack.
Damn straight.
He he, you said, "members."
Offline Hand
« Reply #49 on: Tue, 25 May 2010, 08:25:20 »
Nah, I give up trying to stop the flow.
Don't give up!
You would expect at least a few people to respond over there.  Maybe there's a secret hidden code you need to embed in a post to get ocn members to read it.
Past: Unicomp Customizer, SteelSeries 7G
Present: Ducky Shine 3, mx brown
Future: mx clear
