Author Topic: Panic Keys From Panic Girl - How to Make Any Key fit a MX or BS stem  (Read 5543 times)
Offline fssbzz
i got PANIC keys from pimp keyboard, and it is already cherry mx.
Offline ricercar
  • mostly abides
« Reply #1 on: Tue, 04 January 2011, 13:21:33 »
Mixed inventory then. My Panic and Any keys ordered last month all had the square sleeve (non-MX)
Offline Moogle Stiltzkin
« Reply #2 on: Wed, 12 January 2011, 07:21:47 »
What tools do i need to remove a stem and transplant into another key ?
What kind of glue is good enough for the job :X
Royal Kludge discount code:
Lowyat15
15 USD discount.
« Reply #3 on: Wed, 12 January 2011, 11:23:51 »
You mean this one ?
http://geekhack.org/showwiki.php?title=Island:9617
There are a bunch of tools here but i don't what they are or how to use them :/
What i've found so far is
- epoxy glue
- safety googles
I need to know which tool to cut a keycap to remove the cherry mx stem to implant into another key.
« Last Edit: Wed, 12 January 2011, 11:34:04 by Moogle Stiltzkin »
Lowyat15
15 USD discount.
Offline itlnstln
« Reply #4 on: Wed, 12 January 2011, 11:35:11 »
Fail.
Offline kps
« Reply #5 on: Wed, 12 January 2011, 17:55:15 »
Is there a problem of some kind?
