Author Topic: TIL (Today I Learned) WHY it's called Cherry MX Crosspoint Contacts  (Read 3165 times)
Offline itlnstln
All that research and modding, and you didn't know how the switch worked?  I am shocked and astonished.  This has been up for years (QWERTers Clinic; click for more):
Offline ch_123
« Reply #1 on: Fri, 25 February 2011, 15:32:51 »
I had thought that the hideous overcomplexity of Cherry switches had been well documented forever?
Offline ch_123
« Reply #2 on: Fri, 25 February 2011, 16:09:44 »
I dunno. That moving white clicker on the Blue Cherry slider makes my inner engineer cry.
Offline Koeitje
« Reply #3 on: Fri, 25 February 2011, 18:31:07 »
So basically my keyboard consists of 104 tea-bagging switches :D
Offline Pylon
« Reply #4 on: Fri, 25 February 2011, 20:31:46 »
Alps is really easy to understand.
The slider drags catches on the clicky leaf and pulls it down until the leaf snaps back and hits the wall of the housing, which makes the click sound.
Offline keyboardlover
« Reply #5 on: Sat, 26 February 2011, 06:49:08 »
So I'm guessing replacing alps switches is NOT as easy as the "un-clip" and "pop and drop" methods I used to replace my cherry mx switches?
Offline Pylon
« Reply #6 on: Sat, 26 February 2011, 11:15:49 »
No, it's straightforward on the complicated switches since you don't have to deal with the switching mechanism. You stick a pair of screwdrivers into the switch and pull and you've got your switch taken apart. You've got a clicky leaf, a slider, an upper housing, and a spring, and the rest of the switch still attached to the keyboard. The hardest part is getting the spring back.
Simplified type 1 (Fukkas), on the other hand, are harder. They're a lot more vulnerable to damage compared to the complicated design, and the actuation leaves, which are just two pieces of metal, get bent and damaged very easily, especially if you don't exactly align the upper housing with the lower when putting the switch back together (which is very easy to do).
I've destroyed a few so far. See the switch next to 1 (where ~ normally is, but it was Esc for that particular board) for a destroyed Fukka switch.
« Last Edit: Sat, 26 February 2011, 11:18:28 by Pylon »
Offline Soarer
« Reply #7 on: Sat, 26 February 2011, 11:31:38 »
Technically, this thread's title is incorrect.
Offline Soarer
« Reply #8 on: Sat, 26 February 2011, 11:38:53 »
Title is in error (technically... grammatically I don't care about).
Thought I'd see if you could work it out for yourself...
Offline Soarer
« Reply #9 on: Sat, 26 February 2011, 14:39:47 »
Quote from: ripster;301370
TYL (Today You Learned) that I really don't care.
About accuracy? That would be a shame.
Offline Soarer
« Reply #10 on: Sat, 26 February 2011, 15:32:41 »
Oh, so the shameless one does want to know!
It's just that a 'crosspoint switch' is something completely different.
Offline Soarer
« Reply #11 on: Sat, 26 February 2011, 15:44:29 »
Quote from: ripster;301449
Tell it to Cherry Corp.
Why? They said crosspoint contact. That's fine.
Offline Soarer
« Reply #12 on: Sat, 26 February 2011, 15:50:17 »
Are you of Italian descent?
« Reply #13 on: Sat, 26 February 2011, 15:51:26 »
I am half Italian and half German. For some reason, I'm feeling a little insulted...
Offline Soarer
« Reply #14 on: Sat, 26 February 2011, 15:55:55 »
Maybe I should change that to inquiring about Berlusconian descent?
Offline Soarer
« Reply #15 on: Sat, 26 February 2011, 16:09:20 »
Oh, I get it now. You're a Welly sockpuppet.
Offline Soarer
« Reply #16 on: Sat, 26 February 2011, 16:20:13 »
Quote from: ripster;301340
Wellys YouTube videos and mod posts, like most of his technical posts, is technically not complete.
Just semantics.
Offline Arcanius
  • Buckling Spring Lover
« Reply #17 on: Tue, 09 August 2011, 16:46:31 »
Today I learned I learned the word?
Hmm, something sounds wrong there.... ;)
Offline Soarer
« Reply #18 on: Tue, 09 August 2011, 20:43:04 »
Quote from: ripster;396045
Still waiting for your objection to the post title.
I stated it. Not my job to educate the only keyboard expert on the planet retaking the 1st grade.
Offline noodles256
  • le legendary
« Reply #19 on: Sun, 14 August 2011, 14:08:59 »
blow your minddd
AF | Ducky YOTD |
Offline Soarer
« Reply #20 on: Sun, 14 August 2011, 19:13:59 »
Why are you asking, again, after I answered months ago?
Is it that you're trolling? That would be against forum rules.
Is it that you're now harassing people who voted for you in the troll poll that you won? That would be against forum rules.
Offline Soarer
« Reply #21 on: Sun, 14 August 2011, 19:54:39 »
I still don't see Cherry calling it a crosspoint switch, since it isn't one. They say it's a switch with a crosspoint contact.
I'll save you the trouble of not caring about the difference, again...
Quote from: ripster;301349
TIL that you have a problem communicating precisely your concerns.
The post title can't be changed here anyway.  Which I find odd because at OCN the mods told me it can be and they use Vbulletin.  However I've never confirmed this since I've never been the OP there even after 1K posts.  What a kibbitzer!
Quote from: ripster;301424
You don't know me well.  I have no shame.
Added link to this post from the Cherry Switch Wiki.
Quote from: ripster;301435
Well, speak UP man.
Added this to the "Geekhack Mechanical Keyboard Guide" glossary.
Quote from: ripster;301453
Are you of German descent?
Quote from: ripster;301455
No, ItlnStln is.
And he may or may not be a Stallion depending on how picky you want to be.
Have you heard of KBDAuthority.net?  They argue about stuff like this.
Quote from: ripster;301458
Well, I'm glad that worked then.
Quote from: ripster;301463
He has bigger worries than semantics right now.
Quote from: ripster;301476
Who?
Quote from: ripster;301491
Oh yeah.  Wellington1869.  See - I take Semantics Seriously!
He forgot that ALPS has one proper orientation for the sliders and upper case.
TIL the word "Cruciform".  As in, "Cherry MX Reds have the same cruciform dimensions as any other MX switch."
Quote from: ripster;396074
Rusty, haven't been hanging around Reddit much.  Gotten boring.
Typical political crap.
(Attachment Link) 23731[/ATTACH]
This wasn't bad though
Quote from: ripster;396207
You should try English as a first language.
Quote from: ripster;398845
Cat got your tongue?
Is it the plural thingie - it's versus its?
In America this is IT.
(Attachment Link) 24262[/ATTACH]
Oh wait, that's Cousin Itt.
If it's a little grammar thing that's against forum rules.
(Attachment Link) 24263[/ATTACH]
Thing.
(Attachment Link) 24264[/ATTACH]
woody
  •  Guest
« Reply #22 on: Mon, 15 August 2011, 06:09:28 »
Quote from: ripster;398983
They spelled fulfill wrong.
A comma is missing after "LED".
