Author Topic: What The?? IBM Industrial??  (Read 1242 times)
Offline The Solutor
« on: Fri, 29 April 2011, 17:26:07 »
Quote from: ripster;338315
I thought it looked a bit PC Jr like.
What about the pc JR keyboard? seem unmentioned here, there are a couple of its keyboards on ebay.
Offline CurtisLeon
« Reply #1 on: Fri, 29 April 2011, 18:24:28 »
Quote from: The Solutor;339298
I believe they were just ordinary rubber domes.
Currently Using
Space Invaders: NMB RTRT8255CW+
Black ALPS: Dell AT101W
Foam & Foil: BTC 5339SX
In Storage
White ALPS (complicated): Focus FK-2001, Reveal KB-7061 (Chicony rebrand), PC Concepts KB-7000 (Chicony rebrand)
Orange ALPS: Apple Extended Keyboard (modded to ghetto Blue ALPS)
Peerless: Fujitsu FKB4700
Foam & Foil: LR 69497 (unknown make, terminal keyboard)
Offline The Solutor
« Reply #2 on: Fri, 29 April 2011, 21:27:22 »
Quote from: ripster;339320
Rubber domes.
Wish the HHKB had arrow keys.  Even if the Poker had regular arrow key's I'd buy one.
I agree.
Although I think that the dumbest move of poker is having the predrilled led holes but with the switches in the usual orientation.
Not these though. INVERTED T RULEZ!
At least has a decent enter key...
« Last Edit: Fri, 29 April 2011, 21:39:26 by The Solutor »
